When my washer spins my clothes, it shakes really bad. what could cause this?
  • 21 Answers
The machine is off level. open up your installation guide, it will provide step by step details on how to level the machine. if you dont have the installation guide, feel free to email me at thadoggma420@hotmail.com and i will be happy to walk you through it.
Sam
Posted on Jan 22, 2009
My Samsung washer model wa456 will not spin all the way out with even just a few clothes in it and shakes really had, what do I do?
Washers have a switch which disengages the motor if the load is unbalanced. An unbalanced load will cause the drum to spin irradically and bangs against its bumpers Either you are not loading it correctly or one or more of the flexible supports that keep the drum centered, are broken or disconnected.
Feb 15, 2017 | Samsung Washing Machines
My tub looks crooked and the washer shakes really bad when it spins
Unscrew agitator and look for twisted up cloth underneath.? Could be bearinv in transmission has gone bad.
Mar 10, 2014 | KitchenAid Washing Machines
Why is Maytag Centennial 3.2 cu. ft. SuperSize Capacity Plus Top Load Washer shaking during spin cycle
check to make sure it is sitting level on the floor and one leg adjuster hasnt backed in making it shake. But even when you stick cloths in evenly they can bunch up during cycles.
Jan 02, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Drum knock when spin cycle
Hello.
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Shaking washing machine
If the shaking is during the spin cycle and you are using the High setting change it to Medium. This may fix the problem and the clothes will probably come out even dryer since the drum is not banging around.
Sep 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer shakes violently when spinning at high speed.
is the washer level and on solid surface both will cause machine to dance
Feb 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore 80 series washer wont rinse/spin
I fixed the same problem by using this site: http://forum.doityourself.com/archive/index.php/t-156215.html
Mar 17, 2008 | Washing Machines
Shakes violently and bangs on spin
transit bolts not removed. also can be caused by motor not winding up gradually into spin - usually a motor tach fault. most likely cause is transit bolts
Oct 18, 2006 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
69 people viewed this question
Top Washing Machines Experts
