Question about Ricoh Lanier LD328C Black Toner 24000 Yield Type R1 - Genuine OEM toner
Lanier ld328c no toner message - Ricoh Lanier LD328C Black Toner 24000 Yield Type R1 - Genuine OEM toner
  • brent Yoder Jan 12, 2013
    we have replaced the toner but still getting no toner error
2 Suggested Answers
Cogz
  • 1326 Answers
SOURCE: lanier 5227 add toner message
I take it you have installed a new toner???? Do oyu know the last time the drum & developer unit was replaced?? It is sold as a unit with the developer in the unit. It is a customer part to replace. If these parts were replaced resently, the problem could be in the toner holding unit that you put the toner bottle into... There has been some up dates to that unit > they improved the fin's that moves the toner into the developer unit... Good Luck
Posted on Feb 24, 2012
Lanier 5235
The waste toner is contained inside the belt unit that is mounted on the inside of the right hand door. Remove the screws that hold it together and dump it. Very messy so be careful. The message will go away by itself.
Jul 02, 2014 | Lanier 5235 Printer
Lanier 335c toner won't load
If the toner hopper assembly is not broken the mylars inside of it have fallen off over time. The toner supply unit needs to be replaced.
Apr 25, 2014 | Lanier Ld328c Ld335c Type R1 Toner Black...
Not want to read the new toner
Very, very common issue on these normally related to a problem in the toner hopper assembly itself.
Feb 08, 2014 | Lanier Ld328c Ld335c Ld345c Black...
Lanier LP235c display says Add Yellow toner
Try removing the toner cartridge and gently cleaning the electrical contacts for the sensor. Sometimes they get toner residue on them and give false readings.
Aug 04, 2012 | Lanier 5235 Printer
How do I remove the hard drive from a Lanier LD328c. This needs to be done for security reasons.
You should contact a Lanier or Ricoh service technician to remove the hard drives for you, but if you have to do it yourself the hard drives can be removed by unscrewing and sliding out the controller board (on the right side of the copier). The hard drives are connected to the controller board by three screws and four connectors.
Sep 23, 2010 | Lanier UNKNOWN
Lanier 6720 U14 error on screen
U14 is a user code for waste toner full.
Open front cover and you will see a clear plastic bottle at the bottom of the machine; lift this out and dispose carefully of waste toner (do not reuse). When fitting back into machine, make sure that inside of bottle is clean as the detection sensor looks through the bottle to see if it is empty and if toner is covering inside of bottle, the message will remain.
Apr 20, 2010 | Lanier 5235 Printer
Lanier LW324 waste toner bottle full
Open the machine and to the right under the drum you should see the the black powder (toner) going down into container the right lower side  cover must come off. probably a service call will be needed
Apr 20, 2009 | Lanier Office Equipment & Supplies
I have a lanier lp-138c that is giving me a black toner low message on brand new cartridges... Tried 3 different cartridges and at first they register and then to the toner low...
It could be that the black developer unit is clogged. The toner low sensor is located in the black developer unit. A trained copier tech may be needed to troubleshoot this.
Apr 14, 2009 | Lanier Office Equipment & Supplies
Full Waste Toner Bottle in Lanier LD040
Hello sir; I believed you talking about LD045, am I right? In this model it doesn't have waste toner bottle, the only place you can clean is imaging transfer unit, after you cleanup the message will be disappear.
Apr 10, 2009 | Lanier Office Equipment & Supplies
Ricoh Lanier LD328C Black Toner 24000 Yield Type R1 - Genuine OEM toner Logo
46 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
