My Maytag top load washer lat3500aae will no longer spin on cycle but everything else work fine. On spin cycle it puts out a burning smell. I have replaced both drive belt and pump belt but the drive belt won't turn on spin cycle , any ideas?
3 Suggested Answers
vest6
  • 196 Answers
SOURCE: Maytag LAT9757AAE,top load washer won't spin.
Sounds like a sticky brake assy. This type of brake is very tricky and should be checked be a service technician
It's possible to do it yourself but not recommended because of the 200 lb. pressure spring. Hope the diagram will help.
Posted on Jan 13, 2008
  • 17 Answers
SOURCE: Kenmore top load washer won't agitate, but will drain and spin
your dogs may be bad in the agitater.. if u open the lid and turn the agitater back and forth does it rachet or does it turn freely both ways?
Posted on Dec 13, 2012
My maytag top load washer model #sav2555aww spins but not fast... I replaced the belt and that helped but still not like it did before.. Everything else works fine, any suggestions?
some of these machines have a timer conflict between rinse [ spin pulse ] and full spin at end of wash cycle the timer contacts remain in the pulse cycle the switching assembley may need replacing
Mar 05, 2011 | Maytag SAV2555A Top Load Washer
My Maytag Top Load Washer was in the beginning of the wash cycle with a large comforter when it began squealing, sounded like from a belt within the machine. I smelled a burning smell and stopped the...
The belt has been ruined. Basically there was to much load on the belt. You will need to replace the belt, maybe a 20 dollar fix and should take no longer then 15 minutes. Just make sure that before you go to the parts house, your remove the old belt and take it with you along with the model and serial number of the machine.
Please rate.
May 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Spin cycle not working. smells like motor may
Open the back door and check the motor body for the heat. If so check whether the drum is freely rotating.
Then check the motor.
Apr 07, 2010 | Maytag Legacy Series Top Load Washer
1 yr machine. Won't spin but has burning smell
The reason to this problem can be due to the
brake rotor.It need's to be replaced.
Sep 01, 2009 | Maytag Centennial MVWC500V Washer
Front load washer doesn't spin
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working) electrical outlet. Then check the appropriate circuit breaker and reset it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a few moments, after the door locks, the washer should begin to spin. (For your safety, the washer will not tumble or spin unless the door is closed and locked.)
If this doesn't work, please contact Customer Service at 1-800-688-9900 for toll-free assistance and service scheduling if necessary.
Sep 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Legacy top load washer is SMOKING!
this is a bogus website that is trying to push smelly washer product....no real fixes and there are other products out there for less just use bleach first
May 05, 2008 | Maytag Legacy Series Top Load Washer
Maytag Model # LAT9635AAE
Check to see if it is a pump problem or a transmission problem. First remove both belts see if all the pullys turn freely. if the pump has a tight feel check inside pump for a item jammed in it.look for transmission oil on floor or belts if oil is present transmmision if probably going.ALSO check at the top of the tubs for anything stuk in between tubs.
Oct 10, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
