Question about DG D&G DW0430 watch
I have a d&g watch i cant find the serial # to find out if it is real
D&g is engraved in the back along with dolce and gabbana but there is no visible serial# where is it ? is the watch a fake
Can I get a D&G watch serial number check to see if it’s genuine before buying (SN:8068W) (247704-39
The only sure way is to take the back off. There are many Chinese copies around at present and people are passing them off as the real thing.
How to spot a fake D&G Watch ' eBay
www.ebay.com/gds/How-to-spot-a-fake-D-G-Watch-/.../g.html
This guide might help someone not be taken in by buying a fake D&G watch or the full brand name Dolce & Gabbana. ... (see pictures below). Don't panic if you have bought a D&G watch and you are worried it is a fake - here are some simple tips on how to tell:- *Check the stones ... A fake will loose its stones very easy. D & G watch serial numbers Google Search
Dec 13, 2017 | Watches
R ingraved on back
A personalized engraving on the back of a watch case means nothing as far as its authenticity is concerned. Think about it an engraving can be done at any time after the manufacture of the watch is completed so how could an engraving or lack there of tell you anything about authentic? I bought an older Day-Date President a month ago and it had the persons name, birthday, and SOCIAL SECURITY NUMBER engraved on the back. What is interesting about this particular engraving is that it is a fairly bad engraving. Which means that an unskilled person did the engraving, but that is all it means. The particular watch I am reffering to is very real indeed. All that aside I'm going to say that your watch is fake. That is a 20K watch and the fact that you don't know how the engraving got on there indicates that its more than likely not real. That's also one of the most commonly counterfeited Rolex's. If you wanna know for sure take it into a pawn shop and tell them you want to sell it. Just don't argue with the people when they tell you its fake.
Dec 16, 2013 | Rolex Daytona 116520 Wrist Watch
Need a new leather strap. Wheere to find?
I'm sure there's universal straps u can get but original strap keeps the value
Jun 14, 2012 | DG Dolce & Gabbana Cream DW0058 Watch for...
How do you set the time on a dolce & gabbana eden
I have looked at their web site and although there are a number of watches listed, I couldn't find the one you mentioned.
I suggest that you click on the link below to contact them and ask for help.
http://store.dolcegabbana.com/cms/help/contactform.asp?tskay=436A8784
(Before you do, there must be some method of adjusting the watch and I have seen ones where the adjuster is hidden in the watch strap area. Look carefully under the strap fixings and you may see a push button let into the body, which will need a small probe to operate. There might be two (one on the opposite side). If yours is an electronic watch then one button (mode) will for entering the setting mode and the other to change the setting. When setting is complete, press the mode button to return to normal operation.
May 06, 2011 | Watches
I broken braslet by d &g wathes were i need to fix it
I strongly recommend visiting or contacting your local Certified Master Horologist to repair or replace the band, link, or clasp that may be damaged. They usually can either repair it for you or order the parts from D&G for you and fix it on site for you.
Feb 23, 2011 | DG D&G Dolce & Gabbana Caterpillar...
Real or Fake
Real cartier santos watches are engraved on the back of the watch not etched on the back like a fake. Also the word cartier is engraved on the clasp of the bracelet. Do not but unless these two conditions are satisfied.
Apr 15, 2009 | Watches
I have a dolce gabbana watch and i cannot open it, there is no where i can see on the back to flip the outside casing to open it.
There is the groove or the lip on the back, but it might be very tiny. Get an eyeglass and examine caseback very carefully all around and you will find it.
Do not forget to rate, please.
Feb 03, 2009 | Watches
DG D&G DW0430 watch Logo
263 people viewed this question
Top DG Watches Experts
Ansel Alberto
Ansel Alberto
Are you a DG Watch Expert? Answer questions, earn points and help others
