Question about Olympus WS-100 Digital Voice Recorder
Can you save file in WAV format?
I need to analyze my recording in a WAV file. Is there a means to do this with the WS-100?
    President:
  • 919 Answers
The recorder will record the file in WMA format. You will probably need to search for third party software that will allow you to change the format from WMA to WAV. Do a google search for audio editing software that converts from WMA to WAV. Olympus does not provide any software that does this type of conversion.
Posted on Jan 23, 2009
My WS 100 says FULL and won't either let me put it
The recorder should be formatted only by using the internal FORMAT function found in the recorder's Menu. Using a computer to format the recorder may corrupt or delete system files needed to run the recorder, so formatting via the computer is not recommended.
Individual files can be deleted from the recorder while it is connected to a computer without negative effects.
Feb 04, 2010 | Olympus WS-100 Digital Voice Recorder
How do you convert the mp3 from the olympus digital voice recorder into a .wav file. I know it requires I Tunes, but other than that I don't have a clue. I know how to convert a normal mp3, but...
I think maybe the Olympus MP3 is DRM protected so if you would like to convert the file into .wav file .the first thing you need to do is to remove drm from this file and then convert it .here,I 'd like to introduce you an all-in-one music converter.you could solve all your problem at the same time .save your time .http://www.removing-drm.com/music-converter/reference.html
Oct 14, 2009 | Olympus WS-100 Digital Voice Recorder
How do I save recorded audio files to a playable format?
You could convert your WAV files to MP3 with one of many free utilities.
Free WAV to MP3 encoder
Jul 12, 2009 | Ableton Live 7
Plzz
Formatting the Recorder (FORMAT)
If you format the recorder, all function settings will return to their defaults.
All files stored in the recorder will be deleted.
If you have important files that you want to save, connect the recorder to a computer and
transfer those files from the recorder to the computer before formatting the device.
1 Press the MENU button.
2 Press the FF or REW button to choose “FORMAT”.
3 When the PLAY button is pressed, “nO” is displayed.
4 Press FF or REW to select “yES”, and press the
PLAY button.
After “ARE yOU SURE” is displayed, “nO” will be displayed.
5 Press FF or REW to select “yES”, and press the
PLAY button.
“DONE” displays when formatting ends.
s It may take up to several tens of seconds to finish the initialization. Do not remove the battery or detach
the battery compartment from the recorder during that time. Otherwise data may be damaged.
s Never format the recorder from a PC.
s When the recorder is formatted, all the stored data, including locked files, are erased.
Nov 08, 2008 | Olympus WS-100 Digital Voice Recorder
Olympus WS-100
if you were able to format the recorder thru the recorder.. it should be ready.. but if formatted through the computer, the files needed to operate the recorder are lost and you will need to send to repair to get the files put back on there
Sep 02, 2008 | Olympus WS-100 Digital Voice Recorder
I get a "full" message but it is not full
Try this:
4 Formatting the Recorder (FORMAT)
PLAY button.
PLAY button.
May 28, 2008 | Olympus WS-100 Digital Voice Recorder
Audio converter for dss audio files
You can convert DSS file into wav format with DSS Player 2000 or the latest version. it can only convert it into wav format. after convert into wav format then u can use any other converter to change it into any other audio format. u can use total video converter or Sonic record now multilanguage software.....
best of luck.....
Feb 08, 2008 | Olympus WS-100 Digital Voice Recorder
Recording format
You'll need a software program to convert between audio formats. Here's a link to a free one that you can try:
http://www.topdrawerdownloads.com/download/104928
If it isn't quite what you were looking for there are lots of free converters out there. Just go to www.google.com and search for 'convert wma to wav' and you'll be presented with some choices, most of them free.
Jan 02, 2008 | Olympus WS-100 Digital Voice Recorder
Files do not appear on PC
the computer not support the file format. use DSS player to convert the file format to wav and then to any other audio format. or use the SONY LAS VEGAS 7.0 OR 8.0 to convert it into required format.
best of luck.
Dec 14, 2007 | Olympus WS-100 Digital Voice Recorder
WS-300M Olympus Voice Recorder
you can rewind a tad and listen, but you can't overrecord, because a digital recorder writes audio information into a data file and saves it. you just can play it back again and record a new file. if you want to cut off a part of your recording, you have to edit the file in an audio editor. - as the olympus stores wma-files, you'll have to convert them into wav format first to edit them. i tried the 'switch' software successfully.
Aug 13, 2007 | Olympus WS-300M Digital Voice Recorder
Olympus WS-100 Digital Voice Recorder Logo
139 people viewed this question
Top Olympus Audio Players & Recorders Experts
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
