Question about Garden
Runs fine but chain wont turn. clutch spins but when you pull the trigger it tries to die out.
  • 169 Answers
The fuel system is clogged,,,,,,,need the carb rebuilt or fuel inlet restriction fixed
Posted on Jan 16, 2013
SOURCE: mccullough chain saw pm610 chain slips -- maybe clutch issue
I just had this problem. It is possible that your chain drive teeth have jumped off the drive sprocket. There is a guide for the chain to follow and is decievingly difficult to verify that the teeth are in the drive sprocket. Turn the saw upside down, and look at the clutch. Check the chain to see if the chain is actually on the sprocket and not beside it. It looks right, but it's not.
Posted on Jan 12, 2009
bbenson6
  • 13 Answers
SOURCE: chain wont turn when running
Check the tensioner screw, it could be too tight. Loosen the slack and the chain should move. And of course do this while its off.
Posted on Jul 19, 2009
lindsay836
  • 677 Answers
SOURCE: chain doesn't move / clutch
Starts then.... you hit the trigger... ba ba ba .... dies ?
Check fuel filter in tank, make sure air cleaner is clean.
Make sur your mix is correct.
Posted on Feb 05, 2010
dontbother10
  • 2220 Answers
SOURCE: Clutch slipping?
These are related. On your saw the oiler only supplies oil when the clutch turns, and I am going to ignore the oil problem. If it does not oil after clutch replacement please post back. The oil pump is inboard behind the clutch Please inspect it and the worm gear before reassembly.
A link to an "IPL, 455 Rancher, 455 e, 460, 2009-10, Chain Saw" follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/HIUS/HIUS2009/HIUS2009_70.pdf
The clutch face is on item 1. Inspect the drum (item 3) for glazing. If extreme it may require replacement too. There is also a bearing (item 4) that might effect both problems I suggest you replace it as part of the clutch repair. These parts may be available at your local Husky dealer, if so it will save time and shipping cost. Showing him your parts might be a good idea too.
This is helpful with clutch removal.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make certain the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
If the link I provided is not your saw you can find yours here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 02, 2010
  • 4088 Answers
SOURCE: wont stay running. it idles kinda high. stays
Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other problems. The idle speed screw (turned CCW) will slow the engine down. Hope this helps!
Posted on Nov 08, 2010
I have a Remington electric versa saw rm1635w and the chain won't spin around the bar what do I need to get it running again
there is a safety clutch that you disengage when finishing the cut
it disengages the chain from the motor drive by a dog clutch
pull the safety bar back towards the trigger and the chain will cut
if you leave the finger on the trigger and the chain jams in the cut , you push the bar forward and the motor spins free
if that doesn't work take it in for a fix as that clutch is failed
Nov 16, 2016 | Remington Garden
WEN 6014: Motor is running, but chain doesn't move. Chain sprocket seems fine, cogs are only slightly worn, sprocket fits perfectly, no wear. Is there an internal clutch or connector? Motor worn out?
There is a clutch behind the metal housing where the chain sprocket at the engine end attaches to the chain . There are wear parts with springs on them that have to be changed. ChainSaw Shed Chain Saw Parts for Wen Wagner Brand Chain Saws Chains Bars... You can get parts here.
Sep 15, 2016 | Garden
Chain will not stop spinning on the Poulan Pro 42 cc 18 inch chainsaw, will cut wood with out pulling trigger. Runs is very vast, dies when pull trigger.
I would say it has an air leak, through a gasket or crank seal, make sure the carb is tight and sealing properly.
Jun 15, 2011 | Poulan Garden
Wont stay running. it idles kinda high. stays running with the choke on. pull the trigger 2 giv it gas it dies.
Nov 08, 2010 | Poulan Pro Chain Saw 46cc 20"
I have a Makita DCS640120 Commercial Grade 20Inch 64cc and when i turn it on the chain automatically moves how do i fix it to where it will idle till i press the trigger?
Turn the idle speed screw CCW till the chain stops turning at idle, but the engine continues to run. Make sure the carburetor fasteners are tight. Remove the chain cover, bar, and chain. Spin the outer drum of the clutch to check the bearing which lies between the drum and internal components. If it doesn't spin freely, try oiling the drum bearing area and work it into the bearing. If no help, plan on replacing the clutch mechanism. Hope some of this helps!
Jul 12, 2010 | Makita DCS640120 Commercial Grade 20Inch...
Chain doesn't move / clutch
Feb 04, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Stihl Farmboss - cord will not move
try taking plug out to see if it turns then.if not take off pull cord assembley to see if something has come loose and jammed flywheel, failing that could possibly have snapped the piston ring and jammed. oh yes one last thing check clutch if you have chain brake on and clutch is jammed obviously wont turn.
Dec 21, 2009 | Garden
Chain wont turn when running
Jul 19, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Fly wheel seemds locked up on Husqvarna 445
the flywheel does not have a brake,the clutch side has the break.if you have the chain side cover off the brake is no longer on the clutch drum.the fly wheel is on the oppiset side (starter rewind).take the starter rewind off and see if the motor will turn.if hte motor turns the problem is in the clutch side.if it doesn't the problem is in the flywheel side.the ignition coil has been known to loosen up.the screws streitch out from heat.check the air gap between the flywheel magnets and the ignition coil.should be .10 to .12 inches.if problem is on clutch side check to make sure that the springs are on between the clutch discs.they have been known to break and that does not let the chain spin on bar.any questions get me an e mail
Jan 27, 2009 | Husqvarna 450 e-series 18" Chain Saw
Mccullough chain saw pm610 chain slips -- maybe clutch issue
have you greased your clutch bearing ever.some times they get dirty and tighten up after running a while.pull your clutch off and clean and grease bearing with a little alex grease,and I mean just a few drops.not meant to have a lot of it,too much will burn the crank shaft and you will have more problems then you started with
Jan 01, 2009 | Garden
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
