Question about Bradford White M-I-75S6BN 75 Gallon - 76,000 BTU High Input Atmospheric Vent Energy Saver Residential Water Heater Nat Gas
Melted parts on top of hot water heater
Plastic is melting, top of water heater very hot
  • Bradford White Master
  • 5,245 Answers
What would cause my pool heater to get so hot that it melted the black plastic on the outside of the unit.
check the inside for foreign objects like mice, nests, snakes etc. Check the exhaust is clear, and also the air intake. Does it have an air filter?
May 03, 2015 | Hayward Industrial Products Hayward...
Why won't lp 125 shut off after you turn off faucet continues to burn then backflows hot water through cold supply line and melts it then pressures up and blows line
It sounds like there is too much pressure in the hot water pipes. You can try adjusting the pressure. Do it a little at a time to see how much hot water is coming out. The only other thing I can think of is that there is a large delay between the switch and the water flow. meaning you will need to stop the water a while before you actually want the water to stop flowing.
Elisa Jed ' http://www.mccreeryhvac.com
Jul 14, 2014 | Bosch & Tankless LP Hot Water Heater
No hot water,central heating is fine
Sounds like the output fitting has melted inside and clogged up the output pipe. These couplings are one way valves to keep water from draining backwards when not in use to keep from burning elements. They are plastic inside. I would turn off water and replace those after a visual inspect if needed.
Feb 20, 2013 | Water Heaters
I have an Atwood hot water heater in a Bounder motorhome. When I turn on the switch to fire up the electronic ignition, it instantly blows the 12v fuse. An inspection of the unit shows wiring with melted...
My guess is that you may have or have had a spider web or other debris in burner tube that caused flame to back up, thus burning some wiring but, have someone experienced check it and clean it. The wiring if not burned too bad may be able to be repaired/spliced.
Jul 03, 2011 | RTO Atwood Water Heater - 6 Gal LP
I have an electric Hot water heater with two elements. A few months ago we replaced the pop off valve and a year ago we replaced the thermostat.Since yesterday, we have not hot water. So my husband...
Replace the melted part.
If tank is popping breaker, then the melted part has a short circuit.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
When replacing thermostats, I usually replace both of them
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
There are 5 basic parts to electric water heater.
Electricity to water heater.
Upper thermostat
Upper element
Lower thermostat
Lower element
It sounds like electricity is good.
Elements are probably good if just replaced, but one of them could have a short.
Thermostat is melted, so replace it and see if it restores hot water.
If not, then take 40 minutes and do complete troubleshoot as shown in link above.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 16, 2011 | Rheem Water Heaters
The black wire in the hot water heater is glowing red, I can hear a noise in the breaker bos so I pulled the breaker loos and the plastic to the panel has been melted.
Breaker may be defective and not clipping off when it overheats. More and more power keeps going through it and nothing to stop it. Or check the wiring on the heater itself to be sure they are connected right.
Jan 27, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Hot water heater flow problems.
hey Bookie, those plastic inserts are kinda moulded into the nipples, so taking them out might be more than a feat,...did you solder the pipe to the female adapter ON the nipple? if you did you melted the plastic and that is what's your restricting your flo,......or (believe it or not) the inlet water valve isn't turned on all the way,.....close it then open it,..could have somethin stuck in it. let me know eh? thanks and good luck, cracklin joe
Jan 05, 2010 | General Electric GE SmartWater Household...
Low pressure on hot water taps and showers
Many states building codes require a pressure regulator and expansion tank for hot water heater installation. Check the pressure regulator if you have one as this would only affect the hot water pressure. Adjust or replace. Rap the expansion tank like knocking hard on a door. Hollow sound is good. Dull thud means it needs to be replaced as it is filled with water.
May 24, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Bradford White M-I-75S6BN 75 Gallon - 76,000 BTU High Input Atmospheric Vent Energy Saver Residential Water Heater Nat Gas Logo
111 people viewed this question
Top Bradford White Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Bradford White Water Heater Expert? Answer questions, earn points and help others
