Question about Olympia Mastertype 3 Typewriter
Erase key On the Mastertype 3, I can't figure out how to get the erase key to work. Could you help me with this?
  • Olympia Master
  • 3,594 Answers
When you press the correcton key it should backspace and lift off the print, if it makes the movement and dosen;t correct check to be sure you have a correctable ribbon (orange or yellow knob), be sure the correction is installed properly dull side facing the paper.
Posted on Jan 24, 2009
Hi i own a RCA digital voice recorder model# rp5030A i can not figure out how to delete recordings
Erasing selected file
You can delete a file by the following steps:
1. Select folder (A, B, C , D or )
2. Select file.
3. Press ERASE once and DELETE will blink on the screen.
4. Press and hold ERASE for 3 seconds to confirm deleting. (or press STOP to cancel erasing file)
Erasing all files in a folder
You can delete all files in a specific folder by the following steps:
1. Turn on the unit.
2. Select a folder (A, B, C , D or ).
3. In Stop mode, press FORWARD continuously until "ALL" appears on the display.
4. Press ERASE and "DELETE" will blink on the display.
5. Press and hold ERASE for about 3 seconds, all files in the selected folder will be erased completely (or press STOP to cancel erasing all files).
Tip: File numbers that come after erased one will be moved forward by one automatically.
See page 12 for more info:
Dec 29, 2012 | RCA RP5030 Digital Voice Recorder
How can i use the eraser?
I'm not sure exactly what your problem is but if you type a wrong letter press the correction key on the R. side. The key has a "X" inside an arrow pointing left.
Go to click on current models one of the Nakajimas will be the same as yours.
Sep 19, 2011 | Olympia Mastertype 3 Typewriter
My internal screen on my Env3 doesn't work and i need to erase my messages. help please!
I have the exact same problem. I had to look it up in the manual to fix it but if you follow these steps it should clear it out for you:
1. Open the flip and press "OK"
2. Press "2" to open the message screen.
3. Press the right soft key (the rectangular button above the keyboard).
4a. To erase received messages hit "1" then "OK"
4b. To erase sent messages hit "2" then "OK".
4c. To erase Drafts hit "3" then "OK"
4d. To erase all messages at once hit "4" then "OK".
Nov 11, 2010 | LG enV3 VX9200 Cell Phone
You can download the owners manual in PDF format from this link.
412CID 4 Line Telephone
To answer you question - From the owners manual:
Erasing Caller ID Records
In order to delete a specific Caller ID record in the log:
1. Using the [<] or [>] key, find the particular record you would like to delete..
2. Press the [ERASE] key. The LCD display will indicate that the record has been deleted.
3. You may erase all caller information records simultaneously by pressing [ERASE] from the summary
Call ID display.
Hope this Helps.
Sep 25, 2009 | Bell BE-412CID Corded Phone
Need to delete old voice message, can someone help
Erasing Messages
The unit will announce the remaining recording time after playback, if it is less than
5 minutes. New messages cannot be recorded when:
— “Memory full” is heard.
— “ ” is displayed on the base unit.
— ANSWER ON indicator flashes rapidly (only when the Answering System is on).
Erase some, or all, of the messages in a mailbox. We recommend you erase unnecessary messages after each playback.
Erasing a specific message
Press [ERASE] while the message you want to erase is being played.
• A short beep will sound and the unit will continue to play the next message.
Press [ ][4] while the message you want to erase is being played.
Erasing all messages in the mailbox
1. Press the soft key ( ).
2. Press the soft key ( , or ).
• If Mailbox 2 or 3 has a password, enter it (p. 51).
3. Press [ ][5] to erase all messages in the mailbox.
• A long beep will sound and “Mailbox (No.)” and “No messages” will be heard.
• To end remote operation, press [OFF].
I hope you rate this solution. Thank you and goodluck!
Aug 05, 2009 | Panasonic KX TG5100M Cordless Phone
The correction tape isn't working. it's installed properly, i think, but it doesn't erase anything.
Try taking the tape out and re-installing with the "dull" side towards the paper...if that doesn't work try a new correction tape.
May 29, 2009 | Olympia Mastertype 3 Typewriter
Delete messages
This is from the manual.
Erasing Messages
You may erase messages in the following three ways:
To erase a message while it is playing
1. Press and release PLAY/STOP button.
2. Press the review and skip buttons to select and play the message you want to erase.
3. Press the delete button, the current message is erased, and the next message plays.
To erase all previously played Messages in a mailbox
1. Make sure the phone is OFF (not in talk mode)
2. Press and hold the delete button until "ALL OLD MESSAGES ERASED" is announced.
To erase a message from the handset :
1. Press the flash/answerer button on the handset
2. Press the play/stop (key 2) on the handset.
3. Press the erase (key 0) on the handset to erase a message during playback.
NOTE: Erased messages cannot be restored.
Jan 08, 2009 | GE 28112 Trio Cordless Phone
How do I erase text messages sent
when you are in your inbox or outbox press the menu key and scroll down to delete or delete all.
Mar 20, 2008 | Motorola Mobility RAZR V3
Erasing all phone numbers and user information on A650
Erase memory erases your Phonebook and Voice Dial recordings. This feature is useful if you want to give your phone to a friend or family member.
1. In standby mode, press the left soft key (Menu), then press 9 (Setup), 4 (Security). You're prompted to enter the lock code.
2. Enter the lock code (try the last 4 digits of your phone number unless you set a different one), then press 6 for Erase Memory. A confirmation prompt appears in the display.
3. Use the navigation key to highlight Yes or No, then press OK. A confirmation message appears in the display while your messages are being erased. Your phone then returns to the Security menu.
Reset Phone returns all setup options to their factory default.
1. In standby mode, press the left soft key (Menu) then press 9 (Setup), 4 (Security). You're prompted to enter your lock code.
2. Enter the lock code, then press 7 for Reset Phone. A prompt appears in the display asking if you wish to restore default settings (except for the Phonebook and Voice Dial).
Feb 05, 2008 | Samsung SCH-a650
Need to erase all programs
There are two ways of doing this.
Hit the 2nd key
Then the "+" key
Then the 7 key
Then the 1 Key
then the 2 key
This will delete your whole ram. and clear everything. your calculator will be fine but all your list and data that you might have will be gone
Or You can
hit the second Key
then the plus key
then the 2 key
Then hit enter
and you can delete the programs you want by pressing the del key
This will just delete your programs and nothing else
Dec 13, 2007 | Texas Instruments TI-84 Plus Calculator
Olympia Mastertype 3 Typewriter Logo
121 people viewed this question
Top Olympia Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Jim Keysor
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
