Question about Eureka 71B Bagless Vacuum
Eureka 71b roller does not move - Eureka 71B Bagless Vacuum
Hi I have a Eureka upright bagless vacuum and I need to use the hose attachment to vaccum a car seat and floor. How do I get the suction to apply to the hose only?
Look at the top of the plastic housing that covers the brush roller. You will find an adjustment lever that switches from floor to hose. The lever may be difficult to move. It is not a feature of Eurekas that ages well.
Feb 01, 2017 | Eureka Vacuums
I took apart my Eureka 71B hand held vacuum and a small spring fell out. I don't know where it goes and can't find a manual anywhere. Help?
Lonny,
I have a 71-B2 model myself and if you can take a picture of the spring, I can try to take mine apart and see if I can figure out where your spring goes and get back with you.
Aug 09, 2015 | Eureka 71B Easy Clean Hand Vacuum Yellow
We have a Eureka 71B Hand-Held Vacuum and it looks like the belt broke. I removed the two screws at the bottom that should release the housing that holds the belt. However, the housing still does not...
There's a 3rd screw hiding underneath a plastic shield. You'll have to drill or cut off the covering but then it's pretty easy to deal with.12_9_2012_9_37_36_pm.png
Dec 06, 2010 | Vacuums
4870 roller part number
I know the belt number
Eureka Part Number: 61110B (Replaces 61110, 61110A)
And the roller i think: Genuine Eureka Brush roller part number 61250-3 for Eureka The Boss/Smart vac/smartvac ultra 4800 series vacuums including models 4870 and 4880
Hope this helps you.
Jan 03, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka 4870: Brush roller turns even in hose setting.
You either have the wrong size belt, most likely too small, or you have installed a new belt incorrectly. When you open the cover on the bottom of your vac, you will see the pulley that moves as you flip the switch from floors to carpet. The belt does not go around this pulley. When activated(carpet) the pulley puts tension on the belt causing it to turn the roller. When switched back to hard floors, the belt looses tension allowing motor to cause suction but disabling roller. Also, the dial on top of vac is only to direct suction, not for disabling roller
Jun 21, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
New brushroll for eureka smartvac 4870; bristles too long to turn
HI Don't forget that you have a height adjustment control so its better to put it in the highest position - if this is not allowing the roller brush to move properly on the carpet then switch the vacuum off, and lightly trim with scissors on the brush lines. Avoid cutting everything down though - a slight trim should improve things. Generally though when brushes appear too long its usually because the height adjustment dial hasn't been set upwards.
Mar 27, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka the boss 5893A brush roller will not work
is there anything jammed underneath.can you turn the brush roller by hand.if not then take it back where you bought it.sounds like you have a defective brush roller
Jan 11, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Roller will not move
might be the belt have to take the bottom cover off and see or it might have a foreign object wedged in the roller have to take the bottom off just 5 screws.....hope this helps
Oct 31, 2008 | Eureka Smartvac 4870 Bagged Upright Vacuum
Roller not moving
You can buy a new vacuum at walmart.
Feb 28, 2008 | Vacuums
Eureka 71B Bagless Vacuum Logo
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
