Question about Gateway ZX6800-01 (PW.G8802.004) 23 in. PC Desktop
Fan speed zx6800
Fan running 2700 to 2800 rmp cpu temp at60 c what should be the fan speed
  • 3,799 Answers
It depends on which fan you are talking about (CPU or Case) It would also depend on the heatsink you have fitted and the CPU that is fitted. The speed is about right for a CPU fan though. If your computer stops on it's own after a short while you may have an overheating problem. To check the CPU temp is in the correct range try CPU world website for the spec for your particular model.
Posted on Jan 12, 2013
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: cpu fan running at full speed
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards
desktop or laptop computer fail to boot for a variety of reasons, but a fast, loud fan noise signifies that the system is suffering from overheating.
The problem, and the steps for troubleshooting it, is not unique to the Gateway Desktops.
When the internal temperature of the computer reaches too high a level, the system will shut down automatically to allow the heat to dissipate.
If you attempt to power up too soon, the machine will not boot properly.
To boot, you will need to correct the cause of the overheating, and keep the machine cool.
Blocked Vents
Although different in size, both desktop and laptop computers have air vents to help the fans keep air circulating around the hot internal components.
If these vents become blocked, by pushing a desktop too near a wall or using the laptop on a soft surface, the air supply your internal fans need to cool the system is cut off.
This blockage also traps the heat inside, allowing it to build to dangerous levels.
Keep the air vents on your computer free and clear to allow proper airflow.
Dirty Computer
Airborne particles, such as dust, lint and hair, can gather on the air vents and internal components over the course of time.
This accumulation of dirt not only provides a sort of "insulation" to the electronic components, preventing the heat they generate from dissipating normally, but it also clogs the fan and heat sink to prevent proper function.
Use canned air and damp, soft cloths to thoroughly remove any built-up debris from inside your computer.
Dried Thermal Paste
The heat sink sits atop the CPU chip to help dissipate the heat the component produces. Thermal paste is layered between the CPU and the heat sink to help draw the heat away from the chip for cooling.
Over time, the cooling properties of this paste decreases, and the substance becomes dry and flaky.
You can replace this paste to renew its cooling assistance by removing the old paste remnants with rubbing alcohol and adding a new layer.
Thermal paste is also known as thermal compound or thermal grease, and is available at most electronics stores.
Check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat
Thermal compound is a sticky paste that is placed directly onto the CPU.
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
Hot Environment
When examining overheating causes, don't overlook the environment you use your computer in.
External heat sources, such as fireplaces or even rays of direct sunlight, can cause the internal temperatures of your computer to rise.
This causes your internal fan to run harder in an attempt to dissipate the combined heat before temperatures rise too high.
Move your computer away from external heat sources to encourage more effective cooling.
Hope this helps.
Posted on Nov 28, 2012
My CPU Heat
You should check Task MGR and see what process's are running, you need to find out if the CPU is being pushed, when you are not doing anything the CPU should be close to zero or between 0-10 percent.
So if you check and find the CPU is running at Idle, then you check the CPU fan clean it.
You should install software that will show you the CPU temp and fan speed, as you work the CPU through software running, the fan should increase in speed.
If the CPU is not staying cool near 40C, then look for a better cooler.
Thermal compound has no miracle, the cooler is what is important, and the case fan is not as important as the CPU cooler itself.
Dec 02, 2012 | Computers & Internet
CPU fan running at constant full speed
Seems like you cpu is running hot and therefore triggering the fan to spin fast in order to keep the temp low. You can monitor the cpu temp buy downloading this programs and see its really the cpu thats overheating. http://www.techpowerup.com/realtemp/
Sep 07, 2011 | Dell OptiPlex 330 Desktop Desktop Computer...
I have a Dell Inspiron 530. Was getting 2 quick beeps on start up and loud fan noise. I replaced the cpu fan but the one I bought did not have the right plug for the motherboard connection. I had to modify...
This model (as well as many other Dell desktops) has a DUAL SPEED CPU fan. If the motherboard detects that the CPU temp is running hot it will increase the speed of the CPU fan to lower the temp of the CPU. You should do a Google search for the correct CPU fan and purchase it and install it back into your computer.
Aug 28, 2011 | Dell Inspiron 530 Desktop Computer
Cpu fan runs at high speed all the time
the problem is that the mother board you are now using has a 4th wire that sences cpu temp this allow the heat sink fan to change speed to get this to work correctly you will need to replace the fan with a 4 wire style. what is happening is your not getting a temp siginal back to motherboard so the fan controller think it hot and send full power to fan alll the time the stock fan in hp systems is not very good any way .Get a good heat sink and fan to fit your new board ebay has them very cheap 5.00 to 20.00 this will all so increase you system temp and all get the proper cooling when you really need it.
Jun 10, 2009 | ASUS M3A78-CM AMD 780V AM2+ Phenom FX /...
System temperature too high
Do you still have your manual? If not download it from Gigabyte at this link:http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=2637
Enter your bios & open manual to page 51, "PC Health Status". Here you can monitor the CPU temp, system temp & CPU fan speed. Notice the manual shows the example of system temp to be 30degs C & current CPU Temperature is at 47degs C. One would think these temps are reasonable. My CPU fan runs between 3308Rpm & 3341Rpm. CPU @ 41deg C & MB @ 31deg C. AMD 64 X2 Dual Core 4200+ 2.21 GHz.
Suggest you try this. If your running Win XP. Open system properties. Click the Advanced tab. Click the settings button under
Startup and Recovery. Remove the check mark to the left of, Automatically restart. Windows should provide an error message if & when the system freezes. This will help in finding what is causing the system to freeze. If your CPU fan is running under 3000Rpm you might consider buying a faster fan or add a case fan to the side of the case to help bring in fresh air to blow onto the CPU fan & PCI-Express card. Here is a decent lace to look for case fans: http://www.xoxide.com/casefans.html
Keep me up to date andr_zero.
Mike
Dec 17, 2008 | Gigabyte GA-P35-DQ6 Motherboard
Fan on
The CPU fan on the GX280 is a variable speed fan. It only runs as fast as necessary to keep the CPU cool. But the fan also has an rpm sensor built in that regulates it at 3000 rpm. If the sensor is going bad, it senses its running slower than 3000 rpm when its actually running faster and continues to speed up until its wide open. Thus the 'jet engine' sound. Replace the fan and that should do it. If by chance it doesn't, it gets more serious and likely a motherboard problem.
Aug 26, 2008 | Computers & Internet
Motherboard problem
Chances are the CPU fan may be running too slow, dust & dirt build up under & over the fan blades can be a big factor. CPU fan could just be going. Are you over clocking the system. (IF so buy a better heatsink & fan for over clocking the system).
To check if CPU is getting too hot. Enter the bios & go to the title, "Power" page 2-28. Open Hardware monitor & check the CPU temp & mother board temp. (Make sure the case is closed in normal running conditions).
Link to Asus: http://support.asus.com/download/download.aspx?modelname=M2N-MX&SLanguage=en-us
Jul 02, 2008 | ASUS M2N-MX Motherboard
Cpu fan noisy/chip fan fail error messages
pils,
Yes. This sounds like a fan issue. The noise often comes from bearings failing within the fan. Also, a failing bearing can make things harder on the motor as it brings the fan up to speed. This is likely the reason that you see increased warnings during the fan speed check while booting because it comes to speed more slowly as bearing wear increases.
I give this a 90% chance that your CPU fan is causing the issue. Since a decent CPU fan will cost you ~$20 online, it's not much out of your pocket if you happen to uncover another culprit.
I'll keep an eye on this post. Let me know how things go.
Apr 03, 2008 | ASUS A8N-E Motherboard
Cpu fan noisy /chip fan fail
You must buy a new CPU Fan. You can get them HERE or a zillion other places on the Internet. You need a Socket 939 type fan that will handle your cpu speed. If you need help installing it, it may be in the manual. You can read the manual by clicking on the picture of your MB at the top of this post and then scrolling down.
Hope that fixed ya...
Geno
Apr 01, 2008 | ASUS A8N-E Motherboard
Gateway ZX6800-01 (PW.G8802.004) 23 in. PC Desktop Logo
129 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
