Question about SanDisk Sansa e250 MP3 Player
Sansa e 250 will not play all mp3 songs as before.
Some songs now show as UNKNOWN. It use to play everything.
  • xandermark Jan 24, 2009
    mi reproductor de mp3 sansa sandisk se congela en la pantalla de bien venida y se queda con la luz de fondo prendida y ya no pasa aunque le reestablezca y lo inicie de nuevo hace lo mismo y no lo reconoce la pc pormas que lo intento.
    Su ayuda por favor
Right clicked on properties of song and added artist and title of that song, hit apply and problem solved.
Posted on Jan 23, 2009
Plays six of twenty mp3s and the rest come up as
Delete songs and Format (Helps with try to delete BAD TRACKS and folders that will not delete
Labeling Unknown Songs: open Windows Media Player and go to library click on artist. The sub folders will be named by the artists and the unknown songs will be in the sub that say's unknown. Click on unknown then right click on the title bar put a check next to artist and album artist. Right click song under artist or album artist or both and type in the name of the artist etc.... This change in your computers Music folders also then sync with your sansa or media player then load songs to it........
Jul 27, 2010 | SanDisk Sansa e250 MP3 Player
MP3 needs to refresh DataBase?
You have to many songs a sansa e 250 only holds a certain amount of space so your best bet is to buy a memory card or delete songs so you can add new ones.
sincerely,Britani
Apr 19, 2008 | SanDisk Sansa e250 MP3 Player
"unknown" songs taking up memory in my sansa e200
Renew music svc sub, convert to Mp3, or update/remove DRM licensing
Nov 25, 2007 | SanDisk Sansa e200 MP3 Player
The Unknowns
Are they the correct format for the player? Are they MP3's?
Nov 06, 2007 | SanDisk Sansa c240 MP3 Player
Broken
hi try formating the mp3 then check if it still has the music.
Jun 30, 2007 | SanDisk Sansa e250 MP3 Player
My Mp3 Won't Allow Me To Put Unknown Artists Or Albums Or Anything On
if you still have the songs on your computer you can format the player it will delete everything but you will be able to put your songs on with no problem. i had that same problem it was showing songs that i deleted from it and not playing songs that we're supposed to be there
Jun 20, 2007 | SanDisk Sansa e260 MP3 Player
Songs When Selected Play Something Else & Songs that are missing altogether
Follow this link - it explains how to update your player's firmware http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Hopefully this should solve the problem. if you need the user guide find it here; http://www.sandisk.com/Assets/File/pdf/retail/Sansa_e200_UserManual.pdf I Hope this helps :)
Mar 11, 2007 | SanDisk Sansa e260 MP3 Player
My e250 wont play some songs, they are marked as unknown
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jan 28, 2007 | SanDisk Sansa e250 MP3 Player
Device keeps shutting off by itself and won't synch
Make sure the songs are in the right format. Napster is a real bear about disappearing songs - try another music svc.
Oct 11, 2006 | SanDisk Sansa e270 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
117 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
