Question about Hitachi DZHV595E HD Camcorder
Hitachi DZHV595E wont turn on.
When plugged in via usb or to a plug socket, the lights are on as if it is charging, but it wont connect to my laptop or turn on when unplugged.
marked
  • 6487 Answers
SOURCE: HDMI from laptop to DVI plug on Hitachi big screen TV
To fix it, just turn the set off, let it discharge for a few hours. Reach in and remove the socket from the back of the tube and reinsert a few times to break through the corrosion.
This is a sign of weakness in the manufacturer of the guns and the connecting sockets. The metal used in the pin connections inside the socket are corroding and when you remove the socket and reinsert it cuts through the corrosion and makes good
contact again.
If still not working contact the support for your television..
Hope that helps......
Posted on Jul 06, 2008
  • 92 Answers
SOURCE: hitachi 42hds69 turns on for about 20 minutes then
There is a componet that is heating up on the board then shutting the tv off when it fails, it is cooling off and working again. The problem is this can only be fixed with a diagram of the board to locate the faulty part. You will have to take it in to a service center for work. Sorry for the bad news, I hope this helps a little.
Posted on Sep 25, 2009
  • 125 Answers
SOURCE: hitachi 50ux19k model that will power on and powers right off.
Replace Both of your STK ICs that will fix this they are big black ICs will have part number on them STK392-110 use 180s Mats Electronics has them 1-800-628-1118
Posted on Mar 25, 2010
SOURCE: i have a 1994 50ex8k hitachi rear projection tv that wont turn on
it has a built in safety. there's a problem with tv board
Posted on Sep 10, 2010
  • 9 Answers
SOURCE: hitachi 52" projection tv went black. when i
if this is a DLP it seems your lamp burned out and needs replaced , if so search ebay with model # for replacement, you can purchase a buld or lamp assembly
Posted on Nov 28, 2010
My panasonic Hc-v100 camcorder is not charging when plugged in to USB cable - cursor light is not flashing and battery is running down
you DON'T charge the camcorder with the usb cord,you only move files between cam and computer,you need a power cord that plugs into the wall,see pic, LETO 2A AC Power Charger Adapter USB Cord For Panasonic HC V100 HC V500 HC...
ihave the same camcorder,
Mar 24, 2015 | Video Cameras
My bpt3002 wireless speaker will not charge
Try using the 5v power adaptor socket instead off the USB connection, see manual.
http://www.southerntelecom.com/polariodsupport/downloads/PBT3002.pdf
Also check the battery is secure inside the speaker.
The charging light is RED.
The laptop must be "on" all the time to charge via the USB socket!
Feb 16, 2015 | Computers & Internet
Unit will not power up
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Jan 12, 2013 | Dell Inspiron 6000 Notebook
My laptop wont turn on or charge i bought a new charger and it still wont work how can i fix it?
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Jul 07, 2010 | Computers & Internet
My computer wont charge the battery
May 30, 2010 | Dell Inspiron 1501 Notebook
I plug the laptop in to charge but it is not turning on
May be your charger is no working. If possible check with a new charger. if its working you can buy a new one.
Feb 18, 2010 | HP Pavilion dv7-1130us laptop
Battery charging issue
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 11, 2009 | Advent Netbook
Battey not charging, red light flshing
Check the power adapter with a multi-meter, the voltage of the power plug that plugs into the power socket on the laptop should be slight higher than the voltage that is printed on the label on the adapter.
If it is faulty, there are replacement power supplies available on the Internet or at your friendly computer shop.
If the adapter is OK then the power socket on the laptop is faulty or this socket has a dry solder joint connection on the motherboard.
You can test this by wriggling the power plug when it is connected to the laptop, if the charge LED flickers and if you hold this plug in a certain position the charge LED stays on without flickering, then the power socket is faulty.
This can be repaired, but requires the laptop to be completely
disassembled. I suggest you get a quote first.
Oct 02, 2009 | Dell Inspiron 1525 Laptop
It wont come on or charge
Check the power adapter with a multi-meter, the output voltage on the power plug that connects into the power socket of the laptop should be at a voltage slighly higher that the voltage that is printed on the label on the bottom of the adapter. If the voltage reading is low or none at all the the power adapter needs to be replaced.
If the voltage is OK then plug the power plug into the laptop and wriggle this plug in the socket. If the charge LED light flickers on and off and in a certain position the LED light stays firmly on then the power socket on the laptop is either faulty or there is a dry solder joint with the power socket where it attaches to the motherboard. This fault can be repaired but it requires dismantling the laptop completely to get access to the power socket. I sugest you get a quote first.
If connecting the power to the laptop doesn't work then the fault could be a faulty charging circuit/electronics and may require a replacement motherboard.
Sep 20, 2009 | Acer Aspire One PC Notebook
Creative zen v plus
You could try the back usb port, mine doesn't charge on the front port It needs 2.5vdc?
Aug 26, 2007 | Creative Labs ZEN V Plus MP3 Player
Hitachi DZHV595E HD Camcorder Logo
105 people viewed this question
Top Hitachi Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
PNiss
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
