Question about Epson Stylus C84 InkJet Printer
Paper Jam C84
Was printing and I looked over and all the paper I had was all going through the printer. Now its jammed. Alice
  • 353 Answers
Was the printer feeding multiple sheets at the same time, so that the sheer thickness of the wad caused the jam? If so, look into the slot where you load paper (this is called the automatic sheet feeder or ASF). You should see a small roller with a rubber coating. This is what pulls the sheets into the printer. Put one sheet of paper into the ASF and do a print. The Windows test print facility is convenient for this: start-control panel-printer and faxes, then right click your printer icon and select properties, then test print). If this works OK, put two pages into the ASF, then three etc. Observe what happens. If at some point more than one page is pulled in, it infers that the ASF is not working properly, in which case you will need to consult a technician (or have a go yourself at dismantling the printer). If the one-two-three-four etc page test doesn't produce a multiple feed, all it probably means, is that static electricity is holding the sheets tightly together. Make sure when you put a wad of paper into the ASF it has been fanned.
Report back on what you find, or if you have any queries on the above.
Posted on Feb 01, 2009
Paper jams at toner cartridge, printer service maintenance kit installed
Paper Jam clearing: copy and paste the link in your web browser...I used to work with these printer's..when they work great, when they don't, not so great..
https://www.manualslib.com/manual/949165/Hp-Laserjet-5000.html?page=84
Clearing Paper Jams If the printer's control panel displays a paper jam message, look for paper in the locations indicated in Figure 22, then see the procedure for clearing the paper jam. You might need to look for paper in other locations than indicated in the paper jam message. If the location of the paper jam is not obvious, look first in the top cover area.When clearing paper jams, be very careful not to tear the paper. If a small piece of paper is left in the printer, it could cause additional jams. If paper jams are a recurring problem, see page 78.(A paper jam message might also display if the rear door is open.)
The top cover of the printer must be opened and then closed to clear a paper jam message.Paper jams can occur at the following locations:Output areas(top and rear)Go to page 75.
Loose toner might remain in the printer after a paper jam, but thetoner should clear after a few sheets are printed.
Jan 31, 2018 | HP LaserJet 5000n Printer
My hp deskjet says there is a paper jam when there is none and will not print
If your printer for any reason reports a paper jam, withput going through the "clearing paper jam" procedure it may not respond to print command. So follow the procedure below:-
Clearing paper jam in a printer is simple almost seven step procedure depending on the printer. Paper jam is the term used to refer to the scenario where your paper fails to come out of the printer during the print process. When you send a document to the printer, normally the printer prints out the document on a paper; then you can pick up your printed copy. When the paper gets stuck in the printer, it is said that paper has jammed in the printer "paper jam".
Even if you are not a technical person, you can conveniently clear paper jams. All you need is to follow the set of procedures outlined below.
Good luck & God bless!
Mar 01, 2011 | HP Deskjet 3845 InkJet Printer
Paper jam - can't clear error message
Hello Nj,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Paper jams are was very common on HP printer model.
Here are few instructions on how to clear the paper jam on your printer.
How to Clear a Paper Jam on an HP Inkjet Printer 1. Disconnect the power cord from the back of the printer before you begin. With the power disconnected, you will protect yourself from being shocked. This is an important step when you are fixing any type of electronic device.
2. Move your printer so that you'll have access the back panel. Unhinge the back access panel of the printer.
3. Look for paper through the opened back panel. Remove any paper you find jammed.
4. Close the back access panel. Make sure that it latches into place and looks the same way it did before you opened it.
5. Open the front or top access panel. This is the panel you use to access ink cartridges. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer. Go back and do that now. Look for paper that may be jammed in this area of the printer.
6. Remove any paper you find jammed here. There will be resistance from the paper feeder, so pull slowly or the paper will rip and create a more serious problem.
7. Close the front access panel. Make sure that it latches back into place.
8. Plug the printer in and attempt to print again. If you can print successfully, you have removed the paper jam.
Hope this helps.
Aug 08, 2009 | HP Office Equipment & Supplies
Paper jam epson c84
If you are sure that no scraps of paper (or other object) is jamming the paper feed path, you will need to dismantle the printer to investigate further. This is really a job for a technician; however, if you want to have a try yourself, you can download the service manual from here:
http://www.eserviceinfo.com/downloadsm/12748/Epson_C64%20and%20C84.html
Also, post a new comment to this effect since I can provide useful extra info on getting these difficult machines apart.
May 08, 2009 | Epson Stylus C84 InkJet Printer
Hp2200D Won't print - "jam" light comes on - but no jam
Have you cleaned the feed roller? If it's dirty it'll spin but won't pick up any paper. Look at the paper after a "jam." Can you see any black roller marks on it? That's a sure sign of a dirty roller. If you suspect a dirty roller, clean it with a little alcohol on a cloth.
Mar 10, 2009 | HP LaserJet 2200D Printer
Copier canon mf4150 says it has a paper jam, but there is no paper jam.
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
Sep 16, 2008 | Office Equipment & Supplies
Paper jam
if it picks up paper then say's jam you most likely have a very small piece of paper still jammed.look for a dent in the paper you pull out,if there is a dent then that's probably the problem.look where dent is on paper and that is where you should look for the piece that's causing the jam,if that does'nt solve problem i would need more info
Sep 22, 2007 | Brother MFC-3240C All-In-One InkJet...
Epson Stylus C84 InkJet Printer Logo
95 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
