Question about Water Heaters
To much preasure building up in my whirlpool EE3Z80HD055V
Water keeps leaking out of T P valve and leaking in the fittings leading into the high pressure "WellMaster" tank that sets above the water heater. It has never done this before and I notice when you turn on just hot water the flow of the water is inconsistent. I am thinking that a new thermostat and maybe new heating element cause it doesn't heat as efficient as it used too.
  • 148 Answers
SOURCE: Hot water heater leaking at the top valvue
I believe the problem you had with the pop off valve is a one time thing since you said you just installed the water h eater
The pop off valve is a pressure relief valve that is activated by build up in the tank from excessive pressure either through too much heat or pressure which works by pressing aginst a spring loaded valve
If you go to the whater heater and look at the valve ther is a handle on it take your hand (stand clear of valve opening) and slowly pull it you will see water start to come out
More than likely a new valve could have had a piece of debris in it or was partially open
re
If the heater was overheating the valve would stay open and you would see extremly hot water rushing out
I do not recommend that you replace the valve unless it continues
Good luck to you
Posted on Jan 09, 2009
freetek
  • 5568 Answers
SOURCE: limited hot water
Some checks are surely possible but PLEASE make sure that the 220VAC is absolutely shut down.
In a home we built in 1977, circuit breakers were improperly marked and I, with decades of experience, believed I had turned off the power to our water heater only to find that it was still 'hot' and blew away a screwdriver tip before thinking to check across terminals to see if the voltage was in fact OFF.
You may have the same problem I had twice over ~30 years; that the lower heating element is open/failed. These typically will gather a coating of mineral deposits and eventually be unable to transfer their heat to water fast enough to avoid overheating and failing.
The limited hot water comes from the fact that the thermostat is checking for temperature at the exit point of the heater; the top. The thermostat turns on both elements but with only the top one still working it heats 10-15% of the tank capacity and then shuts off.
With your meter set to the lowest Ohms scale (typically 200 Ohms), measure across the element terminals. You should measure pretty much a short since the elements have an extremely low resistance; on the order of 10-20 ohms, if you measure anything that goes 'off-scale' on the 200 ohm range (normally blinking), the element is shot.
Don't forget to drain the tank before pulling out the element!
If you are in the US, near any city, check your white pages for: Johnstone Supply or check their website to see if one is near you.You will pay 1/3-1/2 hardware store prices for the replacement element - buy two, store the second one. They are 'wholesale' to the trade but have never been refused.
If you don't feel like wading through their extensive website, you can take the element with you and they can give you what you need.
Posted on Jan 25, 2009
rick_stokes_
  • 61 Answers
SOURCE: warm water only
You can eliminate the shower control knob possibility by turning on your hot water anywhere else in the house. If you get hot water in other places, then it could be the knob causing it. A substantial lime buildup in the tank can also cause poor heat transfer from the elements to the water.
Posted on Sep 19, 2009
  • 409 Answers
SOURCE: leaking pressure relief valve
what is the water pressure on the cold side? You may need to install a pressure reducing valve at the water heater inlet to reduce inlet pressure and keep pop off valve from opening when not needed.
Posted on Mar 10, 2010
SOURCE: After connecting a drain line to the pressure
Turn off the electricity.
Turn off the water valve going into tank.
Open a bathtub spout to let hot water pressure off the tank.
Check top of tank for any leaks.
Open the top access panel and see if element is leaking.
Open bottom access panel and see if lower element is leaking.
The reduced pressure on the tank will slow the leak.
If element is the problem, you can squeak by for a while by turning on the hot water heater only when you need hot water.
Order the 'Marathon MR85245 replacement element' online
http://www.gpconservation.com/rheem/marathon-sp213670-titanium-4500w-lower-element
These elements may be available locally, but they are not the same as 'ordinary' tank-type electric heater elements that you buy at the hardware store.
Buy more than 1 element because the Marathon elements have problems.
One of the reported problems with marathon elements is the high price of stainless steel replacement elements.
Drain tank.
Replace element.
Another resource for water heater information is:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Posted on Nov 04, 2010
I have a Whirpool water heater Model No. E3z5ordo55cv the T&P valve is leaking I have replaced it twice in the past week. It is still leaking. Any suggestions ???
The T&P valve or temperature and pressure relief valve is placed on a hot water heater for safety. If it is still leaking after replacement either the temperature is too high causing excessive pressure or your house pressure regulator is set to high or has failed. The water heater has a thermostat to control the temperature. Check to make sure it isnt cranked all the way up. If the water heater is old there could be a lot of sediment build up. if sediment builds up near the temp sensor it will have to superheat the water above normal levels to heat the sediment up enough to shut off. Drain your water heater and flush out all the junk then try it again.
Dec 30, 2014 | Whirlpool Whirpool Energy Star Dishwasher...
Water leaks continuously out the over flow from the geyser hot water system
You could have excessive inlet water pressure , or bad valve .
Feb 24, 2013 | Water Heaters
Model # EE3Z80HD055V sensor failure?
1) Copy following link for troubleshoot resources including service manual, parts ordering, and general repair information:
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
2) 'Sensors' are temperature sensors located above each element, behind the foam insulation, behind the metal doors on side of unit.
Sensors feed temperature information to the computer chip that decides when to turn elements on-off.
3) Order parts direct from Whirlpool.
Feb 02, 2013 | Water Heaters
I have water leaking from a valve on top of my AO Smith PCGC 50 water heater.
That is called a pressure relief valve....
If the water gets too hot, the pressure builds too high in the tank or the valve goes bad, it will leak...
Remember that this valve is a SAFETY device!!!
Do NOT plug the valve off...
Find out why it is leaking and get it fixed...
heatman101
Mar 26, 2011 | Water Heaters
I have a hot water heater that when running seems to build up an excessive amt of pressure. We just replaced the pressure valve because the old one started leaking when the hot water was running for any...
The most likely problem is that the thermostats are set too high. Remove the thermostat cover plates and look to see where the thermostats are set. The range should be between 120F and 135F. Liquids expand with heat so the higher the temp, the high the pressure. Decrease the setting on the thermostat until the leak stops.
The other likely cause is a head of air trapped in the top of the tank. After drawing hot water, it wiill be displaced by the incoming cold makeup water. This will compress any air in the top of the tank. As the water heats, the air will heat and pressure will build - possibly causing the leak. You can purge the tank of air by opening the pressure relief valve until water comes out (which I assume that you have already tried).
Dec 09, 2010 | Whirlpool Water Heaters
My preasure valve is leaking it is the second time i have to change it in 4 years. is that normal
There are reports that elements on the Marathon cause problems.
This comes from the guys who repair water heaters.
But I think the problems are mostly that the elements burn out frequently and are expensive to replace.
There may be other brand-specific problems I'm not aware of
Another thing you can do is put an expansion tank on the incoming cold water line.
Expansion tank is used when water heater temperatures are set high
The expansion tank absorbs pressure during high-heat events so pipes and tanks and pressure valves last longer.
Oct 30, 2010 | Water Rheem MR40245 Marathon Electric ...
My hot water heater is leaking out of long drain pipe
The long drain pipe is the expansion relief overflow, it is too hot. The thermostats are too high. Or the valve is shot. Do you notice the water being too hot to touch? You might want to drop the temp a couple notches. There are thermostats on both gas and electric units. Also, do you have hard water? I have seen hard water build up on the expansion valve and cause it to leak, you could open that up for a second and let out some water to see if it will unclog it. Careful! Hope this helps.
Apr 27, 2010 | Water Heaters
Leaking pressure relief valve
Feb 27, 2010 | Emerson Part UWL Chrome Ultrasystem water...
Whirlpool electric smart water heater not heating all the time
DO YOU HAVE A MANUAL FOR AN 80 GALLON
ENERGY SMART ELECTRIC WATER HEATER?
THE MODEL # IS EE3Z80HD055V
I HOOKED EVERYTHING UP, THE GREEN LIGHT IS ON BUT I DONT HAVE HOT WATER YET.
Mar 04, 2009 | Water Heaters
Water Heaters Logo
90 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
