Question about Kenmore Dehumidifiers
Model 5641 Kenmore Doesn't run; needs resetting?
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Kenmore model 580.54351800 ices up
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Posted on Sep 14, 2011
Kenmore dehumidifier compressor on but doesn't collect water
clean the condenser in the front or the filter if it has one. no air flow to cool it down will result in overheating and no condensation collection across the evaporator coil.
May 09, 2012 | Kenmore Dehumidifiers
Model # 5641 dehumifier- how do you remove the cover to oil the fan?
Pull the humidistat dial off. Remove two screws on the bottom of the front panel. Pull the panel off from the bottom. There are two tabs on the top that will come out when the panel is rotated approximately 45 degrees. There are two oil ports on the top of the motor. Reverse the process to rerassemble the dehumidifier.
Sep 24, 2011 | Kenmore 54501 Dehumidifier
KENMORE DEHUMDIFIER MODEL 580.51300100 DOES NOT RUN, NO POWER LIGHT AND NO FAN RUNNING ETC
First, check the source of the power to the unit, Has a circuit breaker in your home's circuit breaker panel been tripped? If so, unplug the unit, before resetting the circuit breaker. If that's not the case, check the outlet it's plugged into. It may be damaged or have a loose wiring connection. Be sure to turn the circuit breaker for that receptacle OFF, before removing the cover plate.
If all of the above checks out OK, check the water collection bucket, as it may need to be emptied and/or the bucket was not reinstalled properly or the float valve in the top of the bucket is stuck in the UP position, If so, jiggle the arm of the float valve to get to return to the DOWN position.
When reinstalling the bucket, be sure that it fits "squarely" into it's holder and makes firm contact with the bucket safety removal switch.
I hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Sep 13, 2011 | Kenmore 54501 Dehumidifier
Kenmore model 580.54351800 ices up quickly, doesn't defrost, and as a result doesn't dehumidify. Bad thermistor?
heatman101
Sep 12, 2011 | Kenmore 54701 Dehumidifier
Our model JA2M193N Edison dehumidifier runs but doesn't produce water, the coils get cold, but the fan doesn't come on. What do we need to do to fix it?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 14, 2011 | Edison 40 Pint Dehumidifier
My dehumidifier stopped working. What can I do?
Please explain what you mean by "My dehumidifier stopped working." It's a pretty broad term, which doesn't help in knowing which direction to go with helping you. Also knowing the brand and model number of your dehumidifier is extremely helpful. Thanks
Jul 14, 2011 | Kenmore Dehumidifiers
My dehumidifier runs, but doesn't collect water...then shuts off
heatman101
Jun 06, 2011 | Kenmore Dehumidifiers
Compressor seems to be overheating although top is cool. Continues to run but doesn't collect water. Fan is working. Can't locate model number.
If the compressor motor is overheating, it's usually a result of low refrigerant gas in the cooling coils. Recharging is an option, if you can find a shop that will do it.
May 22, 2011 | Kenmore 54501 Dehumidifier
Dehumidifier wont turn on or reset. code comes up as F2 and wont reset. Cleaned off filter. no help. any ideas you have would be appreciated.Just bought it last year. we have the hose connected to a...
To figure out what Code F2 is, I took a look at the Owners Manual for the Model # AD70USS, Strangely, the Owners Manual doesn't list an F2 Code or any codes for that matter. Because that model number humidifier, does not have an LED screen.
Never the less, to reset your unit using an alternate method. Turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet. Wait 12 - 15 minutes before plugging it back in. Then turn the Master ON/OFF Switch to ON and the dehumidifier should have reset itself. If it doesn't check the positioning of the water bucket, to make sure it's contacting the safety switch. Eventhough, you're using a drain home, it's still important.
Hope this helps you solve the problem.
May 08, 2011 | Whirlpool AD70USS Dehumidifier
Dehumidifier model#5641 fan seems to not operate but frees up after a long period of time. Then works ok. But freezes up again
I just picked up a used one for $5...fan didnt work,,took it apart,,two places to add oil to fan,, Very very small holes,,one is toward the back if the fan cover and one is on the front,,right behind the blades..Hope this helps..Its running great now,, :) What a deal!!!
May 24, 2010 | Kenmore 54501 Dehumidifier
Dehumidifiers Logo
65 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
