Question about Kenmore 22313 Bagged Canister Vacuum
Motor on the powermate keeps cutting in and out.
Kenmore canister vac, plugged in, cansiter working, good suction from hose, when pushing or pulling the powermate, the motor cuts in and out.
  • cjackgo Apr 19, 2009
    I have the same isue, powermate keeps cutting in and out. I checked the connections and have held the end of hose to downtube joint tight and it still does it. I took apart the fitting at the powermate end where the cord loops around and into the powermate and can find nothing wrong. All the little power prongs have dark electrical-short type powder around them from the cutting in and out. Need to find a solution or a new vac.
  • 1,214 Answers
If your talking the motor on the beater bar, then chances are either when the beater bar was attached to the hose near where you hold it, it did not lock, and the connection is intermittent, or the cord has an internal break.
Posted on Jan 22, 2009
I have a Kenmore 116.27814702 canister vacuum where the powermate power keeps cutting off when turned certain angles. What part do I need to replace?
#1 Sounds like it might have a loose wire connection; #2 may be s bare wire touching inside and causing a short. Turning at angles may be causing the on and off of the power. Hope that helps
Feb 04, 2018 | Vacuums
It stopped working while I was using it . I tried to plugged in different electric outlets but it still dead. What should I do or look into in order to get it back to normal?? thanks
I would start by taking the wand apart. Be sure vac is unplugged from the wall outlet! You should be left with two pipe pieces, and the beater bar. I would also pull the hose from the canister unit itself. Once all the pieces are pulled apart, check the two or three prong wire connectors on each piece, both the female and male ends. If you have any dielectric grease, use a dab on each electrical connection. Once you reassemble, and still not powering up, wiggle the wand back and forth at the connection near the canister, and after the hose near where the switch is. If the vac cuts on after wiggling it, then you have a loose connection, and will need to tighten the female ends on the electrical connections, by squeezing them together slightly with a pair of pliers. Please rate if this works or does not work. Thanks!
Jan 03, 2011 | Kenmore 23612 Progressive PowerMate Bagged...
Kenmore Powermate power head not working
I've got the same problem. Try checking out the electrical connection where the hose attaches to the canister. The hot male terminal is corroded and the female socket is burned out. Its an unfortunate design flaw that every time you open the vacuum to replace the bag the electrical connection disconnects and reconnects. Not sure if I can find replacement parts for a 10 year old vacuum or if a home-made re-wiring job is in order. Will find out tomorrow.
May 30, 2010 | Kenmore 23612 Progressive PowerMate Bagged...
Vacuum doesn't ****
Assuming the unit (motor) runs ok and since it used, you may need to disassemble it and check the suction right at the motor. Sometimes there is a filter screen in front of it that can plug. The motor impeller could be partially obstructed or dirty, reducing the vacuum force. The bag should be the correct one for the unit or suction can be lost if it doesn't fit correctly.
Mar 28, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Motor goes on and off briefly at regular intervals
Sounds like you may have a bad or loose connection, could be one of wires in the hose to the handle harness or the harness itself may be causing the problem. Also be the motor or relay causing a problem.
Jan 08, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Vacum won't ****
Do you have good suction right out of the canister without the hose attached? If so, AND your hose isn't plugged, you must have a pretty good sized hole somewhere in the hose. If you don't have suction at the canister, pull the filter cover off the top-back of the machine and remove the filter. This is where all of the air that the machine pulls in is exhausted. If something is plugged here, it will greatly reduce your suction. If you still haven't found the problem, you could have a problem with the fan assembly on the motor. But usually this is accompanied by some noise from the motor, but not always. Good Luck!!
Jan 03, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Brush motor doesnt work
The cord at the bottom of the power head neck may be bad. But so could the plug connections in the hose handle, and the cord on the wand. Check both ends of the wand and make sure that the plug ends aren't burnt, if they are replace them and maybe the plug inside the hose handle.
Mar 24, 2008 | Kenmore 23613 Progressive PowerMate Bagged...
Kenmore 22313 Bagged Canister Vacuum Logo
461 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
