Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Whirlpoo refridgerator question
I have a Whirlpool top-mount fridge, model ER8YHMXSL00
Mfg 5/06
The bottom shelf area continually freeze the items up, even set at "one" on the dial.
Suggestions?
  • 1 more comment
  • Toyota Ed Jan 26, 2009
    Everything freezes in the lower shelves.
  • peyton thompson
    peyton thompson May 11, 2010
    is it just the bottom shelf or are you having problems with everything freezing ie: milk, eggs, veggies?
  • Dan Harris
    Dan Harris May 11, 2010
    Fridges really aren't my expertise. It takes special training to work on a fridge due to the freon and I didn't ever do that training. Best bet would be to just submit the question to the help area and see who can help you there. If you need any help on a washer or dryer or even a dishwasher let me know and I would be glad to help. Good luck and sorry I couldn't be of more help to you.
  • 410 Answers
If it frrezes up even with the control set to 1 then you have a bad temperature control. the t-stat is loacted in the control housing in the refrigerator section. this housing is usually held in place by 1 screw near the front then swings down for access. you can get pt#2201754 from sears or a local appliance parts house in your area. just 2 wires so its not hard to do.
sorry it took so long to get back to ya. good luck peyton
Posted on Jan 27, 2009
Problem with varying temperature.
Sounds like an air-flow problem, are the fans running? Damper door open? Model #?
May 26, 2016 | Hotpoint RLFM171P White 342 l Fridge A...
Why is the top shelf of whirlpool upright freezer not freezing?
Just had this issue. Freezer is packed usually & suspected airflow. Emptied bottom 2 shelves & vent strip was solid frost. Bottom 2 shelves were filled w/ solid roasts & other solid large items. Used blowdryer & currently waiting to see if it begins freezing top shelf.
Jul 03, 2014 | Whirlpool EV160NZTQ Upright Freezer 16 cu...
Ge tfx25jrbb-ww refridgerator not cooling
The first thing to check is if you can hear the fan running inside the freezer. This not only keeps the whole freezer cold it alspo circulates air down to the refrigerator keeping it cool as well.
May 28, 2012 | GE Refrigerators
We just purchased this model, and the items in our refridgerator keep freezing, including the milk in the door. We have turned down the setting to 2 and it keeps occuring, is this common? Mostly things...
I've actually ran inti this problem alot. its just a design flaw. the objects that are freezing are close to the direct flow of cold air coming from the freezer into the fresh food compartment. adjusting the temperature will result in the same condition. The only thing you can do is rearrange products closest to the air duct. You may even gave to rearrange the shelves. Just ran into this same problem yesterday when i was dispatched to a customers home. Its just a stupid flaw in the design of the fridge.
Feb 08, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Ed22pwxxn00 setting on 3 top shelf items freeze. Is our 18 yr old fridge going out?
Adjust the freezer damper to a higher number to reduce cold air flow to the fridge section. This will eliminate freezing in the fresh food section.
Aug 29, 2009 | Whirlpool Refrigerators
Bottom of freezeer and fridge are cold, but top areas aren't?
you have defrost problem or check see if condenser fan working
Apr 07, 2009 | GE Refrigerators
Item in fridge freeze at the bottom, but barely cool at the top
has the cold air circ fan stopped or jammed? this will allow the cold air to drop to the bottom and not circulate.
Mar 16, 2009 | GE Profile PSW26P Stainless Steel Side by...
Whirlpool refridgerator issue
YOU FIRST SOLUTION TO THE DRAIN HOLE FREEZING UP YOU NEED TO GET A TECHNICIAN TO HAVE A LOOK AND REPAIR IT,IT WILL BE BEST IF HE INSTALLS A PAD HEATER TO KEEP THE DRIP TRAY FROM ICING UP.YOUR SECOND PROBLEM YOU NEED TO SEE IF THE DRAIN HOLE IN THE FRIDGE SECTION IS NOT BLOCKED WITH ANYTHING IF SO HAVE IT CLEANED AND POUR SOME HOT WATER DOWN TO WASH OUT WAT IS IN THE DRAIN PIPE.GOOD LUCK.MOHAMED
Aug 20, 2008 | Whirlpool ED2FHEXN Side by Side...
clear ice,clear drain, all the way to the drip pan, and tilt unit slightly to the rear
Apr 22, 2008 | LG LFC25760 French Door Refrigerator
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
391 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
