Question about Samsung LN46A550 LCD TV
At initial startup (don't turn off all day) once tv turns on the screen has a heavy vertices green or red will turn itself off then come back on by Itzel's..may do this twice or s
    Top Expert:
  • Samsung Master
  • 75,032 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on Jun 17, 2017
  • 1554 Answers
SOURCE: Static lines one screen
as the top is ok and the bottom has this issue.
It looks like the circuit board has a bad connection to your screen.
it is not repairable by you and not an adjustment.
you need to have it repaired.
don't you miss the old wack on the side fix?
Posted on Feb 17, 2008
  • 395 Answers
SOURCE: Red Vertical line across tv screen.
remove and reseat the system board if that doesn't cure it replace the system board part number AA94-15695A get it at price $158.90.
this is what the board looks like
Posted on May 15, 2008
  • 41 Answers
SOURCE: Samsung hl-s6186 screen flickers and sometimes goes green
The humming will usally come from the color wheel(one of the only moving parts), which is part of the light engine. If the tv is starting to get a green picture that is a sign that the light engine is on it's way out.
Posted on Aug 08, 2008
SOURCE: samsung tv turning off by itself
I had a similar problem where my 61" Samsung DLP was turning itself off very frequently I had resolved to try replacing the bulb. I called a local TV repair place to see if they had my buld in stock. The guy I spoke to actually told me how to fix my problem! There is a little blue switch behind the bulb access door. The inside of the door has a little piece that presses the switch down. The switch is supposed to work correctly weather the switch is in the up or down position but samsung forgot to take expansion from heat into account. If the switch is held in the upper position by the door and the plastic expands to a certain point, it triggers the set to shut off. This does not occur of the switch is held in the lower position. What you need to do is take the access door off and put it back on by sliding it into position from above. That will hold the switch in the down position, eliminating the problem. My set has not **** itself off ever since.
Posted on Feb 08, 2009
Big Hev
  • 64 Answers
SOURCE: samsung 42" Plasma -Black vertical line when turned on.
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
Posted on May 25, 2009
HDTV Green Screen,
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 26, 2016 | Zenith Televison & Video
MOST LIKELY problem is the convergence amps but.....
It might be your vertical or horizontal circuit...those initiate a 3 blink failure code too....
Dec 01, 2007 | Panasonic PT-50DL54 50" Rear Projection...
Why is my TV screen PINK?
Have heard of this issue,in most cases while using HDMI cable.Try switching to component cable hookup.(Red/Blue/Green RCA type plugs).This will still give you Hi-Def.(don't forget to get a Red/White cord set for the audio also,unless you get a 5-way cord that does both).
Jun 03, 2012 | Sony Televison & Video
I have evenly spaced, rows of two vertical green and red lines from top to bottom of my vizio plasma P50HDTV10A
Somehow when switching between the tv and the dvd my wife encountered the pink and green, thin, parallel, vertical lines on the screen. The picture was visible with the lines. I turned the tv off and on but the problem persisted. Unplugged tv for about two minutes and after plugging it back in and turning it on the vertical lines very gone and the picture was back to normal.
Jan 12, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
19 inch slyvania tv/dvd combo turn on play button stays on and the the tv goes to red green yellow and blue screen and won't do anything else
I have been having just about the same problem with mine, i can watch the tv for about 20 min and then the dvd player comes on by itself then it goes to red, green, yellow, and black and white, i've tried resetting the dvd player to default but it hasn't helped mine.When i try to turn it off it automaticly comes back on so i have to unplug it.If i find a way to make mine work right i will send you a message to let you know so you can try it on yours. I've had mine just over a year and i don't have a warrenty anymore.
Aug 08, 2011 | Sylvania LD195SSX 19 in. LCD TV
TV has sound but the screen looks like it is going out has double, colors green, yellow, red. Went off by itself once. Wavy looking. Smelled burning in back, when it went off by itself.
you're describing a power convergence amp problem, usually starts out at random color shdes or gohsts around the images more noticeable on scenes with letters or horizontal and vertical lines. the power amps overheat and sometimes will short out causing the fusible resistors to burn out. these amps are usually mounted on heavy metal dissipation units in one of the main boards.
Jul 30, 2009 | Samsung Televison & Video
Tv problem
Hi and welcome to FixYa,
Based on your description of the fault on a conventional CRT TV , initial suspect would be a capacitor in the vertical circuitry. There would be a number of capacitors within the vertical area, the probable faulty one would be the biggest of the bunch. It would be relatively close to the vertical IC that is mounted on a heatsink. Incidentally, the technical name of your describe fault is "vertical foldover".
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 29, 2008 | Televison & Video
Hitachi 53uwx10b Convergence
The grid (called an overlay) is put in place to fine-tune one of the colors, usually green. Once one color is adjusted perfectly, the other 2 colors are adjusted to match the first color. For example, if the convergence data is completely erased, the tech will set up the overlay and align the green using to the overlay, and then align the red to the green and then the blue to the green. If the alignment is being done after replacing the convergence IC's because one or 2 colors are slightly off in the corners, the green is usually very close to perfect and the use of the overlay is not absolutely necessary. It is pretty easy to align one color using the outer edges of the screen itself. If you do need the overlay it can be purchased from any Hitachi parts distributor such as Herman Panson, Fox or Union Electronics.
Mar 31, 2008 | Televison & Video
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Samsung LN46A550 LCD TV Logo
50 people viewed this question
Jerry Greenberg
Jerry Greenberg
