Question about Naxa Electronics Naxa NX-572 7" TFT LCD Color Television Television
NX-574 I'm trying to connect to my direct tv, through the antenna port and can not receive and reception. How can I correct this problem. Lou
Check if u are not on A/V mode, return to RF/TV mode and try tuning again, also check your antenna connexion.
Posted on Jul 13, 2007
SOURCE:
I have had a pioneer X-ray p970 f model.. had it for years. However getting radio reception has always been an issue. I live rurally. I would like ABC AM 720. Any ideas. Thani you Susan
A web search for your model turned up a blank. You aren't kidding about having it for years. I'll give you some generic information about AM radio reception and hope you find something useful.
Generally, AM reception is through a wire coil wrapped around a ferrite (very fast magnetic material) rod. Received signal strength is dependent on the angle between the rod and the radio station's transmitter antenna, so rotating it in a horizontal direction (around an imaginary vertical line through the center of the receiver) is often helpful. The angle of the best direction can be affected by nearby equipment (metal appliances, ductwork, computers, etc.)
Many non-portable audio receivers and a few boom box types have both an AM and and FM antenna terminal on the back. The FM antenna is very much like a TV antenna (you can use a TV antenna) and is generally required to get FM reception except in units with a telescoping antenna mounted to the case. The AM antenna is used to augment the coil signal, and is generally needed only if you are trying to pick up a weak signal. Attaching a wire to the AM terminal may help (make sure you have a good electrical connection between the terminal and the metal of the wire). This wire will also have an optimal angle for best reception. Try arranging it vertically; many AM radio stations transmit vertically polarized signals for the benefit of car radio antennas.The longer the wire is, the better, but it doesn't have to be very large. The physical limit is about 110 yards, the practical limit is how much you can stand to have stretched out behind the stereo. (A thin wire going up the wall to the hook behind a picture will probably not attract much attention.)
Portable radios often use a single telescoping antenna for both AM and FM along with the internal coil previously described. If you have this, experiment with antenna position and radio location. I have been told that some early model LED light bulbs may interfere with AM radio reception, especially if they are within a few feet of the radio.
Feb 26, 2018 | Pioneer Audio Players & Recorders
My vizio is set on avor antenna I have a HD antenna but TV won't pick up my favorite network stations wtva om nbc or abc
re-orient your antenna , the more the higher the better signal reception you will receive. and check your neighbor tv reception if they are facing the same problem with your tv , the problem isnt with your tv, its the tv network sometimes failed.
Nov 29, 2016 | Vizio Televison & Video
Yes hello, i'm trying to hook up my Coby 12'1 digital tv to a converter box is that possible or do i need a cable box for it to connect?
You should be able to connect the tv to a converter box. This is good for OTA signals to a TV with an NTSC tuner (coax) or composite video input. http://www.cobyusa.com/?p=prod&prod_num_id=205&pcat_id=2007#features-tab has the manual for the DTV102. Put the antenna coax cable to the converter box ANT In and then either the antenna out to the TV or the A/V (composite) out to the TV's composite in. If you use the RF connection, you will need to set the TV to channel 3 or 4 and set the switch on the converter box appropriately. For a composite video connection, you will need to change the input to AV1 (if there are several inputs). Depending on the TV, there may be a source or input button on the TV. For other models this is only on the remote. If you have the original remote, no problem. If you have a universal remote, make sure that you have a key that corresponds to the feature and that you found the code that lets the key work for your TV. (Not all universal remotes have the feature.)
However, you should get the best antenna that you can and have it pointed correctly to receive the stations. Digital signal doesn't have borderline reception. Try antennaweb.org or tvfool.com to check the stations and directions in your area. Antennaweb assumes an outdoor antenna but is very conservative in the channel list that it will indicate you can receive. Tvfool lists the channel reception depending on the antenna type. Tall trees and buildings can block the signal.
I hope this helps.
(please note that surges from the antenna can damage converter boxes and kill the tuner.)
Feb 08, 2011 | Coby DTV102 ATSC STANDARDDEFINITION TV...
My tv antena is broken and i ma trying to assembe the cable to the thing that goes into tv. Any instraction please? The tvcable is not conected to the conector which goes into tv. I peeled the placstic...
Hello
If your TVs internal telescopic antenna has broken, you can us an external antenna from connecting to the rear antenna socket. For that you have to buy some extend of antenna cable, and a yagi antenna; as it is better for reception. If your TV screen size is 14" or below, a small wire of length 2 mteres or so is enough. Buy one Balun coil assembly fro electronic sparepart shop, and connect this wire to it, connect it to the antenna socket at the back of the TV, and with picutre just wave it to some side where you get the maximum picutre clarity.
If you TV screen size is more than 14 inches, external yagi antenna shoud be used for claear transmission reception, and it must be directed well towards the tranmitter also. Alaingning it is a trial and error process, at which position you gets the clearest picture, without any Ghosts. OK.
Dec 29, 2010 | Philips Televison & Video
When trying to connect a phillips soundbar/dvd player into my tv using the HDMI cables/ports - it said it was not HDCP compatible. We tried teh different HDMI ports
If this equipment does cause harmful interference to radio or video reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures:
  • Reorient or relocate the receiving antenna.
  • Increase the separation between the W4207 HD Monitor and receiver.
  • Connect the equipment into an outlet on a circuit different from that to which the receiver is connected.
  • Consult the Westinghouse Service Center or an experienced technician for assistance.
DVI CONNECTION: Connect a Digital DVI cable from your computer to the W4207 HD Monitor DVI port. Using a 3.5mm mini cable to RCA Red/White (Left/Right) audio converter cable, connect the 3.5mm cable plug into the computer
Dec 13, 2010 | Westinghouse W4207 42 in. HD-Ready LCD TV
Improve reception
HI there,
Well Yes you can improve the reception, please follow the below steps -
Improve FM Radio Reception -
1. If you don't have an antenna connected to your FM receiver, purchase a simple dipole antenna--a simple T-shape flexible wire-- and connect it to the FM antenna inputs on the receiver. Because FM signals are directional, you'll want to experiment with the positioning of the wire to find the best reception of the station you're trying to receive.
2. If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
3. If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
4. If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
5. Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
Improve AM Reception -
1. Gradually rotate the radio 360 degrees. Leave it in the position where it sounds best.
2. Reverse the AC plug if it isn't polarized. (If you can flip the plug over, then it's non-polarized.)
3. Plug the radio into a different AC outlet.
4. Move the radio closer to a window.
5. Experiment to learn if appliances and powered products in your home are causing interference: computer monitor, television, electric blanket, light dimmer, fluorescent light, hair dryer, air conditioner, smoke detector. If possible, turn off the offending item. Otherwise, move the radio to another room.
6. Upgrade to an external antenna if your receiver, tuner or radio has a place to connect one.
7. Buy a passive AM antenna that doesn't need to be connected to a radio or receiver.
Good Luck!!
Thanks
Dec 29, 2009 | RCA RP5430 Clock Radio
I get no stations on my tv
Use an Antenna that Provides Good Reception of All Channels
  • Most existing antennas used by consumers will provide good reception of DTV signals. (Before making any changes, try your existing antenna first to see of it allows you to receive all the stations you normally watch.)
  • For watching DTV signals, you will need an antenna that provides good reception of both VHF signals (channels 2-13) and UHF signals (channels 14-51) to reliably receive all of the digital signals broadcast in your area.
  • Many antennas are designed only for reception of either VHF or UHF signals (but not both). For example, the commonly used “rabbit ears” indoor antenna is only suitable for receiving VHF signals. To receive UHF signals, an indoor antenna should also include a wire loop or other feature for reception in that band.
  • The reception capabilities of TV antennas also vary considerably, so be sure to talk to retail consultants and look at information on the packaging and/or the Internet to make sure that any new antenna you may choose provides good reception of both VHF and UHF channels. In addition, if you use an indoor antenna and receive signals on VHF channels, you may need to use an antenna with amplification.
  • Many antennas currently being sold as “HDTV Antennas,” perform best at receiving UHF signals; some of these models state that they provide reception of signals on channels 7-13 but actually perform less well receiving those channels. If you obtain one of these antennas, be sure it provides good reception of all the VHF channels as well as the UHF channels.
  • To check for the DTV signals that are available at your location, use the DTV Reception Maps available at www.fcc.gov/mb/engineering/maps.
Check Your Connections
  • Check that your digital-to-analog converter box or digital television is connected properly. Make sure your antenna is connected to the antenna input of your digital-to-analog converter box or digital television. If using a digital-to-analog converter box, also ensure that the antenna output of your converter box is connected to the antenna input of your analog TV. Refer to the owner’s manuals of your components if you are unsure of the proper connections.
  • Ensure that your components are plugged in and have their power turned on.
  • If you have a digital-to-analog converter box, tune your analog TV to channel 3. You should see a set-up menu or picture displayed on your TV screen. If you do not see a set-up menu or picture, tune your TV to channel 4. If you still do not see a set-up menu or picture, recheck your connections.
Perform a Channel Scan
  • Digital-to-analog converter boxes and digital televisions have a button, usually on the remote control, that is labeled “set-up” or “menu” or some similar term. Press that button to access the set-up menu. Using the directional arrow buttons on your remote, scroll to the option that allows you to perform a “channel scan.” The channel scan will automatically search for digital broadcast channels that are available in your area. Consult the owner’s manual of your digital-to-analog converter box or digital television for detailed instructions on how to perform a channel scan for your device.
  • Once the channel scan is complete, you will be able to tune to the digital channels received by your antenna. You should perform a channel scan periodically to check whether additional digital channels have become available.
Adjust Your Antenna
  • Small adjustments to your antenna can make a big difference in the number of digital channels you can receive. If you have an indoor antenna, try elevating it and moving it closer to an exterior wall of your home. After adjusting your antenna, perform another channel scan to see if your reception is improved.
  • While adjusting your antenna, it may be helpful to access the “signal strength meter” on your digital-to-analog converter box or digital television to determine whether your adjustments are improving the signals’ strength. The signal strength meter is usually accessed through the menu feature on your remote control. Refer to the owner’s manual of your device for detailed instructions on how to access its signal strength meter. Remember to do another channel scan after you have adjusted your antenna.
  • Television stations broadcasting in digital use both the VHF band (channels 2-13) and UHF band (channels 14-51). Many indoor antennas use “rabbit ears” for the VHF band and a “loop” or “bow-tie” antenna for the UHF band. Make sure you are using an antenna that covers both the VHF and UHF bands and have connected it properly.
If You are Still Having Difficulty:
  • Until June 12, 2009, some stations will be operating at reduced power levels. If you are not receiving certain digital TV stations, this does not necessarily mean there is a problem with your antenna or digital-to-analog converter box or digital television. Check with the TV station to find out whether they are planning changes that will improve reception.
  • When an analog TV signal is weak or receives interference, static, snow, and distortion will often appear on the screen. Digital broadcasting will provide a clear picture; however, if the signal falls below a certain minimum strength, the picture can disappear. This “cliff effect” means that if you watch analog TV stations that have static and distortion, you may have to adjust or upgrade your antenna system.
  • Simple indoor antennas provide minimal performance that may not be suitable for your location. If you are unable to obtain satisfactory DTV reception with your current indoor antenna, you may wish to obtain an indoor antenna that includes features for better reception of UHF signals, as well as VHF, and/or an amplifier to boost the received signal (often referred to as an active indoor antenna).
  • Generally, an outdoor antenna will get better reception than an indoor antenna. However, the performance of outdoor antennas can degrade over time due to exposure to the weather. If you are having problems, check for loose or corroded wiring, broken antenna elements and that the antenna is pointed in the right direction.
  • Try to keep the length of wire between your antenna and digital-to-analog converter box or digital television as short as possible for best reception.
  • “Splitters” that are used to connect a single antenna to multiple digital-to-analog converter boxes or digital televisions reduce the amount of signal available to each device. If you are having problems, check whether reception is improved without the splitter. In some cases an “active” splitter that includes an amplifier can solve the problem.
  • If you are near a station’s broadcast tower, reception of that station, as well as other stations, can be impeded by strong signal “overload.” Consider using an “attenuator” or removing amplifiers to improve your reception.
  • If you decide to replace or upgrade your indoor or outdoor antenna, many types are available from electronics retail stores at a variety of prices. Websites such as www.antennaweb.org provide information on the locations of broadcast towers and the types of outdoor antennas appropriate for the stations you wish to receive. If you need assistance with upgrading your antenna system, check with a local antenna retailer or antenna installer.
Hope it may helps:
Regards:
VOTIT
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Are there any boxes that don't require 'autoscan' for setup?
How to connect a motorola DCH3416 to a computer?
Feb 19, 2009 | Televison & Video
DTV connection
Have you tried http://www.antennaweb.org/aw/Address.aspx? This will show you the location of the HD broadcast towers for your local stations and my recommendation would be to use an outdoor antenna if you can. Picking up the reception is definitely about pointing the antenna in the direction of the towers.
Nov 10, 2008 | Televison & Video
Naxa NX-511
Yes, you can. I was able to get my Dish Network remote to work with my Naxa 574 TV. Just follow the directions for the remote and you should be able to use it.
Dec 12, 2007 | Naxa Electronics NAXA NX-571 Television
Naxa Electronics Naxa NX-572 7" TFT LCD Color Television Television Logo
145 people viewed this question
Top Naxa Electronics Televison & Video Experts
ray gallant
ray gallant
Dung Maurice
Dung Maurice
Level 1 Expert
Are you a Naxa Electronics Televison and Video Expert? Answer questions, earn points and help others
