Blank screen on Toshiba L300 -11B TR57
Have been advised to remove battery and disconnect from mains. then hold in power button for 30 seconds and then re connect to mains. still no luck.
Is there such a thing as a key that could be pressed accidently somewhere on the notebook which blankls the screen? (I'm thinking along the lines of a mute button !!)
I have a panicking daughter at UNi across the pennines and I am trying to fix it over the phone!!!!!
  • Jay
    Jay May 11, 2010
    It could be a damaged cable running from your LCD to your motherboard. have it checked out for broken or cracked connections.
  • DEKR
    DEKR May 11, 2010
    please give me more info
Blank screen
Remove the residual power from the computer and check if it works.
To remove residual power, disconnect the power cable and battery from the computer. Press and hold the power button down for 20 seconds. Connect only power cable to the computer and check if it boots
Aug 20, 2014 | Gateway Computers & Internet
No power screen is blank
RIGHT
1) UNSCREW THE BACK OF UR LAPTOP REMOVE THE BATTERY REMOVE MEMORY FROM THE LAPTOP AND HDD
2)IF YOU GOT 2 SLOTS REMOVE THEM BOTH FOR DAMAGE AND TRY ONE AT THE TIME
SEE IF IT WORKS IF NOT DISCONNECT THE PC REMOVE THE BATTERY AND THE POWER AND KEEP HOLDING THE POWER BUTTON FOR 30 SECONDS AND TRY IT THAT WAY
Sep 27, 2013 | Acer Aspire 5315 Notebook
My screen dont come on when i hit the power button
Please unplug the power adapter first then remove the battery, then press and hold the power button for 30 seconds. Then plug the power adapter then plug it to the power outlet, now press and hold the power button at least 30 seconds, just to make sure that your laptop will turn on.
Thanks.
Sep 28, 2011 | Toshiba Satellite L45-S7409 Notebook PC
My 1501 Dell Inspiron turns on but I have a blank black screen. The only light that shows is the power light on the upper right side of the laptop.
Power getting to the laptop. Try first to see if this will give a screen image on an external monitor, listen for the sound of the cpu fan, hard drive and DVD rom drives clicking, see if the DVD rom drive will open if pressed.
Then remove battery and AC adaptor, press the power button for 30 secs, refit mains only and try this on mains supply (no battery)
If this fails to boot, check the light on the ac adaptor is a steady green, flashing green indicates power is not fully reaching the laptop (motherboard problems)
If it is steady and the LED power light on the laptop is steady, suspect the DC jack socket. If this feels loose or sloppy, it will need replacing, depending on the type fitted, it may be soldered onto the board, or a wired connector, which sometimes goes bad.
After that, I'd suggest that a capacitor has gone on the actual motherboard and you will need to strip the laptop to check it.
Jul 18, 2011 | Dell Inspiron 1501 Notebook
My Toshiba laptop will not turn on. Light comes on showing battery only. Am plugged in.
Remove battery and ac adaptor. press power button and hold for 30 seconds. Reconnect AC power only, try rebooting. If this fails, then you have a problem with the power switch, or the cut off switch which is located just by the screen hinge may be sticking.
Failing that, and assuming the DC jack is a tight fit, you could have a problem with the motherboard. In this case, I would advise you get it checked by a professional
Mar 27, 2011 | Toshiba Computers & Internet
Toshiba satellite becomes unresponsive after bios
First of all try this. Turn the laptop off and remove the battery. hold down the power button for 30 seconds. Plug just the AC mains power jack in and turn the laptop on.
If it boots all is well, turn the machine off, put in the battery.
Just out of interest can you remember who manufactured the BIOS? was it Phoenix or AMI?
Good luck.
Jul 15, 2010 | Toshiba Computers & Internet
Blank screen, error code;0f00c.
The error you appear to be getting during diagnostics should not be related to the computer not starting. The error you are referencing has to do with a blank CD not being in the CD/DVD drive during that part of the test.
I ran the diagnostics again with a blank cd in the drive and I recieved error code 1000-0146.
Mar 12, 2010 | Dell Dimension 3000 PC Desktop
Which jumpers do I short and where do I find them to reset the bios on a Toshiba Satellite A15-S127 (PSA10U-00RESV) PC Notebook?
There are no jumpers on laptops. remove the battery and disconnect the mains charger hold down the on button for about 30 seconds this resets the bios. Replace the battery
Jan 22, 2010 | Toshiba Satellite A15-S127 Notebook
Toshiba Satellite L25-S1216 - blank screen
Try to shutdown, remove battery, remove AC plug, Press and Hold Power button for 30 seconds, replace battery and AC adapter and test.
do you hear windows booting ( the startup sound) after a few minutes, if so there may be a monitor hardware problem
Feb 27, 2009 | Toshiba Satellite L25-S119 Notebook
I have a Toshiba A105 Laptop, Screen goes blank after windows....
Here are some easy things that can sometimes resolve this problem:
1) Sometimes there can be a static buildup on the mother board. Power off, remove the battery, remove the power cord and hold the power button in the on position for at least 30 seconds.
2) If that didn't work- Power down, remove the battery, remove the Hard Drive and memory modules and reinsert them. Try to power back up
If these things don't work, get back to me for some more ideas.
Ron
Dec 15, 2008 | Toshiba Sattelite A105-S2071 Notebook
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
