Question about Sennheiser DW 30 HS - Headset semi-open - wireless - DE - DW 30 HS/US
How do I change the battery in my sennheiser DW 30 HS?
Do sennheiser tr120 wireless headphone rechargeable batteries ever need changing
Yes All batteries are subject to failure and eventually need to be replaced, some last longer than others it's a manufacturing consistency problem. ...
Feb 27, 2015 | Sennheiser RS 120 Consumer Headphones
My sennheiser hdr 130 has no sound even though it has lights on its based and it is connected to my t.v. what is the cause of this problem and the solution?
This worked for me (this solution was posted on another thread). Unplug the base and take out the headset batteries. Wait 30 seconds. Reconnect. Turn on head set. I could hear immediately!
Jun 13, 2010 | Sennheiser HDR 130 Consumer Headphones
Will higher amp hour batteries damage the motor on my CTM HS-2800
Absolutely not. Higher amphour batts don't put out more voltage, just more voltage longer.
The 2800 takes U-1 gel cell batts that run about 33 amphours...good for about 12-16 miles. You might be able to fit bigger batts in it, but measure first before you buy...gel batts are pricey.
May 22, 2009 | Ctm HS-2800 Power Wheelchair
Bad battery
A replacement battery can be purchased from Sennheiser for $20.00.
Battery Part Number: BA 151
Sennheiser Link:
http://www.sennheiserusa.com/newsite/productdetail.asp?transid=004146
Dec 24, 2008 | Sennheiser HDR-45 Consumer Headphones
Bad battery for my Sennheiser HDR 45 headphone
Battery is: BA 151
Sennheiser Link:
Not charging
Did you try charging the batteries with another charger?
Mar 03, 2008 | Sennheiser RS 130 Consumer Headphones
Sennheiser RS 130 Wireless Surround Sound Headphones
Did you try to remove the batteries and at the same time unplug the power of the base for 30 sec ?
Jan 10, 2008 | Sennheiser HDR 130 Consumer Headphones
NO SOUND HDR 130
Try to remove the batteries and at the same time unplug the power of the base for at least 30 sec. then replug and reinsert the batteries. That did the trick on mine.
Dec 25, 2007 | Sennheiser HDR 130 Consumer Headphones
Sennheiser hdr 30 battery
you can check in ebay battery # ba151
Nov 17, 2007 | Audio Players & Recorders
Sennheiser DW 30 HS - Headset semi-open - wireless - DE - DW 30 HS/US Logo
192 people viewed this question
Top Sennheiser Radio Communications Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Sennheiser Radio Communication Expert? Answer questions, earn points and help others
