Question about Kohler Devonshire 2 handle Centerset Chrome Lavatory Faucet
How do i take off the handle off of a devonshire faucett
2 Suggested Answers
FixinFax
  • 3085 Answers
SOURCE: How do you remove the handle assembly from Kolher
Pry off the little red / blue plug and use an allen wrench to loosen the screw
Posted on Feb 20, 2010
I have a Kohler Finial K310 T handle faucett and when I turn on the hot water, drops come out from under the cold water T handle.
You have a bad seal on the cold side remove handle turn water off remove nut that holds thd stem in pull stem take Phillips screwdriver remove seal at bottom of the stem them put it all back together reverse of how you pulled it apart
Aug 12, 2014 | Plumbing
Moen Model CA87888 4-hole 2 handle and sprayer kitchen faucet. I just installed it and it only works with the sprayer. When I turn on the faucet (hot or cold), I am only getting a very small trickle. ...
Pull the screen off the faucett, from the new install you probably clogged the screen. If you get good flow without the screen, clean your screen out and re-install. You will need to twist off the piece and the end of the faucett to get at screen. Pay attention to how it comes out so you can put it back in the same way.
May 02, 2011 | Moen Home
Low pressure and diverter not staying on
remove the temp handle first decorative handle then brass sleeve under that brass should slide straight out you will see the mixing housing witch is brass cup shape piece about the size of washing powder cap there will be a small black plastic screen there pull out clean and replace then put back together should have good pressure which will fix diverter problem
Oct 01, 2010 | Kohler K-T396-4-BRZ Devonshire Single...
When open the faucett water comes from the shower head and faucett at the same time
Open the cover plate up at the faucett and replace the faucetts cartrage and rubbers, sound like somting in that region has parished
Hope that is the problem
Jul 19, 2010 | Moen & One Handle Tub & Shower Faucet
Cant shut water off on coldwater side on single leaver fauctt
is there a logo on the top of the handle,if so pry it off and there is a screw there,on some there may be a hex head screw on the back of the handle out of direct sight for looks
Feb 28, 2010 | Moen Monticello Single-Handle Kitchen...
How do you remove the handle assembly from Kolher Devonshire bath faucet model?
Feb 20, 2010 | Kohler Model 10433: FortĀ® Single-control...
We have a Devonshire pedalstal sink that is clogged and we can't snake with the P trap it just gets hung up. Plunging hasn't worked. Any ideas?
You need to remove trap and rod from the wall opening I have had to remove many pedestal sinks in order to rod the drain
Nov 15, 2009 | Kohler K-3488-0 White Devonshire...
The single handle fauchet will not stop running water.
Replace cartridge and insure that the C clip is not missing.
Sep 11, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Kohler Devonshire 2 handle Centerset Chrome Lavatory Faucet Logo
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
