Question about Electric Mobility Rascal Scooters, Turnabout/Stowaway, Mini base scooter 130 Wheelchair Battery
Sometimes my electric mobility scooter acts as though it's dead - but, the batteries are fully charged and the horn will work. Other times, it acts perfectly normal. The downside is, it's left
The scooter is "electric mobility 130". I hope this can be fixed, as I cannot afford to buy a new one. Thank you in advance for any help you can offer.
  • Electric Mob... Master
  • 1,263 Answers
Okay now this is most likely a loose connection
does the rear axle come away from the main frame ? if so check the connectors there clean gently,,,,
Now check the battery connections does the battery pack come away from the scooter if so again check the connections here , clean and make sure connections are good.
Regards
Posted on Jan 13, 2013
  • 92 Answers
SOURCE: I have purchased new batteries for my mobility
The control seems to be the issue. I have rewired so many scooters. When you have power and it wont go, it is usually the control. If you cannot afford the part right away, you can rewire it or have it rewired direct
Posted on Apr 06, 2010
  • 23 Answers
SOURCE: electric mobility scooter says charge is full but won't run
This sounds she has tripped her circuit breaker. It works just like the one on your house, when you ask too much of it it suddenly goes 'pop' and seems to be dead.
Looks like you have the same scooter as mine, it should be a little white button on the back of the base. If you follow this link, it will give you a pdf version of the older model pride victory manual, (Mine is a three, they are up to about 10!) See fig. 8 on page 20 and 'Circuit Breaker' on page 21. Also, Page 33 has the troubleshooting info. Hope this helps.
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Victory%20Owner's%20Manual.pdf
Posted on May 06, 2010
  • 177 Answers
SOURCE: batteries die fast on my mobility scooter.
Hi. What size batteries you buy will be limited to the amount of room you have in the machine.
17 amp hour batteries are really a bit small for any mobility equipement. A lot of power chairs have 35 or 40 amp/hour batteries.
Buy the biggest that will fit into the available space.
Batteries are designed to perform a certain number of "charge cycles". If you run your batteries down by 75%, you will only get a small number of "charge cycles". If you only use 25% of the batteries capacity, you will get 100's of "charge cycles".
The best I have seen is 7 years out of a set of batteries. Short trips and recharging after each trip is the reason.
Good luck. Neil.
Posted on Jun 04, 2010
Testimonial: "thanks again"
  • 177 Answers
SOURCE: Scooter stops intermittenly
Hi. Does the machine stop suddenly, or does it slowly stop as it normally would? Does this happen on hills or slopes?
A lot of scooters have a self-resetting circuit breaker connected to the battery leads. If the machine draws to much current ( amps ) then the circuit breaker trips out. After a few minutes the circuit breaker will reset and you can continue.
This could mean that the circuit breaker is faulty or that the motor is drawing to much current, or is burnt out.
Some machines have a very light duty circuit breaker, and these can trip out often. I have changed many of these circuit breakers for this reason.
Check all your battery leads are secure and tight.
If it is still a problem, get a serviceman to check the motor current is what it should be.
Good luck. Neil.
Posted on Jun 07, 2010
FixinFax
  • 3085 Answers
SOURCE: Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Posted on Jun 27, 2010
I have a Taotao electric scooter not a mobility scooter the scooter is fully charged the lights and horn work fine but when you turn the throttle nothing happens it makes a kind of clicking sound
Not familiar with your particular scooter - but I am well versed with electricity. The issue you're seeing is likely a result of a poor connection somewhere. The amount of power (current in amps) required to operate the horn or lights is a small fraction of that needed to run the motor.
You should trace larger sized wires/cables from the motor back as far as you can - ideally to the battery if possible. Remove, thoroughly clean and reconnect each of these cables under each terminal screw - one at a time. This way you'll know any unconnected cable goes on the only terminal that is removed.
At this point, you should have 100% good connections for all high current loads - including the motor and will probably be able to use the scooter. Placing the battery on a slow trickle charger overnight will help ensure that the battery is fully charged - not just enough to operate the horn or lights.
May 11, 2015 | Electric Health & Beauty
Mobility scooter
Check the inline fuses inside the tiller.
Dec 29, 2014 | Health & Beauty
Scooter is fully charged but will only run with charger plugged in
check batterys separate 1 may be dead load test them
Mar 23, 2013 | Health & Beauty
Battery charged power light dead
hi, if that's the model where the rear axle comes away from the frame , check the connections there make sure they are clean and do in fact connect
Regards
GeWiz.
Feb 05, 2013 | Electric Mobility Health & Beauty
Battery shows fully charged and the horn beeps but it won't move.
I have the same problem in mine.. But the beep is continous. Mine is a fortress 2000 AT. anybody knows what's the trouble on this one?
Jan 12, 2013 | Electric Mobility Health & Beauty
The scooters won't start although lights and horn workd
mcdevito75 here, Is the battery fully charged, if not, Charge battery, if Charged double check connection at battery and motor.
Jun 24, 2010 | Electric Mobility Mobility Electric Power...
Batteries fully charged on pride legend fuses, isolater checked. checked all wiring appears good connection but system dead, please advise joe
Hi ,you need to check whether there are any fuses under the seat,
Does the horn work ? , do the power tiller ? the display showing how much the battery is charged
Regards
GeWiz
Aug 02, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Electric Mobility Rascal Scooters, Turnabout/Stowaway, Mini base scooter 130 Wheelchair Battery Logo
309 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
