Question about Dell Computers & Internet
How do I setup wireless N technology on Dell Inspiron 560 Intel Core 2 Duo
The Dell instructions are too vague. I received Dell Wireless 1525 WLAN Card Quick Start Guide with 2 external antennas. Where is the card or do I need to purchase?
  • jak247 Jan 12, 2013
    Came with 2 screw on antennas- I thought a wireless 1525 WLAN card came in my computer-if so to what do I screw on antennas ? The Quick Start Guide shows the 1525 WLAN card. Is this inside my computer or do I need to puchase separately?
    portforward does not list the Dell card
  • Dell Master
  • 3,799 Answers
Try following the instructions in the quick start guide. That is what it is for after all. The card goes inside the case, look on the back and see if there is anywhere to fit the antenna. If there isn't you will need to buy a wireless card(it doesn't have to be Dell or even a card- a USB wireless dongle will do the same job and is easier to fit and set up.
Posted on Jan 12, 2013
Testimonial: "Thanks for your help. Obviously, you haven't seen the lack of instructions in the quick start guide, I tried to follow."
5 Suggested Answers
  • 6 Answers
SOURCE: Dell Inspiron 1525 Memory Card Reader Compatibility
There is no big differece between the two. Both of those can work on your DELL memory card. Cheers!!
Posted on Jan 28, 2009
  • 41 Answers
SOURCE: I have a "Dell, Inspiron
For PCI adapters, I go with TrendNet. I would recommend a USB adapter though. They come in all shapes and sizes, but they all pretty much do the same thing. Here is a link to a ton of them:
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2699&name=802.11g-USB-2.0-Adapter&Nav=|c:2691|&Sort=0&Recs=10
Please let me know if you have any other questions.
  • 70 Answers
SOURCE: wireless card driver
Ok, since it's a Dell, then it's pretty easy to get the driver.
1. go to Dell's support website: http://support.dell.com
2. Click "Drivers and Downloads"
3. Choose "By Service Tag"
4. Enter your service tag and click GO
5. Scroll down to "Network"
6. Download the "Recommended" driver and install.
7. Follow the installation directions from there.
Posted on Feb 04, 2009
  • 81 Answers
SOURCE: how to use the ore duo
The core 2 Duo should be used the same as any single core PC. The only difference is that with the Duo, the computer itself will utilize both cores as needed. Simply use it as you would any other PC.
Posted on Apr 28, 2009
Cannot access internet or no network connection.
Dell Inspiron 1525: Unable to Connect Wireless Network
setting up the right option for wireless network connection at Dell 1525. Here's the following:
  1. Go to Control panel
  2. Select Windows Security Center
  3. Select Windows Firewall
  4. Click on Change settings
  5. Here you might see User Account Control will ask for your permission to continue, simply grant it.
  6. Click on the Exception tab at the middle
  7. Scroll down to Wireless Portable Devices and check the box next
  8. Click Apply, then hit OK
  9. After close the program now you can try to connect again and watch the result.
With assumption you're already make the wireless enable in BIOS setting. In the device manager you should see what the type of wireless wlan card you used and make sure it's already turned on via your switch on your laptop. If it was, then you need to find out the right wireless device driver for Dell Inspiron 1525. Here's the following:
  1. Visit Dell Support site and open the Network tab in the table.
  2. Find your wireless device and download the driver for it.
  3. Aim to a folder on your computer or any external drive if you have it.
At the Inspiron 1525 laptop
  1. go to start
  2. Right click at My Computer
  3. Click Properties
  4. Click Device Manager and Network Adapter .Here you should see a WLAN Mini-Card or might you only see "Unknown Device".
  5. Right Click on it and go to properties to select the Update Driver. Now you should browse the folder to select the driver you're already download at the first step.
NOTE:
Just follow the instruction appears completely. After installation the wireless wlan driver at Dell Inspiron 1525 finish, then reboot the machine and know your wireless connection should be works properly.
Jun 07, 2011 | Dell Inspiron 1525 Laptop
Dell Inspiron 1525 has black screen and blue lock icons are active, with centre(of three) flashing.
Remove all Drives, battery, RAM and wireless cards, see if anything changes, if not replace the motherboard. If error changes, add 1 RAM module back and see if system POSTS. If it doesn't , try the other module, if still no go, replace motherboard. If you do get a change, add items back until you ID the failed item.
Nov 29, 2009 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
My wireless will not work
Check your Settings in the Control Panel (Network Connections, as well as Hardware (to be sure the device is enabled!)
Also Check Power Settings in the Control Panel.
Go to Dell.com, Download the Drivers and Software (Everything Relative to Networking)
Reinstall them,
Apr 21, 2009 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Want to get Dell inspiron 1525 drivers for window xp
http://www.laptops-drivers.com/dell-laptop/how-to-install-windows-xp-on-dell-inspiron-1525-or-downgrading-vista.html
hope this will help
Mar 03, 2009 | Dell Inspiron 1525 (dndwpa3_6) Intel Core...
SOUND DRIVER PROBLEM IN DELL INSPIRON 1525
Reinstall the xp audio drivers off of Dells website.
Thank you for choosing Fixya.com
John C.
Feb 18, 2009 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Audio Driver required
http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&osl=EN&catid=-1&impid=-1&servicetag=&SystemID=INS_PNT_PM_1525&hidos=WLH&hidlang=en&TabIndex=
These are all the drivers for inspiron 1525, Just change the window operation to either XP or Vista as to what you have.
Dec 14, 2008 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Hi i m havung dell 1525 with core2 duo processor in it ..and at top of the dekstop there are 8 options like internet,web cam,help and support............is removed ..i can't see them now.........plz help...
sounds like the dell 'quickset' software has been removed- insert the driver disk that came with the 1525 and follow the install instructions - then scroll down until you come to the desktop software section and reinstall the control software - hope this helps
cheers
Nov 19, 2008 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Computers & Internet Logo
60 people viewed this question
Alun Cox
