Question about Thermos Stainless Steel Gas Grill
Where to purchase the burner brace for model 461252605
The burner brace is rusted out where to get replacement
2 Suggested Answers
gcken
  • 140 Answers
SOURCE: Cracked primary burners
yes call Flame Grill Services at 770-521-2050
Posted on Apr 04, 2010
I have a 98 Nissan maxima and main brace under motor going to the front is rusted brace is OK but what it bolts to is rusted how do I fix
go to a wreckers that handles your make of vehicle and buy that section complete ( rust free unit)
drill out the spot welds where the rust unit is attached to the body sub frame
do the same for the new section
position the new section in place against the sub frame and you have 2 options her
either weld the parts back together ( best get a qualified welder to do this)
or drill holes and use grade 8 bolts to bolt the sections together
remember that it is an integral part of the sub-frame so it has to be done properly for safety
Sep 14, 2015 | Nissan Cars & Trucks
Cooktop light stays on
Replace the element
Feb 06, 2013 | Kitchen Ranges
Side metal pieces that cover the Viking grill burner are rusted. Do I need to replace the whole burner or just use until burner holes become clogged that then replace?
I would suggest first lifting them out, give them good brush with wirebrush, check if holes are not clogged, check for any not surface damage, they ususally rust bit over on the surface and that is all.
If grill flame is working correctly, and grating have still "decent" thickness and is not falling to pieces, I would still use them normally.
Rust on the grate is usually caused by not using it and exposure to rain/water, as this grating is usually rather solid, surface rust will not affect it. If you have model with stainless graing - there should be no rust on stainless...
That is one of the reasons why you should not wash your grill after use! Fat from cooked food is protecting it from environment.
Hope this will help your worries at bay :-) Enjoy your grill!
Aug 08, 2010 | Viking VGBQ410-3RT Grill
Yellow flame
You may have a rusted, clogged or damaged burner or venturi tube. With a flashlight, check for spider webs, wasp nests or dirt (mud) dauber nests in the opening of the venturi tube where it connects at each gas valve orifice. Clean it out manually or blow it out with air compressor. Make sure the air adjustment opening (on the end of the burner's venturi tube) has not been changed. If it's closed too much, it will be difficult to light and cause lazy yellow flames. If it's not clogged, the burner may just be old and rusted and the burner holes are not allowing very much gas through anymore. It's also possible the burner has rusted so bad, the burner holes have been enlarged, it is falling apart or has cracks along the burner seams. If so, replace the burner(s) immediately. It is unsafe to use. Your local propane co can usually order the parts you need and some will even do the work, if you are uncomfortable doing it yourself. Bring with you the Make, Model and Serial number of the grill, so they can order the correct parts for your specific grill. Also specify whether it's natural gas2_bing.gif or propane.
Douglas
Jun 06, 2010 | Char-Broil CharBroil Master Flame Gas...
Mar 18, 2010 | Thermos Stainless Steel Gas Grill
We have an armstrong 125GRTC601a-2a package unit. The burners have rusted out. We are trying to find replacement burners. Do you know how or where we can purchase these burners. We have contacted...
did you check the heat exchanger? If the burners rusted out you may have holes in it and could get CO in the building. You might be replacing this unit.
Aug 05, 2009 | Heating & Cooling
Main Burners completely rusted out; control knobs to burner...
Get replacement burners and preheat them once. Then paint them with high temp enamle paint to withstand the temps of the grill. The burners are regular untreated steel and not the stainless that one would expect. Painting them will prevent them from rusting out after 2 years. Just make sure you temper them once before you paint them as they will expand a little. Then paint them and enjoy!
Apr 26, 2009 | Frigidaire GL38LKEC (LP) Grill
Only one of four burners will light.
Hello, there is a carry over tube between the burners that looks like a burner hold down at the back of the grill. This is likely rusted closed and will need to be cleaned or replaced. The clips that hold the tube down are part # 7000132 and the tube part # is 7000280. They can be purchased directly from Char-Broil or Sears parts.
http://www.charbroil.com/
http://www.searspartsdirect.com
If you find this helpful please vote yes. Thank You!!
Apr 19, 2009 | Char-Broil Advantage 463453306
Grillpro model # 236464 owner's manual
Don't buy GrillPro grills they are junk!!!!!! I have had a GrillPro Model #236464 Stainless Steel Grill and after Three Seasons it has rusted to peices!!!! All Three burners and all Three Flavor Guards and both Channel Cross lites have rusted to a big pile of rust peices. I called GrillPro which is Manufacturered by Onward Manufacturing Company Limited in Canada and all of these pieces have been on back order for over a month and the company says they don't expect the parts anytime soon. Onward Manufactures the following brands:Broil King, Broil-mate, Sterling, Barbecue Genius and GrillPro. I have looked at several of these brands at Menards and they all use the same type of Burners and Flavor Guards that are in my grill so unless you want a big pile of Rust after three years of use I would avoid all of these Brands!!!!!! Forget the problems Take it back where bought and buy something else!! These brands will let you down! Al Gavin - 515-238-3920
Sep 17, 2008 | Brinkmann 810-2300-B Grill
Thermos Stainless Steel Gas Grill Logo
Top Thermos Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
kc5133
Level 1 Expert
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
