Question about Samsung HL Televison & Video
SAMSUNG TV HL-85687W picture is dim
Picture is suddenly very dim/dark and cannot view well at all. Will a new bulb fix the problemo?
    Scholar:
  • 52 Answers
(Please check your model number - it appears to be incorrect, I believe it's HL-S5687W)
1) How old is the lamp? (how many hours on it)
2) Is the lamp an original equipment lamp, or aftermarket?
It's either the Lamp itself (it's not common for a sudden reduction in brightness), -or- the Lamp Ballast has gone bad. This is the power source for the Lamp, and although they usually die completely when they do go, sometimes they will act just as you have described... they fail into a "low power" mode.
If the lamp IS an original mfr lamp, and if it's nowhere close to being near "end of life", then I'd say it's likely the Ballast.
Prices for the original Samsung lamp run around $100 onamazon and others.
The Ballast p/n BP47-00037A has a cost of around $50 to $100 online.
Google those p/n in "Shopping"
The Ballast can be replaced without great knowledge, but will require some dis-assembly, and CARE.
WARNING - Dangerous, and even lethal voltages are present inside your TV set. Do not attempt this unless you are trained in these kinds of repairs. Leave the TV unplugged for several hours (or preferably a full day) before attempting such repairs.
Posted on Jan 12, 2013
SOURCE: no sound or picture HL-R5067w samsung
alread change the lamp and fan did not work
Posted on Feb 09, 2008
SOURCE: 2 new bulbs, still dim picture
It could be a dirty projection lense or the light engine is malfunctioning by a slipped lense in front of the color wheel or the light engine is dirty it self. They are not two hard to take out if the mounts have set marks on them then it is easy to put the engine the way it was.
Posted on Mar 18, 2008
  • 2920 Answers
SOURCE: samsung dlp hl-p4663w
you need to find out what mage it blow to get the tv to work again
Posted on Oct 23, 2008
  • 25 Answers
SOURCE: We have a samsung tv model #HL-85687W and need to
pullof small covers on back it should be one of them.
Posted on May 27, 2010
Testimonial: "Thanks sooo much for your suggestion. It was easy to replace and I was glad to be able to do it myself."
  • 171 Answers
SOURCE: DARK PICTURE ON MY SAMSUNG DLP/HD REAR PROJECTION TV
It sounds like you need to buy a new bulb, this is what usually happens when the bulb is burning out this bulbs are made to last 6000-8000 life hours
http://www.discount-merchant.com/
Posted on Aug 20, 2010
I have a 55in Samsung Dlp the color looks good but a little dark can't see picture if the movie is dark
You might need a new bulb, the bulbs get dim as there life diminishes. Replace the bulb to get a bright picture. Do not use cheap bulbs, an OEM bulb for that tv should be $60+. . Cheap clone bulbs will work but will fail a lot sooner
Feb 19, 2015 | Samsung Televison & Video
Where is the service menu for the bulb in the Samsung HL-S5087W DLP
if picture dim it is most likely the lamp and resetting the lamp timer will not help that.
Oct 14, 2012 | Samsung HL-S5087W DLP TV
THE PICTURE IS TOO DARK. It is not as bright as it used to be.
Normally when your picture starts to get darker or dimmer it usually means that the lamp is almost out, your are able to go to a page called discount-merchant.com they have good prices on tv lamps and tv parts also and they also help you with questions you may have.
Dec 29, 2009 | Samsung DLP HL-P5663W 56" TV
Dark picture on lg dlp tv
Did you use a generic replacement? Many TVs have a dark picture after replacing the original lamp with a generic. The other issue I've encountered are TVs that have been exposed to cigarette smoke will develop a dark, discolored picture over a relatively short time.
michtech
Feb 19, 2009 | Samsung HL-R5668W 56" HDTV
Samsung DLP Dark Picture
try to reset the tv setting to its manufacturer settings and see if it fix the problem
Feb 01, 2009 | Samsung DLP HL-P5663W 56" TV
TV has dark streak on one side of screen.
Your TV has a bad light tunnel. This part is inside the light engine. A qualified tech will have to replace it, but the part is available. Once it is replaced the TV will be as goog as new. Please take time to rate this solution and let me know if I can be of further assistance
Dec 13, 2008 | Samsung HL-S5687W 56" HDTV
Televison & Video Logo
135 people viewed this question
Jerry Greenberg
Jerry Greenberg
