Question about Whirlpool Washing Machines
I am attempting to repair my uploader whirlpool washer, I have removed the drum, however I hear lot of water inside the drum still, what should I do? is it normal?
The washer was stopping its cycle on OL alarm, my drain pump seems ok, bearings also seem ok, I cleaned the drain filter, I am ready to put the machine together, but all that water remained in the drum is questionable.
    Sergeant:
  • 291 Answers
Yes that is normal. That is your balance ring. It's an ingenious device that acts as a counterweight to keep the tub balanced. All is good.
Posted on Jan 12, 2013
  • Mando Jan 12, 2013
    Thanks, I will post the result later on. Thanks again.
jsrock516
  • 5911 Answers
SOURCE: washer will not drain, seems to be plugged
Try using a wet/dry shop vac and see if you can pull water through the drain hose in the back. If you can, duct tape the vacuum nozzle to the drain hose to make a good seal. With the vacuum on, watch the drain hose under the tub. If it collapses, you have a clog somewhere. It may be easier to remove the hoses from the pump, first to see if there is anything stuck in the impeller. It doesn't take much to restrict water flow. If you need to remove the hose from the bottom of the tub, try to get as much water out using the method I mentioned. It may be slow, but as long as it can pull water, try to drain. This will save you from a big mess later. If there is a clog in the hose, all that water will gush out with the hose disconnected. You may want to have a few towels handy. Now...in some models there is a plastic ball valve in the drain hose connected under the tub. This needs to stay there, but may also be jammed with crud. Sand and dirt is notorious for clogging at this point in the drain system. This hose should come off with a simple clamp tightened with a screw. If you go through all the effort and find the lines clear, you may have a failed drain pump.
Posted on Aug 10, 2007
Amigaman
  • 248 Answers
SOURCE: Washer will not drain properly.
The splashing you hear is a liquid thats in the balance ring. This is located at the front edge of the inner tub that you spun by hand. It helps balance the loads. This is normal. The smell is a problem inherent to front loaders. About once a month run hot water wash with a cup of bleach in it, no clothes. Best bet is to leave door open to allow air to dry interior. I removed bulb in mine.
Posted on Oct 06, 2007
aborcass
  • 2651 Answers
SOURCE: Our Whirlpool washer won't drain
this machine has the pump directly atached to the pump assy, so if the motor is runnning your pump will drain water. more likely is that when you put the unit back together perhaps you didnt plug the lid switch assembly bak in. if there is no lid switch detected the unit will not drain or spin and when it gets to that mode it will simply stall out. no noise or anything. will fill, agitate but not spin and/or drain/ check the lid switch!
Posted on Nov 11, 2008
SOURCE: Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
Posted on Mar 01, 2009
  • 3 Answers
SOURCE: Whirlpool Duet GHW9150PW0 water in drum, stinky cloths
I read this in some guys blog, he was having the same problem with his Duet and said that adding water to each cycle solved the problem without having to use any chemicals. He's working on an easier way to do this, his solution was quite complex but he did post a solution that someone sent him that seemed to work and may work for you. I'll attach the "URL" for his site. Hope this will help.
http://whirlpool-dueling-with-duet.blogspot.com/
Posted on Mar 05, 2009
The drum seems loose. When it spins to let the water out it will spin good then all of a sudden it will bump loudly
Search Results
    How to Diagnose Drum Problems in a Washing Machine ...
    ? 7:48
    https://www.youtube.com/watch?v=wUL5Wb1T71c
    Nov 19, 2013 - Uploaded by eSpares
    For all your washing machine spare parts go to http://bit.ly/1DumBrv The most common fault in a washing ...
    GE Washer Top Loader Out of Balance Shaking Repair ...
    ? 14:19
    https://www.youtube.com/watch?v=GA98ZmnzEfc
    Jul 12, 2014 - Uploaded by Mike Davies
    GE Washer that Shakes and is Load during Spin Cycle. step by step ... Washer Tub Seal Replacement - GE Top Load Washing Machine ...
    GE Front Load Washer Inside Drum Loose - YouTube
    ? 0:46
    https://www.youtube.com/watch?v=P8EcTTL2lcI
    Apr 4, 2013 - Uploaded by Wayne Meador
    I need help with my GE Front Load Washing Machine!!!! If you or anybody that you know can help me fix this, I ...
    Kenmore top-load clothes washer drum/tub is loose and bangin
Jan 08, 2016 | Washing Machines
Hi my whirlpool doesent speen
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will notturn - 11068202794. ApplianceVideo.com ...
Kenmore / Whirlpool Washer Not Spinning 1 - YouTube
? 11:33
https://www.youtube.com/watch?v=TB_W6sPdzkM
Jul 10, 2012 - Uploaded by Bill Newberry
Kenmore / Whirlpool Washer Not Spinning 1. Bill Newberry ... Washer will not spin the clothes dry ... Now ..
Dec 03, 2015 | Whirlpool Dryers
Washer won't drain or spin.
What to do when your washer won't spin or drain water ...
? 2:23
https://www.youtube.com/watch?v=oFB1jEdXVsQ
Jun 20, 2012 - Uploaded by searspartsdirect
What to do when your washer won't spin or drain water ...Washer Repair - Not draining or spinning ...
Maytag, Whirlpool & Roper Washer Diagnostic - Water Does ...
? 6:33
www.youtube.com/watch?v=diRuMkf9_Vs
Sep 12, 2013 - Uploaded by ApplianceVideo.com
Fix your own Maytag Top Load Washer which has some of the following ... Troubleshooting Why the Washer ..
Oct 31, 2015 | Maytag MHWE450WW - Performance Series HE...
How to remove Frigidaire water vane?
Good Morning Friend,
I understand you want to know how to remove the water vane on your Frigidaire Affinity washer, model# FAFW3801LW. I see that there is possibly a penny inside the vane that you can hear an feel as the drum rotates. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your particular appliance, and should be able to take the vane off and remove the penny with ease. Hope this is helpful.
-Best Regards-
WP
Jun 27, 2014 | Frigidaire Affinity FAFW3801LW 27"...
Whirlpool duet washer door will not unlock or complete the cycle
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
  • Oct 13, 2011 | Whirlpool Washing Machines
    Brand new Whirlpool WTW4800XQ out of box . Set up plugged in , loaded load pushed start lid locked hummed lid lock started flashing. waited till lid lock went off Still nothing
    Before you attempt to do anything please check if the drum lock is removed, check the power plug, connect the water line inlet. and finally check the settings of the program.
    Read through the manual and DO NOT ATTEMPT TO DO ANY REPAIR AS BEING A NEW SET you have warranty.
    Call your dealer if the set hums even after the initial checks were done.
    Aug 04, 2011 | Whirlpool WTW4800XQ Washer
    Even after removing and cleaning the filter in the whirlpool elite washer, I still hear a coin like rattling sound, also the water is not draining properly. What's my next step? Mike
    check the drum veins you may need to remove the top of the dryer or lift the lid to get at the screws to the drum veins. remove each one clean them out and this should solve your problem
    Feb 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    I have a whirlpool duet. I had washed 8 towels 2
    To get inside the machine for a look, you have to take the back panel off,
    1. Pull the plug
    2. Turn off and then Disconnect the HOT and COLD water hoses at the machine
    3. Remove bottom, side and all but 2 top corner screws from the back panel (all around the outer edges only) then supporting the panel, remove one corner screw, let the panel down on that side, then remove the other.
    4.Remove panel
    5. Grab a light, look inside.
    My guess is that the spinning, wobbling drum worre a hose thru.
    Good Luck!
    Hint: Put all the back panel screws in loose, all the way around... then tighten them
    Mar 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Stale water in whirlpool duet front loading washer cannot see water but can hear it if you move the inside of drum
    Saw in my local newspaper... Whirlpool won't tell you to maintain by unplugging the machine and removing the front bottom cover of washer (3 screws) ...you will see a valve cover in the center right in front of you....Get towels ready to soak up the water that will spill out when you open this. Remove it and clean the plastic filter and any debris you might see inside then put back together. It worked and wasn't hard to do but now I have other issues with the machine errors and such....I think I'll go back to the old washers minus the electronics.
    Mar 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Stinky washer
    I have the same problem. The solution is to use bleach with your whites. It's better to use a normal amount of bleach frequently rather than a lot of bleach only once in a while.
    Oct 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Washing Machines Logo
    41 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
