Question about Meiko 64" Double Tank Electric Heat Rack Conveyor Dishwasher
Meiko K64E dish machine pre wash will not shut off keeps running
Dish machine keeps on running after the dish racks are threw and it should be off.
2 Suggested Answers
Sailorm0on
  • 61 Answers
SOURCE: We would like to get the cost of 2 dishwasher
The product costs 9249.95. check this link for reference http://www.selectappliance.com/exec/ce-product/mk_dv80.2
Posted on May 13, 2009
Meiko dishwasher dv 82.0top arms are not spraying water
In most cases, they are just clogged with stuff from the dishes not being pre-rinsed. The top and bottom sprayers are both connected to the same systems as far as the wash and rinse is concerned.
Jan 10, 2018 | Meiko Dishwashers
My Hotpoint dishwasher works fine except that it will no longer wash the dishes in the top rack. It's like the water is not coming up far enough from the bottom to do the job.
There should be an upper spray arm to wash the upper rack, it may be stuck. Look at its position, run the machine a few seconds and see if it moved. The spray nozzles on the arm often get clogged with food particles. the pipe feeding the spray arm has to extend when you pull the rack out and retracts when you push it in. Make sure it works properly and has not disconnected.
Sep 04, 2017 | Hotpoint Dishwashers
The dishwasher runs through it's cycle but does not clean the dishes properly and leaves a cloudy film and smears on the inside of the machine and the dishes
    Common Problem
  1. Confirm the wash water is hot
    1. Try heated wash(sani wash) if available
    2. Run hot water in sink to warm up before starting
    3. At least 120 degree Fahrenheit water temperature
  2. Open door check wash arm position start washer for a minute
    1. Confirm wash arm has rotated
    2. Check for plugged spray tips at either end of wash arm.
    3. Use small tweezers to remove
    4. Check for rack and dishes interfering with arm rotation
  3. Place cup in upper rack with opening up cycle washer.
    1. Confirm that cup quickly fills with water
    2. Not washing check water level in tub mim 1 1/2 inch
  4. Discontinue use of rinse/dry liquid additive.
    1. Confirm rinse/dry additive not leaking from dispenser into tub
    2. Washer detergent contains sparkle additive and too much sparkle/rinses/dry additive will coat dishes
    3. Try alternative wash detergent that contains minimal rinse/dry additive and use without liquid rinse/dry additive.
  5. It will take several wash cycles after the elimination of rinse/dry to purge the oily film from dishes and machine..
  6. If success "joy" is achieved with no additives then cautiously add back wash detergent with additives. Additives are important to facilitate drying and protecting the glassware china from leaching. The leaching process permanently etches the surface of glassware leaving a cloudy appearance.
Jan 03, 2016 | Dishwashers
Error 305 on meiko dv200.2 what does it mean?
Could be a faulty booster level / pressure switch. Do you hear the air gap cup filling in the back? Could be a faulty fill solenoid (aqua stop hose with solenoid at water inlet.)
Aug 31, 2013 | Meiko DV200.2 Door-Type Dish Machine
Why rinse booster heater and rinse cycle not function for MEIKO-Model: DV80T (Dishwasher)
In these machine when boiler heating not reached to 85 deg 1)washing cycle keeps running. 2)it will not goto rinse cycle. 3)check the boiler heater & replace.
Jun 28, 2010 | Meiko DV 80.2 Dishwasher
We would like to get the cost of 2 dishwasher racks for a Meiko DV80.2 dishwasher. I beleive the racks are 20 x 20.
May 13, 2009 | Meiko DV 80.2 Dishwasher
My meiko Dv 80 dish machine keeps showing and info code of 420. What does it mean and what should I do?
info 420 means shortage of rinse agent reported "ready for washing"state. you may have an empty or low rinse in your bottle , also could be filter on your dosing tube slightly bloked , or your doing pipe may be bloked . if not them your pump might be fauty
Apr 03, 2009 | Meiko DV 80.2 Dishwasher
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
OLD KITCHENAIDE MODEL KDI-20 LEAVES SOAP GRANULES ON DISHES.
I have this same problem, plus the pre-wash soap dispenser doesn't open sometimes even though a service guy replaced that. Could he have replaced just one side and not the other? this dishwasher also has a new motor. sometimes it washes beautifully. but other times it does not. even if both dispensers opened.
Dec 04, 2008 | KitchenAid Dishwashers
Dishes not clean in bottom rack of Whirlpool Quiet Partner I (du1048xtps4)
check to make sure your lower spray arm openings are not blocked.
Nov 07, 2008 | Dishwashers
Meiko 64" Double Tank Electric Heat Rack Conveyor Dishwasher Logo
19 people viewed this question
Top Meiko Dishwashers Experts
jdthefixer
Are you a Meiko Dishwasher Expert? Answer questions, earn points and help others
