Question about KitchenAid KV25G0X Stand Mixer
How to fix a Kitchenaid Model # KV25G0XWW mixer head that jumps
    President:
  • 2,976 Answers
Use the locking lever on the side. It WILL jump if you are mixing something stiff.
Posted on Jan 16, 2013
SOURCE: Kitchenaid K5A mixer 10 speed only runs on fast, no slow speed
Pull the back off and there will be two screws at the top of the Speed Control Plate and a 3rd screw at the bottom. Tighten the top two screws down. bakerboy49203@yahoo.com. Let me know if it works.
Posted on Mar 21, 2009
SOURCE: 4 1/2 quart kitchenaid mixer head jumps when mixing
Adjusting the screw didn't work for me the first time I tried it.  I was afraid of loosening the screw too much, and so I didn't turn it far enough.  Turning the screw counter-clockwise until it stuck out several millimeters finally worked.
Posted on Apr 08, 2009
  • 145 Answers
SOURCE: Kitchenaid Mixer will not lock
This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Hope this helps!
Posted on Jul 08, 2009
ASE TECH
  • 57 Answers
SOURCE: My Kitchenaid mixer (KV25G0XWW)5+ yrs old, started
go to any local hardware store Ace tell them you need retaing ring pliers to remove you c clip if you cant find try your automotive stores like autozone, advanced autoparts they should have retaing clip remover.you should also get some gear oil while your there for the gears sounds like you dont have any oil int the gears.heres an image to help you out.d456ce6.gif
Posted on Jan 27, 2010
Testimonial: "Thank You! Very Helpful!"
  • 5 Answers
SOURCE: Brand New Kitchenaid Artisan Mixer - Mixer head is stuck
Unplug the mixer, turn the whisk the opposite of normal rotation in a quick motion, the remove a per normal.
Posted on Feb 20, 2010
KitchenAid ACCOLADE 400 Mixer.When mixing dough the bowl jumps out of the the bowl lock. How can this problem be resolved?
I know this sounds a bit simple but the bowl cup can sometimes actually wear out and a very fast (# screws) and a new one and the problem is solved. If however there is a problem on the head hold down set screw (under the mixer in the cavity ) it can come loose then the mixer head can bounce all over the place causung the bowl to get loose in the holding cup at the base of the mixer., I hope this helps, let us know if you need more, we can FixYa
Feb 22, 2015 | KitchenAid Food Mixers
Does the epicurean have an attachment for ice cream maker?
The Model: the Kitchenaid KAICA attachment will work with all Kitchenaid mixers 4.5 to 8 quart models both tilt head and bowl lift.
Aug 03, 2014 | KitchenAid KT2651X Epicurean Stand Mixer
Kitchenaid stand mixer 5SSWH 325 watts. How do I adjust the bowl height? Beater is too far from bottom of bowl. Thanks! Cas
There is a screw at the bottom of the motor head (flat head) you usually can't see it because of the top rim of the mixing bowl. hard to see and hard to reach, it may also be hard to turn due to "gunk" from mixing stuff (egg butter flour sugar) turn the screw counter clockwise to lower the motor head clockwise to raise it, you may also have the wrong size beater, it is not an uncommon problem, if you are the original owner and you have the original beater it should fix your problem with the adjusting screw, however I am not clear as to your model a 5SSWH would actually be a K5SSWH, which stands for kitchenaid 5 quart solid state white mixer, if this is your model number and you have the correct beater size then the adjusting screw will work to lower the head down, adjust it down using the stir or slowest speed just untill you can hear the beater "Ding" against the bottom of the bowl, then back it off a quarter turn to adjust properly. Hope this helps, let us know
Apr 17, 2013 | KitchenAid K5SS Heavy Duty Commercial...
Kitchenaid artisan ksm150 - Motor Head Locking Lever stuck in locked position
Get a copy of the Repair Part List of your model from Kitchenaid.com
Remove the Motor Housing (1). The Latch Lever (3) is connected to the Latch (10)
and held in place to the Lower Gearcase (5) by the Latch Bearing Screw (8). This
screw is visible from the outside and located near the Latch Lever.
Tighten this screw to fix your problem.
Aug 03, 2011 | KitchenAid KSM150PS Artisan Series Stand...
KichenAid mixer parts problem
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212057.pdf
has a diagram of the locking mechanism item 9. The screw you removed was probably item 8. Look at the parts and you should be able to figure out how to get it back together.
Mar 27, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
My Kitchenaid mixer (KV25G0XWW)5+ yrs old, started making a grinding sound whenever we increased the speed to 5. Below 5 and there was no sound. It seemed that the sound was coming from the planetary...
Jan 27, 2010 | KitchenAid KV25G0X Stand Mixer
Mar 15, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Mixer Head Wobbles
Fixed it!!! My mixer had the same problem.  It was a hand-me-down...
Okay, so I lifted the head and looked down into the pivot where there is a screw (looking from the front of the mixer).  I took a flat-heat screwdriver and turned it counter-clockwise.  (It took quite a few turns, the screw came out a few millimeters.)
BUT when I lowered the head, hurray!  No more paddle rubbing against the bowl!  No more head jumping up and down!  No more wobbling in the "locked" position!
Try it!
Jan 13, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Stand jumps
The height of the beater is easy to adjust on the tilt-head model.  Tilt the head back, and look into the pivot from the front of the mixer.  You should see a screw on the hinge.  With a flat blade screwdriver, rotate this screw half a turn counter-clockwise to raise the beater height.  Lower the head and check that the beater does not touch the bowl.  Repeat until the adjustment is satisfactory.  To lower the beater closer to the bowl, turn the screw clockwise instead.
Jan 12, 2009 | KitchenAid K45SS Classic Stand Mixer
Need user manual for Kitchenaid Artisan Series Mixer Model RRK150 OB serial no. WS 1208816
Looking on the KitchenAid site, your model did not look up, buyt I put miune in and this is the link to download the manuals.
Nov 25, 2008 | KitchenAid Artisan Series Tilt-Head Stand...
KitchenAid KV25G0X Stand Mixer Logo
485 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
