Question about Irons
Bosch iron - access to thermostat - question for Ernesto Cuadra
Ernesto, thanks for your drawing given at http://www.fixya.com/support/t13833260-bosch_sensixx_b25l I am unable to figure out how to open the iron in order to get to the thermostat. I am only able to open up the rear panel of the iron (from where the power cord emerges), but that does not give me any access to the thermostat area. I've looked for hours on the web for a service manual or repair manual, but without success. Can you guide me as to how to gain access to the thermostat on the Bosch TDA2445 steam iron? Thanks very much! - Steve
4 Suggested Answers
  • 244 Answers
SOURCE: I have a Bosch Steam
Your steam generator my have mineral deposits that are clogging the steam openings. One of the easiest things to do is to pour out the water and add white vinegar. Let the vinegar sit for about 2 hours. Then turn on the iron and press the steam button until the deposits are loosened and flushed by the heat and steaming vinegar. Do this on a towel or other absorbent fabric so you don't stain your ironing board. You may need to unplug the iron, let it cool and then gently **** the steam vents with a wooden skewer or toothpick.
I hope this helps you. If it does, please rate my suggestion!
Posted on Jun 02, 2011
ercupa190
  • 12223 Answers
SOURCE: My Bosch sensixx B5 automatic iron fell from the iron board, the handle opened - I tried to put it together but it's stuck to auto (it doesn't give other heat choices) and the steam button doe
download the manual instr. go to www.fitness.manualsonline.com
and proceed according for help.
God bless you
Posted on Sep 25, 2012
  • 7 Answers
SOURCE: Bosch sensixx B25L no steam
Are you sure that you have the correct settings chosen? It sounds like you have a faulty unit!
Posted on Sep 26, 2012
My iron has stopped warming up and is cold despite it flashing
Some irons shut off after a certain period as a safety measure, also there are settings for temperature. PLease double check the manual for more information:
http://www.bosch-home.co.uk/products/irons/steam-irons/TDA7060GB.html#tab4
May 23, 2016 | Irons
Bosch TDS 1445/05 Sensixx station doesn't making steam
HI!
I HAVE AN Bosch TDS 1445/05 Sensixx AND THE IRON PLADE NOT WORM AT ALL. I CHECK THE POWER.I CHANGE THE THERMOSTAT/THE CONDENSER WITH THE LAMP/.BUT STILL NOT WORK. THE BOILER WORK GOOD.PLEASE HELP ME.WHAT CAN I DO MORE. THANK YOU
Oct 06, 2012 | Irons
Bosch Sensixx B25L
see the instruction from your manual:
Check the owner's manual for your iron to learn the manufacturer's suggestions for cleaning, what water to use, and storage tips.
Soft-water systems add minerals that can harm an electric steam iron and your clothes so don't fill the iron with softened water. Instead, use filtered or distilled water.
2) if the iron does not heat a( test the power cord for open or defective b) and thermostat for adjust c) test the thermal fuse d) test the heating element for open.
God bless you
Jul 31, 2012 | Bosch Irons
No instructions with my ireon how do I descale my
Here is the link:
https://portal.bsh-partner.com/portal%28bD1kZSZjPTAwOQ==%29/PORTALFRAME.HTM
May 06, 2010 | Bosch Irons
THE IRON SEEMS TO BE WORKING FINE WHEN YOU PLUG IN BUT ITS NOT HEATING UP
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Feb 25, 2010 | Bosch TDA8340 Iron
I have a bosch iron and it needs to be calc cleaned how do i do it?
hello my name is gilles to clean your iron get yourself a bottle of clr it is a mild acid pour a litte in with water let you iron sit for 1/2hour or so then drain your iron out by turning it upside down then you should be ok thanks from gilles
Mar 15, 2009 | Bosch Irons
Irons Logo
70 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
