Question about Food Mixers
What type of oil do I need to use in a mtn 1.5 hp meat grinder
    President:
  • 2,976 Answers
Any FOOD GRADE oil will work. I prefer to use mineral oil.
Posted on Jan 17, 2013
4 Suggested Answers
  • 25 Answers
SOURCE: KitchenAid Mixer
depending on the model there is a round cover on the front of the mixer. Detach it to expose the secondary drive connection. Depending on what you are connecting to it you need to connect to the drive port and secure the accessory so it is stable. If you need instructions google kitchen aid and ask them for a manual.
Posted on Mar 26, 2008
  • 49 Answers
SOURCE: Hobart A200
Yes A-200 are number 12 I would find a hobart grinder they will have a big H in the casting on the neck get one with a stainless pan and stomper to push product down the throat. If you wait on Ebay and put it on your watch list they do come along. look for no rust. Make sure it has the big H in the casting. the other after market ones seem to not last long like the metal wears on the worm and hub to fast. also you always know where to get a piece if you need it if its a Hobart. not so with the forign jobs.
Posted on Dec 29, 2008
  • 3 Answers
SOURCE: hobart meat grinder,model 4322 asking what type of oil in gearbox to use?
You can buy food grade grease from kitchenaid or on amazon. I did use the grease from my work. Any grease would do the job just make sure you read the specifications to find the grease that can stand high heat so it doesn't melt while the machine is running.
Posted on Dec 14, 2011
Wear to find a spare khife for an MaxiMatic HA-3433A Elite Platinum 550-Watt Stainless Finish Meat Grinder
contact the manufacturer through their website support they probably have them available to purchase
Apr 05, 2015 | Food Mixers
How to use food grinder attachment
The mixer's planetary is not disconnected when the meat grinder is attached and continues to turn.
If the noise you hear only occurs when the grinder is in place, then the grinder may be assumed to be the cause. Consult the meat grinder's instructions and make sure that nothing is loose or overtightened.
Mar 04, 2015 | KitchenAid Kitchen Aid K45SSWH Classic...
Need instrucion manual for moulinex electric meat grinder & salad maker
You don't mention what model number, but you might try this page. It has several meat grinder instructions booklets you can download.
http://www.moulinex.com/Pages/default.aspx
Jul 22, 2014 | Food Mixers
The switch doesn't work on my grinder. got new one but terminals are different. is there a schematic for min0022 or 40744 grinder?
Best you contact the manufacturer so you do not burn out the motor by mistakenly attaching to the wrong posts.
Mar 14, 2014 | Vollrath 40744 22 Meat Grinder 1.5 HP 110V...
Need to adjust clutch on hobart 4346 meat grinder how do you do it?
On the 4346 mixer/grinder the clutch can't be adjusted. It is a Moorse clutch and will need to be replaced. If you ate handy buy the rebuild kit for the bottom end from Hobart. It's not cheap but once it's done it will last for years. Hope this helps, Food luck
Dec 16, 2012 | Hobart 4346 Meat Grinder Mixer Chopper...
Hobart meat grinder,model 4322 asking what type of oil in gearbox to use?
Dec 13, 2011 | Food Mixers
Hi, the motor went slower and slower and now has stopped. We were using the meat grinder and we have only used this machine 9 times in the past two years. We are very upset customers and have 15 pounds...
If you remove the meat grinder, does the mixer still work? It could be that the meat grinder is jammed.
You might have also blown a breaker. Have you tried plugging a lamp or something else into the outlet to make sure it's still working?
Oct 18, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Black Residue on meat using Kitchenaid meat grinder attachment
This is a common issue with the Kitchenaid food grinder. The black residue is a product of the meat itself.
With Kitchenaid Food Grinder Attachments, it is recommended that the meat be partially frozen before grinding. This is to ensure a quality grind and to make sure the meat holds all its juices while grinding.
If any juices from the meat are leaked into the food grinder, the friction will cause a chemical reaction and turn the juice from the meat into a black substance.
Dec 17, 2008 | KitchenAid K45SS Classic Stand Mixer
My kitchenaid sausage maker does not stuff the sausage casings
This may be a problem with assembly of the Sausage Stuffer Attachment. Your Use and Care Guide for both the Food Grinder and Sausage Stuffer could illustrate the assembly for you in detail.
Also, it may take up to 4 minutes after meat is fed through the top of the Food Grinder for it to start stuff into the casings. The meat is fed into the Food Grinder, ground, and then pressure is built up behind this ground meat to push into casings.
Jun 01, 2008 | KitchenAid KSM150PS Artisan Series Stand...
Food Mixers Logo
71 people viewed this question
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
