My tv starts making a distorted picture then turns off about every 15 minutes
    Scholar:
  • 52 Answers
What type Flat Panel TV is this? LCD? Plasma? Rear projection? This information would go a long way towards determining the probable cause.
However, a first diagnosis is that there is apparently a circuit overheating.
I've found that on some of the lower cost brands, the manufacturer does not test them well enough to cover all climates, or long enough to determine weak circuit design flaws. Unfortunately, it usually means a trip to the repair shop, which these days can be a high percentage of the replacement TV cost.
If you are willing to try, and can be CAREFUL, you can open it, clean out any accumulated dust/dirt (which can exacerbate overheating), possibly check (unplug/replug/wiggle) all connections between boards/modules. This may clean a dirty contact if it's gotten a tiny bit corroded or dirty (usually on older sets, or high humidity or high smoke environments)
WARNING - the power supply in any TV set will retain dangerous voltages even after unplugging. I'd recommend to unplug it, wait no less than 24 hours before delving inside it.
Never attempt to supply AC power to a set that has the back cover off... lethal voltages ARE present during operation, yes even in LCD TV's.
Posted on Jan 12, 2013
abhishek33
  • 1239 Answers
SOURCE: My 42 inch plasma has black distorted picture
hi
its cathode ray tube problem or the colour wheel...check that both please.....
thank u,,,,,,
Posted on Mar 07, 2009
  • 122 Answers
SOURCE: 40 samsung lcd picture problem
first check the power supply board for puffy capacitors. then change the t-con board on lcd panel
Posted on Mar 09, 2010
milkburp
  • 416 Answers
SOURCE: Picture issue on start up
T-Con PCB. It is attached to the panel, under a metal shield. The LVDS ribbon cable runs to it from the Main PCB. It can be purchased separately for this model. For version SS03, the PN is: BN81-01312A
Posted on Mar 15, 2010
  • 3 Answers
SOURCE: I get three horizontal lines and picture is
Hi, How are the lines positioned? are they equally spaced creating four equal sections or are they close to each other?
Jack
Posted on Oct 19, 2010
SOURCE: i have a 46 inch polaroid lcd tv that when you
my 46'' inch tv polaroid lcd has been working fine for 3 years. today my wife and I noticed the tv is shutting off the screen will go black and the power light does switch to red. you can here something inside the t.v clicking but you can turn it on and it will start back fine for 20 minutes then shut off again? Does anybody know whats going out on the tv? let me know
Posted on Dec 06, 2010
After about 30-60 minutes TV starts to hum and picture gets distorted, could this be the color wheel...???
Sounds like a sync problem due to color wheel speed. clean and lubricate color wheel motor with tiny amount of Z-Max lubricant (liquid Buckey balls, available at Wal-Mart), on each bearing. make sure wheel is free-wheeling and turns easily. Should cure problem. If the color wheel is in good shape, there is a power supply problem, which may be due to dried out electrolytic capacitors or a regulator that's failing. Troubleshooting or controller board replacement may be needed. Regards.
Dec 07, 2015 | Mitsubishi WD-73840 73" 3D Home Cinema...
Mar 15, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
Distorted color on hdmi output
If you haven't already stumbled across the fix: I just had the exact same problem after about eights months of casual use. Unplugging the DVD player for about 15 minutes and then plugging it back in "solved" the problem. Until next time it happens, anyway.
Apr 17, 2009 | Philips DVP5990 DVD Player
Sony KV-32XB25 Distorted Picture
In most of the case, the problem is a defective LCD panel, if is it, there is not worth to fix.
Aug 02, 2017 | Sony KV-32XBR250 TV
Sep 01, 2008 | Samsung Televison & Video
Distorted Picture
the hyper module is defective needs to be repaired or replaced.
Aug 03, 2008 | Televison & Video
DIstorted picture for 480p input only
Many set have two differant convergance settings one for 480 and one for1080 this is because when it changes mode the set runns a differant frequencys, what may have happened is you have a cold solder joint somewhere that takes this fifteen minutes to corect itself, might want to start by resoldering the convergance and high voltage curcuits
Jan 02, 2008 | Toshiba 57H81 57" Rear Projection...
Video distortion
unplug the tv before you go to work or for a couple of hours then plug it back in and let the tv warm up for 15 minutes and adjust the covergence
Dec 11, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
