Question about GE Microwave Ovens
How to change light bulb for model WES1450DN1BB
How to change the light bulb
What kind of microwave oven is this? A counter-top model or an over-the-range microwave? Do you have a brand and model number? And which light bulb do you want to replace - the cavity light bulb, or the bottom light(s) of an OTR microwave?
Oct 19, 2014 | Microwave Ovens
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
Changing interior light bulb on GE jes1289sk
I have had this trouble before but with a different model. There may be a plastic screen inside the microwave that will just pop off exposing the bulb. Now all you will need to do is to find out what type of bulb you will need to change the other bulb. I hope this made things easier on you.
Jul 25, 2013 | Microwave Ovens
How to halogen light bulbson my microwave JVM3670Sk03 I have changed one I know there is another one how do i change it please advice thanks anna
That's covered on pages 35 & 36 of your owner's manual.
If for some reason you don't have yours, you can download it here.
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and
EMO4000, replace the burned-out bulb with a 120 volt,
40-watt incandescent bulb (WB36X10003), available
from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and
JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from
your GE supplier.
To replace the bulb(s), first disconnect the
power at the main fuse or circuit breaker panel
or pull the plug.
Remove the screw at the left edge of the light
cover and push on the right edge of the cover
to open.
Be sure the bulb(s) to be replaced are cool
before removing. After breaking the adhesive
seal, remove the bulb by either gently turning
(for models JVM1850, JNM1851, DVM1850 and
EMO4000) or pulling straight out (for models
JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt
halogen bulb (WB36X10213), available from your GE supplier.
To replace the oven light, first disconnect the
or pull the plug.
Remove the top grille by taking out the screws
on top of the grille that hold it in place and
sliding the grille to the left (opening the door
makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located
in the center of the top opening. Remove the
screw that secures the light cover and lift the
cover off.
On some models, the light cover is located at the
left of the top opening. Lift the cover off.
Pinch the clips that hold the light socket in
place and lift the socket out.
Remove the bulb from the light socket by
pulling straight out. Replace with the same size
and type bulb, then replace the light socket and
cover.
Replace the grille and screws. Connect electrical
power to the oven.
Jun 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Need to change the light bulb. found it but can't
push in on the bulb and then turn a quarter turn counter-clockwise,its a bayonet base bulb,not a candelabra base like a typical light bulb has
Jul 26, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Can the light bulb be changed in this model?
Normally a microwave has to be opened to do this , very high voltage inside approx 2400v , but a normal screw in microwave bulb.
May 12, 2009 | Microwave Ovens
Changing Microwave bulb
Remove lid, you'll probably need a pozi drive screw driver and a tamper proof torx drive.
The bulb is located near the front.
Mar 15, 2009 | Microwave Ovens
GE microwave interior light bulb replacement.
Your post has two distinct model numbers shown, so it's hard to be precise, but I'll try my best.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's at
http://207.234.249.73/mwd/ge_lamp_replacement.jpg
Always unplug a microwave before removing or installing any bulbs!
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there.
There may be a panel on the bottom covering the light(s), too.
If not, chances are you'll have to remove it from the wall, then remove the outer cover.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
If yours is an Advantium type, the following instructable should help: http://www.instructables.com/id/SZFF4WSF44XYT8X/?comments=all
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 03, 2008 | GE JES1289SK Microwave Oven
Open Questions:
GE Microwave JVM1441BH04: Safe to reconnect replacement stirrer & turntable motors after accidentally burning out the turntable motor? GE JVM1441BH04 Over Stove Microwave: Tapping noise was coming from the 21v AC stirrer motor which sits atop the cooking chamber. I disconnected the two connecting leads, unfastened the single screw holding it on, placed in on my scanner glass to get a high rez photo of all the specifics listed on the motor label. Bad news: While waiting for the scan to finish, I warmed my coffee in the microwave on the highest heat for 30 seconds. I subsequently discovered the 21v AC turntable motor, which had been working just fine, was now no longer working, with infinite resistance across its terminals, and a burnt electrical smell. Both the stirrer and turntable motors are powered by a 24v tap off the magnetron fan. My theory: By running the microwave with the stirrer motor out of the circuit, I delivered excessive voltage to the turntable motor, which quickly fried. The 24v tap off the magnetron fan motor currently shows the correct 24v output. However, with both the stirrer motor and turntable motor disconnected, running the microwave for a few seconds shows approx 95v across the wire leads for both of the 21v motors. I have obtained replacement motors for both the noisy stirrer motor and the fried turntable motor. My question: Can I simply reconnect both motors in their proper locations, vow never again to run one without the other connected, and all will be well? Or will the newly installed motors simply be fried in a matter of seconds?
Jan 04, 2018 | GE Microwave Ovens
Microwave Ovens Logo
35 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
