Is tere a digital tuner to replace a analog tuner
  • 5,190 Answers
No - most people use a set top box. They are pretty cheap and just connect to the scart socket.
Posted on Jan 14, 2013
How to switch from analog to digital
The LED LCD TV's came out in 2009. It already has a built in digital HD tuner.
Allen wants to know how to switch the TV between the built in analog tuner and built in digital tuner.
Switching between the two tuners is done by means of the "TV mode" switch on the remote control.
You will NOT be able to select analog channels if have NOT done analog tunning.
If you need to do a retuning then hit the "menu" button select "setup" then "plug and play" enter the default pin number 0000. When you are selecting the channel source to memorize make sure you select "digital and analog". This will then cause the TV to tune and memorize both the analog and digital channels.
For details refer to page 8 of the user manual.
Feb 24, 2014 | Computers & Internet
Does my Curtis Mathes Tronics model 19001 have a digital tuner?
No,all small tvs CRT tubes analoge tvs design under 35" none of the tvs have a digital tuner inside of it tv Tuner signal board.Must get a signal through a Digital Converter box to recieve a free on AIR broadcating channels from a Digital broadcasting signal.Tvs that are analoge CRT tubes design that have a Digital Tuner design inside of it are only some DLP tvs analoge CRT tube design 40" and above have it only.
Aug 09, 2011 | Curtis-Mathis CM19011 TV
Does this model DVD/VCR recorder have an analog tuner or a digital tuner?
Is there a manufacture date on the back of it. The Commission's digital tuner rule specifies that as of March 1, 2007, all new TV sets must include digital tuners. I believe that rule follows when it comes to DVD players with built in tuners. If you bought this before that date then most likely its analog. I see in the owners manual has no listing for a digital tuner. So I would come to the assumption that its analog tuner. Hope this helps!!
Jan 14, 2011 | LG LRY-517
Analog to digital convertion
Yes,LCD tv have digital tuner inside.Just buy a digital antena.Plug it in the antena analog whole.Go to menu setup go down to ch.rescan should have all free air channels.
Jan 16, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
HP pc with built-in tv tuner
Have 9, 5 and 13 turned entirely digital as yet, so as to leave you without their signal?
From what you say, the tv tuner in your HP receives analog signals better than or instead of digital signals the stations you can receive may be analog while 9, 5, and 13 may have dispensed with their analog transmitters.
They don't have to until June, since the changeover was delayed from the original February cutoff date by Act of Congress. It is actually easier to receive a digital signal than an equally powered analog equivalent so the fact that your system worked so well with analog signals bodes well for the efficiency of your indoor antenna arrangement, though you may have to replace the possibly analog receiver in your pc with a usb digital thumbdrive like model to continue after the changeover is final.
Here's a tip...if the receiver in your pc resembles a square aluminum tin can, mounted on a PCI card in one of your slots, it is very likely analog and not digital.
Usually these receivers (or actually TUNERS) are heavily sheilded while digital receivers do not require the same amount of sheilding to avoid interference with other components, which is the concept of the big square tin can, that a digital tuner does not require.
Mar 27, 2009 | Computers & Internet
Digital Transition
It's analog.  You need to purchase a digital receiver.  I personally have a USB external digital tuner running in Media Center 2005.  Search Ebay for "ATSC usb".  There's a lot of different options and most of them are pretty inexpensive.  To use a digital tuner in Media Center 2005, you have to leave the analog tuner / tuners in also.  You should still be able to use your current remote control with the new digital tuner.
Jan 25, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Digital or Analog
Unless it specifically states it has an ATSC tuner (not to be confused with an NTSC tuner), or it has a CableCARD slot, it's only has an analog tuner, if it has a tuner at all.
Not a big deal, as long as the TV has some kind of input, you can get a Digital Converter box which will decode the digital TV transmission back to analog and feed it to your TV.
You can apply for a money-saving coupon toward the purchase of digital converter box at http://www.dtv2009.gov/
Aug 12, 2008 | Sanyo AVM-2555 25" TV
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
