Im having trouble starting my acer laptop, iv tried pressin f2 and f8, and tried pressing safe mode options and others available, but it just goes onto the windows loading page and then to a black screen and a big white cursor, can you help please?
  • sezzer642 Jan 22, 2009
    hmm thank you, but i dont know how to do that?
    Sergeant:
    Champion:
  • 242 Answers
Try use last known settings that worked. If that doesn't work,reload your operating system, sounds like something might be corrupt.
Please rate my awnser. Thank you.
Posted on Jan 22, 2009
How can i reset password of acer extensa 4620z
Hi chubico04...
Try this solution to your problem.
Start your computer
1. Keep pressing "F1,F2 or F8" as the laptop computer starts.(Depending on your computer)
This will start the computer in Safe Mode.
2. When the window "Advanced Boot Options" opens, choose "Safe Mode" with arrow key and confim by pressing the Enter key, then PC enters the Safe Mode.
3. Once you are in the Safe mode Click "Administrator" on the Windows login screen.
Take note that you have set the Administrator password before, you need to input the changed password instead of leaving "Password" field blank.
4. Then click Start > Control Panel > User Accounts > Select the account that is locked and change the password.
5. Restart laptop and login into the account you just created using your new password.
Please take time to rate me thumbs up
Sep 27, 2011 | Acer Extensa 4620-4648 Notebook
I forgot the password to my laptop acer
Hi junior 707
Start your computer
Sep 26, 2011 | Acer Aspire 3000 Notebook
How to activate safe mode on acer aspire
press f5 at acer logo appear at start up, then chose safe mode
i hope this helpfull, please rate very helpfull if you think this helpfull
thanks for using fixya
Jan 22, 2011 | Acer Aspire 3623WXCi Notebook
I have an acer aspire one notebook, last night while i was on the internet it froze up. I powered it down and it will not restart. You can see the battery lights light up and hear the fan running, its not...
When you hit F2 it takes you to the BIOS menu, and that's where you should go and while in there go to Boot, and using arrow keys select the one that says IDE WDC and move it with F6 to position 1. Then press F10 and select Yes. Restart and it should work. Post back if still having trouble.
Dec 07, 2010 | Acer Aspire One PC Notebook
Hi im having trouble with getting my desktop to come up. its just showing start thats it and saying location is not availble
It sounds like you have maybe two problems.
Firstly, press start and when it shows the BIOS menu, press F2. Select default settins from the menu and save with F10.
Press start again, if it doesn't try to load after the POST, (BIOS menu) and press F8 as it is starting to boot up. Select Safe Mode and let it run until it has finished loading. Close down and it should have repaired itself. If it hasn't, and I am assuming it does get past the BIOS menu because if it doesn't there is a MotherBoard fault and it will require technical support through Toshiba.
If it doesn't load but gets past POST, as it finishes the BIOS option menu, (F2 or F12) press F8 and select recovery. Follow the prompts and that should sort your problem out.
Hope that helps.
Nov 28, 2010 | Toshiba Computers & Internet
Acer 5620 pressing f8 at start wont load bios either
F8 is usually reserved for Windows Safe Mode. BIOS settings are usually found with by pressing ESC, Delete, or F2 on most system. Some times I run my finger along the entire row of function keys like a piano if it isn't specified which key works during boot up.
Mar 19, 2010 | Acer Extensa 5620-4020 Notebook
My Acer Aspire 1500 laptop wont pass startup.
It seems that your laptop hardware is good and it seems that it is a software issue.
  1. Boot in safe mode: When your laptop start, press the F8 key. then it will ask you which boot device to boot from, browse using the arrow keys and chose something with HDD and press ENTER and then press the F8 key again. Then you will be given a boot option and choose SAFE MODE.
  2. While in SAFE MODE, try to uninstall your newly installed software that might be causing the laptop to hung up.
  3. Also, click Start => Run then type: msconfig.
  4. Go to the Startup Tab and uncheck the many programs that looks not necessary to load while windows is loading. The program like Yahoo Messenger, Skype can be opened manually so uncheck them if present.
  5. Click Apply then OK.
  6. Restart your laptop and see if it helps.
Feb 23, 2010 | Computers & Internet
Cant get into safe mode. tried toggling f8/f7 together but nothing
the key to getting into safe mode....tapping F8 (only that key) super fast, not stopping until you hear a beep...and see the option to boot into safe mode.  The most common reason that it will not work is that it is not pressed fast enough or early enough.  You will know that you missed your chance if you see the windows loading screen......start pressing it right away when you restart your computer and don't stop pressing F8 until you see the black screen with the white letters giving you the option to boot into safe mode.
Good Luck!
May 08, 2009 | Acer Aspire 5100 Notebook
Unlocking laptop from safemode.
Boot the PC with tapping F8 Key during start. It will give you option for selection of Safe mode.
Let me know what the screen shows in both mode. Any error message will help out to fix the problem
Oct 05, 2008 | Acer Computers & Internet
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
