Question about GE DCSR483EA Electric Dryer
Heating coil gets really red - GE DCSR483EA Electric Dryer
  • kbolewar Jan 22, 2009
    could it be the exhaust duct coming out of the back, if it is kinked or clogged?
    ok thanks, I will check those and also check the cycling thermostat
    President:
  • 1,214 Answers
If you are looking at the heating coil without air moving past it, then it will get very, very red, to the point of melting in two and breaking. In normal operation, there is enough air moving past the coil to keep it from getting red hot.
Posted on Jan 22, 2009
  • Mark Egan Jan 22, 2009
    Any restriction to airflow would cause this to happen. Kinked hose, plugged lint screen, plugged ductwork leading out of the house, plugged internal ductwork, etc.
    Cycling thermostat has nothing to do with the coil getting red hot. If there is enough air blowing past the coil, it will not get red hot. he cycling thermostat only controls the element based on drum temperature.
My dryer is not heating at all where to I find the thermostat and coils? Thank You
Most dryer heating elements are incased in a metal type box behind the dryer. It looks like the size of a shoe box for the most part, the heating element or coiled wires are inside that box, most of the time the coil wire breaks and will not get red/hot and will not heat at all. I've replace the heating element on my dryer, wasn't that hard to find and remove and examine that the coil was broken not making contact any more.
Mar 05, 2015 | Dryers
I have a Dimplex Heater model no DS5629BR Can't get any heat I have unpluged it & and still can't get any heat. Dont see anything in manual about thermostat being bad or changing it all it said w
Have an electrician check it out.
The heating comes from coils of wire which glow red heat. Air from the fan passes over these coils and keep them from burning out.
If the unit has overheated, it is very likely that one of the coils has burned out and there is no electrical circuit, hence no heat.
An electrical repair shop will be able to verify this for you and fit replacement coils.
Jan 06, 2015 | Dimplex Heating & Cooling
The heating coil in back of the drum turns red ...normal?
If it stays red constantly you have a problem as the thermostat control should regulate the heat, otherwise not unusual to go red as that is what a coil is designed to do.
Nov 12, 2013 | Dryers
Will start, clothes will tumble but will not heat up to dry the clothes
Run it with the vent off if you feel some heat for the first minute and the airflow is strong you best bet is to change the valve coils.The vent is not a part in the dryer the vent is was connects to the back of the dryer pull the vent off and run the dryer to test.
The coils are on the top of the gas valve.
Gas dryer with no heat: The parts that I have pointed out with the arrows are the parts that you will need to check with an ohm meter if the dryer is not heating. First check and see if you have 110 volts coming to the gas valve at this type of a connector. If you have voltage, then unplug the dryer and check the parts I have pointed to. Some dryers have 3 coils instead of the 2 shown here. If you do not have voltage coming to the burner, then you will need to check the timer contacts that feed the gas burner, hi limit thermostat, operating thermostats, the safety switch on the motor, and any other point that you can see on your wiring diagram picture that feeds voltage to the burner. The coils on the gas valve are very bad for working once or twice and then quitting. If you find a open circuit on one of the gas coils, replace them all = less problems later on. If the glow coil does not work ( get red ), check it with a ohm meter for continuity. The next thing to check if the glow coil does not come on would be the radiant sensor. Inspect the igniter for small burnt spot on dark gray or black part of igniter or check for 110 volts to igniter wire plug when dryer should be calling for heat. Sometimes the ( older style ) igniter is separate from the holder and the holder can no longer hold the igniter tight enough and the two parts burn/arcwhere they touch each other = new igniter and holder ( some manufactures have new kits to replace these older style parts ).
Does the igniter get red and stay red, or does it get red, you hear a click and it goes off, then a minute later its gets red again?....if so you possibly have a bad set of coil valves. If the igniter gets red and stays red constantly then its the flame switch that is bad and maybe welded closed.
Check out, this possibilities.This should help.Thanks.Helpmech.
Mar 25, 2011 | Kenmore 93142 Gas Dryer
My dryer rotates but does not heat up. I replaced the ignitor and it did not fix the problem
Hello there
Gas dryer with no heat: The parts that I have pointed out with the arrows are the parts that you will need to check with an ohm meter if the dryer is not heating. First check and see if you have 110 volts coming to the gas valve at this type of a connector. If you have voltage, then unplug the dryer and check the parts I have pointed to. Some dryers have 3 coils instead of the 2 shown here. If you do not have voltage coming to the burner, then you will need to check the timer contacts that feed the gas burner, hi limit thermostat, operating thermostats, the safety switch on the motor, and any other point that you can see on your wiring diagram picture that feeds voltage to the burner. The coils on the gas valve are very bad for working once or twice and then quitting. If you find a open circuit on one of the gas coils, replace them all = less problems later on. If the glow coil does not work ( get red ), check it with a ohm meter for continuity. The next thing to check if the glow coil does not come on would be the radiant sensor. Inspect the igniter for small burnt spot on dark gray or black part of igniter or check for 110 volts to igniter wire plug when dryer should be calling for heat. Sometimes the ( older style ) igniter is separate from the holder and the holder can no longer hold the igniter tight enough and the two parts burn/arc where they touch each other = new igniter and holder ( some manufactures have new kits to replace these older style parts ).
Jan 10, 2011 | Kenmore Dryers
Gas dryer not heating consistatnly
Hello there
Jan 09, 2011 | Kenmore Dryers
Dryer not heating . i took out drum and ran dryer . i watched heating coil get red/glow but then "clicked" off.this happened approx. every minute. i have a gas rgk2951kq2.
This is most commonly due to the coils that are part of the gas valve. The glow you see is the hot surface ignitor trying to light the main burner. The gas valve coils will not open the main gas so you never get the heat.
The coils can be replaced.
Aug 22, 2010 | Dryers
Coils get hot
Hi, as soon as you turn your dryer on, power is sent to these heat strips and they will glow red hot. This is normal. They will kick on and off through the drying cycle by several thermostats in the unit so it will not over heat. Nothing to worry about as you have 240 volts going to them.
Sincerely,
Shastalaker7
Apr 20, 2010 | Whirlpool LEB6300 Electric Dryer
Gas dryer no heat frigdarie
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
Gas dryer with no heat: The parts that I have pointed out (click it )
Sep 11, 2009 | Frigidaire Dryers
GE DCSR483EA Electric Dryer Logo
163 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
