Question about Garden
Do you have instructions and/or a video showing how to replace the sprocket and clutch assembly on a Echo CS 310 chain Saw
  • 169 Answers
Not on an echo but they are pretty much all the same.....go check out my youtube channel and look up clutch themowermedic1 on yt
Posted on Jan 16, 2013
Loringh
  • 185 Answers
SOURCE: Chain saw starts with starting fluid only but will not run.
Hi lwhssh:
Suggest you drain the fresh gas/oil and add a fresh batch but first add a gas stabilizer to your batch of gas/oil in the storage container. You will probably still need to use starting fluid for a few times When 2 cycle engines sit for a long period of time, the gas/oil mixture undergoes a change and tends to leave a residue on the delicate parts of the carb. The gas stabilizer will help that.
I always do the following for 2 cycle engines when I put them up for the winter. Empty the gas container on the device and then start it to use up any gas left in the fuel lines and carb. this keeps any residue from forming.
Hope this helps Good luck Loringh PS please leave a rating if appropriate. Thanks
Posted on Nov 29, 2008
SOURCE: I have an Echo CS-440
when it threw the chain it may have damaged the guide teeth on the under side of the chain remove chain and file the guide teeth this as happened to me with 440 i have used many saws over the years and the 440 is the only that has ever done this
Posted on Jan 23, 2009
  • 14 Answers
SOURCE: How do you replace the chain drive sprocket on an
you need to replace the clutch, you woould pull the side cover off and remove the bar and chain. then you remove the nut holing the clutch on( the clutch and sprocket should be on piece) take it to your local saw shop and grab a naw one.
Posted on Mar 20, 2009
dontbother10
  • 2220 Answers
SOURCE: How do I change the primer bulb on my Echo CS-3000
The IPL for an Echo CS-3000 is here:
http://www.echo-usa.com/pdf/documentation/CS3000T1T1E_081303.pdf
See page 8. There is no shop manual offered, you will need to interpret the pictures. Didn't look to difficult. GL
Lou
Posted on Sep 07, 2009
Testimonial: "Having the parts list helped me to understand how the primer bulb was installed. A great help. Thanks, Ed"
  • 4088 Answers
SOURCE: Chain brake jammed on Echo CS400 chainsaw
You will need to release the brake by applying a very heavy screwdriver to the + shaped part of the brake coupling. Check the action of the brake handle and duplicate it at the the +. Hope this helps!
Posted on Jun 26, 2010
How to replace clutch spring on a echo 650 chain saw?
id replace the entire clutch as if spring came out then therese got to be a reason
Mar 01, 2015 | Echo Cs-650evl Cs 650evl Chain Saw...
How to reassemble chain brake on an Echo CS-350T that jammed and was pulled apart by someone else?
From what I see you will need assemble thing leaving the main spring and brake cover off. Before attempting to put the main back in install a clutch drum inside the brake band. Then you slip on the main spring and pry the end on with a flat blade screw driver. Now install in the cover for the spring and brake. Reset the chain brake and remove the drum.
Now install the chain brake on the saw and test. Do not trip the chain brake without the clutch drum in place. If these are anything like the Husqvarna version after they get worn they will get where it is nearly impossible to reset.
Echo CS 350T Chainsaw CS350T Parts Diagram Page 7
Jan 12, 2015 | Echo Garden
Brand new Echo cs-400 chain saw: The chain spins fast on idle. Should'nt the chain be stationary on idle?
The manual is available here:
http://safemanuals.com/user-guide-instructions-owner-manual/ECHO/CS-400-_E
The idle speed of the negine may be too high.
Page 26 of the manual gives instructions for adjusting the speed with the "T" screw on the carburettor.
May 12, 2011 | Echo CS400 18" Chain Saw
Chainbrake spring broke need new one
Parts Catalogs Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04511001001 - C04511999999 Language: English Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04612001001 - C04612999999 Language: English Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04713001001 - C04713999999 Language: English
Jan 05, 2011 | Echo CS310 14" Bar Length Fully Assembled...
Echo cs-310....how to put chain on after it became lose....also how to tighen when it becomes loose.
At the right side take out the panel that hide the bolt that has a large groove.When unbolt move froward the chain holder and tight the bolt but not too tight just go further until you can test it by hand making the chain to move freely but stable.Reverse the procedure.
Post / thumbs / testimonial are welcome!
Nov 12, 2010 | Echo CS310 14" Bar Length Fully Assembled...
How do i replace sprocket on echo 370
They have this on the ECHO website. Go to the FAQ page here: http://www.echo-usa.com/faqs/
You can find it by typing in 237. That's the ID # of the answer. Or you can just type in sprocket.
Jul 23, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
How to install bar and chain on cs 310 echo
A CS-310 OM follows:
http://www.echo-usa.com/pdf/documentation/CS310es1112_042310.pdf
There is a very good, model specific, procedure beginning on page 12.
There are 2 listed based on serial number I think, you can download the other and an IPL here:
EchoUSA
http://www.echo-usa.com/documentation.asp
If your saw is not listed type "CS" in the “Model:” window, click "Search" and select your saw from the list provided.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 21, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
How do you replace the chain drive sprocket on an Echo CS-440?
Mar 18, 2009 | Garden
Garden Logo
102 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
