Question about Canon PIXMA MP160 All-In-One InkJet Printer
Ink absorber Purchase from whom, how to replace, how much. 3 easy to answer questions
You don't need to replace it. This is how to reset the Ink Aborber error:
How to clear E27 Waste ink absorber full
1.With the printer powered off but connected to a power source,
press the Power button while pressing and holding the Stop/ Reset button.
2.When the Power is lit, press the Stop/Reset button two times
while pressing and holding the Power button.
3.When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4.When the on/off lights in green, press the Stop/Reset button the
specified number of time(s) according to the function listed in the table below.
(Each time the Stop/Reset button is pressed, the LED lights alternately in orange
and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print (auto teste)
2 times Green EEPROM print (dados da EEPROM)
3 times Orange EEPROM reset (EEPROM reset)
4 times Green Waste ink counter reset (Absorvente reset)
5.Turn off the printer.( it must be turn off) then turn it on again.
Posted on Jan 22, 2009
Brother MCF-J4710DW says ink absorber almost full and won't print? Never heard of ink absorber. Where can I purchase replacement and how do I do it
Many ink-jet printers have a pad in the case to absorb the ink from cleaning cycles. Often these show "full" long before they are actually full, and you can reset the counter and continue using them. I found your answer here:
How To Reset Purge Counter on brother mfc j4710dw
Nov 02, 2014 | Brother MFC-J4710DW 35ppm 6000 x 1200 dpi...
How do I empty an ink absorber that is almost full?
The answer is that you don't empty it. Ink absorber or over flow tanks are not usually emptied. They are replaced. The removal process is different for each manufacturer and/or model printer. You didn't say anything about the model and make or I could be more specific.
Contact the maker of the printer, check the price for a replacement ink absorber or over flow tank and they will give you instructions on removal and disposal of the full tank. Depending on what printer you have, it may be more practical and less expensive to purchase a new one instead.
Jun 04, 2011 | Office Equipment & Supplies
What is the ink absorber. a message keeps coming up to say it needs emmptying
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
If you feel your product might require service, Canon has excellent service options and we are eager to provide any assistance you may need. Click the link below to locate an authorized service facility and obtain further instructions.
Find a Service Location
If you still have questions about the issue you are experiencing, a Technical Support Representative will be happy to answer any question you may have. You can contact us through the email link or phone numbers listed below. Regards,
Jan 14, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
Waste ink holder is almost full. Where is it and what does one do with it?
Here is what Canon says on their website:
Ink Absorber Replacement Options This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Hope this answers your question.
Jan 07, 2011 | Canon S900 InkJet Printer
I cannot print the error message is waste ink absorber is full
Ink Absorber Replacement Options This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
If you feel your product might require service, a Technical Support Representative will be happy to answer any questions you may have and explain the service options available to you. You can contact us through the email link or phone numbers listed below.
  • Obtain Support by Email
  • For toll-free technical support, please call 1 (800) 828-4040 begin_of_the_skype_highlighting 1 (800) 828-4040 end_of_the_skype_highlighting during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. EST, excluding holidays).
  • Toll-free TDD Support Line for the Hearing Impaired is available Monday - Saturday (excluding holidays) at 1-866-251-3752 begin_of_the_skype_highlighting 1-866-251-3752 end_of_the_skype_highlighting
  • Technical Support is available for Customers in Canada at 1-800-OK-CANON begin_of_the_skype_highlighting 1-800-OK-CANON end_of_the_skype_highlighting
If your printer is no longer under warranty :
  • For toll-free technical support, please call 1 (800) 828-4040 begin_of_the_skype_highlighting 1 (800) 828-4040 end_of_the_skype_highlighting during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. EST, excluding holidays). Pay for support is required on all units outside their original warranty, unless covered by a Canon Extended Service Plan. The charge will be $9.99. If it is determined that there is a hardware failure, you have the option to purchase a new or refurbished product from our current product line, which includes units with Canon?s new ChromaLife inks, PIXMA Technology, a limited manufacturer?s warranty, free next business day shipping and discounted pricing. If you elect to take this option, the pay for support charge will be canceled.
Nov 25, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
How do i trouble shoot waste ink absorber full in a canon pixma ip1600
Solution: Ink Absorber Replacement Options iP1600
  • For toll-free technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. EST, excluding holidays).
  • For toll-free technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. EST, excluding holidays). Pay for support is required on all units outside their original warranty, unless covered by a Canon Extended Service Plan. The charge will be $9.99. If it is determined that there is a hardware failure, you have the option to purchase a new or refurbished product from our current product line, which includes units with Canon?s new ChromaLife inks, PIXMA Technology, a limited manufacturer?s warranty, free next business day shipping and discounted pricing. If you elect to take this option, the pay for support charge will be canceled.
Oct 07, 2009 | Canon PIXMA iP1600 Printer
Empty waste ink absorber IP4000
I found this at the Canon website. www.canon.com
I also have a Canon Pixma, seems my turn is up and coming too.
Aug 25, 2009 | Office Equipment & Supplies
Waste ink absorber canon mp130
Hi. It happens when there is some problem with the cartridges tank, either full or not seated properly. I found that Canon recommends following methods (directly from canon) to fix it.
Method 1:
Reset the device when it is not functioning properly.
If the device is not functioning properly or to clear memory, reset it.
1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the <ON/OFF> button again.
3. Wait until the device has completed its cycling process before submitting another job request.
Method 2:
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible. Press the <OK> button to release the error. You will still be able to print for a short period. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
* Obtain Support by Email
* For toll-free technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. EST, excluding holidays).
* There will be a pay for support charge if your product is out of warranty (see next section, below).
* Toll-free TDD Support Line for the Hearing Impaired is available Monday - Saturday (excluding holidays) at 1-866-251-3752
* Technical Support is available for Customers in Canada at 1-800-OK-CANON
* For technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 8:00 a.m. - 12:00 midnight. EST, Saturday 10:00 a.m. - 8:00 p.m., excluding holidays). Pay for support is required on all units outside their original warranty, unless covered by a Canon Extended Service Plan. The charge will be $9.99. If it is determined that the problem you are experiencing is due to a failure of the printer's hardware, the pay for support charge will be canceled. If your out of warranty printer is determined to have a hardware problem, you have the option to purchase, at discounted pricing and free next business day shipping , a new or refurbished product from our current product line, which includes units with Canon?s new ChromaLife inks, PIXMA Technology, and a limited manufacturer?s warranty.
Aug 01, 2009 | Canon PIXMA MP130 All-In-One InkJet...
I9950 Canon printer with message 'Waste ink absorber almost full.
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power
button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power
button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release the Power
and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights
alternately in orange and green, starting with orange.)
4) 4) When the LED lights in green, press the Resume/Cancel button 4 times to reset 'Waste ink absorber'.
5) Press the Power button to execute.
Jan 21, 2009 | Canon BubbleJet i9950 InkJet Photo Printer
Ask
Sep 16, 2008 | Canon PIXMA iP1600 Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
232 people viewed this question
old marine
old marine
