Question about Magnavox Mdv2100 DVD Player
My dvd player opens then closes correctly but then begins to make a clicking sound and re-opens by itself....
Why can't we get the dvd to eject?
Possibility 1 -
The laser light inside the DVD player is most probably no longer aligned and cannot read the beginning of the disk. Therefore it keep on trying to find the first line but it can't.
Possibilty 2 -
Your husband entered a pirated copy and sometimes the first few tracks are unreadable due to the lower quality of DVD-R used and it jams the laser light inside the DVD player.
What needs to be done is to unplug the DVD from its source and gently pull open the DVD drawer in order to remove the stuck disc inside. Once that is done, power up the unit and press on the "eject" bottom so that the drawer can close itself.
Good luck.
Aug 16, 2012 | Samsung DVD-V4600 DVD Player/VCR
When trying to play a dvd the tray comes out like usual,but when closing tray for it to load tray doesnt fully go in and automatically ejects itself..i have taken it apart and found if its on its rear end...
My experience with CD/DVD player tray malfunctions has unfortunately led me to conclude that when they begin to screw up they don't stop until they die - and rather quickly. Hope your experience is different, but I wouldn't count on it.
Jul 26, 2017 | RCA DRC247N DVD Player
When a bluray disk is stopped the player does not resume where it left off like a dvd it starts from the beginning of the disk
Hi there, this is a problem with ALL Bluray players, it is an annoying format problem, where "resume play "is not available on JAVA enabled Blurays, (BD-J).
JAVA content is usually the interactive menus and extra features on specific Blurays. These are essentially computer programs, so when you close them and re-open them they open from the beginning, (Just like on your computer, when you close a program).
All standard DVD's and non BD-J discs will resume play as expected, this is why some people think there is an intermittent fault, and others say that there model of player is working fine. Hope this helps.
Here is an link to SonyAsia's FAQ
Jan 16, 2011 | Sony BDPS570 Bluray 3D Player
Incert dvd read out sats NO
Hello
This usually happens when the DVD or laser lens pick-up has become dirty.All you need to do is
1. Check the disk for scratches.
2. Make sure the disk you are using fit the correct format specified by your DVD player.
3. Clean the laser lens with a DVD laser cleaning disk.
4. Insert a correctly formatted undamaged disk into your player,listen to see if it begins to read the disk,if it continues to make no sound.
5. Open the DVD player carefully and clean the lens with isopropyl alcohol and cotton swab.
6. If none of these solutions works out then a professional repair technician will be able to tell you if fixing your DVD player is worth the money.
BEST OF LUCK
Jul 13, 2010 | Toshiba SD-K760 DVD Player
Opens and closes repeatedly
hello,
The most common reason for the player opening and closing itself is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your player, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your player including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your player going again!
Hope this helps...
Jun 01, 2010 | Apex Digital AD-1125 DVD Player
Unable to open the door of the dvd --when you press the eject button to open the slot---the door does not open---everything else works
Quick trick
First let's find out if the motor is dead or
the magnetic clamp is to strong for the motor.
Press eject then listen closely for the sounds of struggling motor
if you hear it trying SLAP the top right over the DVD drive
and that should break the magnetic seal and release the tray
you may have to try a few times Press eject and open hand slap kinda
hard the top of the DVD drive , don't worry you won't hurt it.
if that works email me and ill tell you how to fix this.
Rob
rsheehan@northernsteeldesigns.com
Oct 14, 2009 | GoVideo Go Video DVD/VCR Combo
Audiovox pvs69701 trouble shoot. When I insert a DVD the unit begins to read the DVD and then then says ''no disc''. It has worked well in the past and I have tried many different DVDs to see if it the...
Open the casing, check the following and follow the instructions.
1. Clean the lens using cotton or cotton cloth.
2 Take extra care not to touch the lens with bare hands.
3. If the player displays "no disc" right after closing the tray then
check capstan motor if it spins smoothly.
4. Replace capstan motor if it cannot spin smoothly or if it seems it
cannot spin the disc.
Jul 17, 2009 | Audiovox Televison & Video
How to make DVP5990/37 Region Free
First I recommend that you upgrade the factory firmware to the latest version. The current version is .31 and available here. Click "I accept" to accept the license agreement and start the download. Open the zip file and burn the file named DVP5990_37.bin to a CD. Put the CD in the DVD player and it will begin the upgrade and open the DVD tray. Remove the CD but leave the DVD tray in the open position. After just under 10 minutes (6-8) the DVD player will report that the update was successful and close the DVD tray. Press the setup button, go to preferences scroll down the choices (past the bottom of the screen) and select reset to default values. The player will reboot.
Next press Setup
select the Preference menu
Press 1,3,8,9,3,1 on the remote control.
Use the up/down arrows to select region "0" which means all regions.
If you ever get a disc that won't play correctly due to a region error, just use the code above to select the correct region for the disc and you will still be able to play it.
Nov 02, 2008 | Philips DVP5990 DVD Player
Mizuda dvd player wont read dvds
A couple of things To try.
1:) The DVD Player May be Region encoded, can only play certain region Dvds. ** Try different Disks**
2:) The Disk May Be Dirty-Scratched ( Towards The Centre )
** Clean The Disk With A Soft Lint-Free Cloth**
3:) The Laser Head may have a speck of dust or debris on it.
** Try a Laser Cleaning CD**
Hope this works For You.
Mike @ Compurepair.
Mar 01, 2008 | Shenzhen Mizuda DVD-999 DVD Player
I am having the same problem as Peg!!!
The belt that changes the disc is broken. can fix with a goody hair tie w/o a metal clasp.
Feb 15, 2007 | kawasaki SVP500 Multi-disc DVD Player
Magnavox Mdv2100 DVD Player Logo
27 people viewed this question
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
