Question about Microsoft Windows XP Professional for PC
STOP:0X000000ED (0X8B7F2590,0XC0000006,0X....) The blue screen. No boot.No safe mode etc. I just installed Yamaha software.
  • wildbillko Jan 22, 2009
    wbko again can anyone pin the error message numbers? Do you think a reboot disc will work? Yes I did read that ms post but does not help much since all worked before download but thank you.
  • seanjamesnaz Apr 10, 2011
    how cant i install microsoft XP Pro Pull version 64 kb because i delete my microsoft Xp Pro Pull version 64kb i dont have a disc of that where i do go a web site of the microsoft Xp pro pull version 64 kb and the full version of that
    Brigadier General:
  • 5,158 Answers
Have a read of this
http://support.microsoft.com/kb/297185
Robert
Posted on Jan 22, 2009
UN MOUNTABLE BOOT VOLUME ERROR - BLUE SCREEN on a dell latitude D505 laptop
try to boot to safe mode using F8 key on boot and then recover system or reinstall OS
Nov 13, 2012 | Dell Latitude D505 Notebook
0f00:065d
Blue Screen Of Death
  • You may need to roll back system with System Restore (press F8 during boot and choose safe mode). Start > Search type System Restore. Now choose a date prior to problem. You may have to try a few dates.
  • Uninstall last program(s) that was installed, again in safe mode.
  • Re-install Windows. Clean install works best.
  • Test one DIMM at time. One slot at a time. To eliminate possible bad RAM.
  • Lastly you may have other hardware problems. If it does another blue screen after reloading windows, especially with a clean install.
Oct 03, 2012 | Dell Inspiron Mini 10 Notebook
I'm getting a blue screen
What was the last thing you did before it happened??? installed a driver??? installed a software???, add a device??? this would help a lot to know...10000 things can make Windoze go in a blue screen... bad device, bad driver, corrupted MBR, bad software, bad memory, etc... try booting in safe mode to see if it works, if it does than it's a bad driver or software recently installed or a bad update that went wrong... if it does blue screen even in safe mode than it's a bad hardware, check all hardware... unplug all the hardware than plug back the hardware one by one to pinpoint which hardware is causing the problem... MEMORY, CD ROM, HARD DRIVE, WIRELESS CARD, etc...
Cheers!
Aug 22, 2011 | Hannspree HannsBook SN10E22BU3221 Netbook
I install windows xp profetional in g62_b39se it installed compeletly but when insatll completed, an blue screen apeared whith stop massage
Power on Laptop & Click F8 Button then Safe Mode Menu Visible Select "Disable Restart After System Failure" Then U Wacth And Reply Error Msg And Error Code Fully.
Best Of Luck
May 07, 2011 | Computers & Internet
My netbook (Acer Aspire One Netbook ao531h) goes to blue screen on start-up it has an unmountable boot volume error, codes shown below: STOP 0x000000ED (0x86B5C470, 0xc0000006, 0x00000000, ...
Its the problem with hardware driver software. Please remove last installed software/hardware in your system. To remove software run system in safe mode by pressing F8 on system starting and select safe mode then remove last installed hardware by opening device manager or remove software by opening add remove program from the control panel.Then restart system.
Any problem came ask again new question
************************Please RATE it *******************
Apr 25, 2011 | Acer Aspire One Netbook AO531h-1729 10.1...
I can only boot in safe mode, if i try to boot reguarly it gets the blue screen right after i enter my password to log on
You most probably installed some software or driver before this problem started to occur. So while youre in safe mode try uninstalling recently installed programs. Other way around is to use system restore when your computer boots up in safe mode and gives you the options screen to do a restore. Restore it to a date before your problem started.
Mar 11, 2011 | Microsoft Computers & Internet
My laptop go on then blue screen then turn off
There is one solution for your BSOD problem and it's free,, As soon as you turn laptop on, keep tapping F8 until another screen appears,, then choose safe mode with networking.
Type tdsskiller.exe into google and download from the first site listed. Download the exe not the zip.
once downloaded install to your desktop. Once installed open tdsskiller and run a scan,
Once scan is complete select cure. Once cured, Please reboot your system and you will have no further blue screen errors.. Hope this helps and please rate,,
Mar 08, 2011 | HP Computers & Internet
When i turn on the laptop there are a blue screen and that is the text - there are a problem has been detected and windows has been shut down to prevent damage to your computer. UNMOUNTABLE_BOOT...
did you install any new hardware like a card, usb product, please have them removed, also if you enabled any stuff on the BIOS setup please go back and disable now, let me know what the situation is,
regards
Apr 21, 2010 | Computers & Internet
Dell Inspiron 1520 laptop. Blue Screen
Dear, Requested data was not in memory. An invalid system memory address was referenced. Defective memory (including main memory, L2 RAM cache, video RAM) or incompatible software (including remote control and antivirus software) might cause this Stop message, as may other hardware problems. What you can do is if you have more than one memory modules, you can boot the system with single and see. If this is due to memory leakage issue, you can find it here
Oct 16, 2009 | Dell Inspiron 1520 Motherboard
Microsoft Windows XP Professional for PC Logo
500 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
