Question about Alpine CDE-9872 Car CD/ MP3 Player
Alpine car CD player stopped working
CD player stopped working. faceplate doesn't light up when attached. the fuse under the hood isn't the problem. even tried a replacement faceplate for it. what could be issue?
5 Suggested Answers
KaeZoo
  • 156 Answers
SOURCE: Alpine car cd player has no volume
It's possible that you have a shorted speaker wire. If one of the speaker wires is pinched, grounded or shorted it will cause the deck's internal amplifier to shut down. The easiest way to check is with a multimeter's resistance function. Remove the CD player and unplug it. Set your multimeter for "resistance" or "continuity". Attach the black probe to chassis ground; you can use the black ground wire in the deck's harness, clean dash metal, or the outer ring of your cigarette lighter. Use the red probe to test each of the speaker outputs in the harness: white, gray, green and violet. If you find a speaker wire that shows any continuity with chassis ground, then that's the cause of the problem. A speaker with a damaged voice coil may also cause the deck to shut down. To test this, probe the positive and negative leads of each speaker and test the resistance between them. For example, to test the left front speaker you'd put the red probe on the white wire and the black probe on the white/black wire. Each speaker should read a minimum of 3 ohms of resistance. If you get a lower reading then it might be causing your problem. If you don't find a problem with any of the speaker wires, then chances are the deck's internal amplifier has failed.
Posted on Jun 09, 2007
  • 48 Answers
SOURCE: car cd player
You shouldnt have any problem at all. These don't use any special anti-theft features that would keep you from using any faceplate.
Posted on Oct 21, 2008
Ironfist109
  • 3018 Answers
SOURCE: I have an Alpine CDE-9881.
  • HI, I can help.
  • First thing is to remember that this head unit can only be used with 1 4th generation and above I-Pod. 1st, 2nd and 3rd generation will either not work or have issues. So check your I-Pod.
  • Another thing to remember is that where the jack for the head unit plugs into the i Pod, they do get weak and begin to not connect. An i Pod in the car gets jerked around a bit more that just listening to it and that jack input can start to fail.
  • If you unplug the i Pod and use the buttons on the head unit that are used to access search mode or to search, do them buttons work as they should?
  • It could be any of the things I suggested. If it is because of the head unit, which I am not so sure of, then this would be a software issue. It would have to be repaired by a tech at Alpine as they have the software for their head units.
  • If you have any comments please feel free to leave them here and I will respond to you.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Sep 18, 2011
  • 102366 Answers
SOURCE: i have an alpine cd player cde9845 in my car. how do i set the clock?
Follow the instructions on page 15 of the manual.
Posted on Oct 22, 2012
2002 Lincoln LS cd player won't work after battery
Try checking all of your fuses. Quite often a fuse blows when batteries or alternators are changed. There should be a fuse box in the engine compartment and another under the dash.
Feb 12, 2012 | Alpine Car Audio & Video
Alpine amp not working.
possably, did you get it professionally fitted? they have lifetime warranty on install,
Apr 22, 2010 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Hold is on and nothing will will work how do i turn off hold on a alpine cda-7892 cd player
Try resetting it. Also if it won't reset using the reset button found behind the faceplate. Take off the negative battery cable under the hood this should reset everthing. Then replace it. If it is old and the motor is having trouble kicking the cd out then stick a used no good cd in on top of the other cd and use it to apply pressure to the cd in the player then pull it out after pressing eject
May 31, 2009 | Car Audio & Video
CD player wont come on was doing weird things
You have your accessory wire (red wire) and remote ran together and the yellow (constant wire ran separately in the dash?
You need the red wire to so you can use accessory and to turn off your cd player when your vehicle turns off.
You need the yellow wire to keep all your settings stored. base/treble/time clock
Just a little clarification. Your amp turns on with the remote wire (blue) wire, if that is not hooked up you will get no power to the amp.
Here's the in-dash diagram to your vehicle at the bottom of this pdf.
http://www.installdr.com/Harnesses/Ford-Wiring.pdf
You want to focus on N,O, and P
Do you happen to have an after market wiring harness? These can be bought from walmart for your vehicle. You just take the male end connect the colors together and plug end that goes to your cd player into the female end. Very easy to do.
Windshield wiper issue: http://www.allfordmustangs.com/forums/attachments/4-6l-tech/32492d1188791176-2003-mustang-fuse-box-diagram-2003-enginefuseblock01.pdf Check C1002, 1003, and 1004 under your hood.
You could also have one of these fuses out under your hood, that might cause you to lose power to everything.
http://www.allfordmustangs.com/forums/attachments/4-6l-tech/32493d1188791176-2003-mustang-fuse-box-diagram-2003-enginefuseblock02.pdf
Let me know if you need more assistance =)
Feb 01, 2009 | Kenwood KDC-MP238 CD Player
Car cd player
Oct 21, 2008 | Alpine CDE-9852 CD Player
VRX745VD
Shortly after this happened to me, the whole faceplate stopped lighting up. Then all buttons but the power button worked. From what I'm seeing I feel that this is from bad capacitor, but I don't have the time to rip it apart right now. Till then, it's a cheap Alpine MP3 player.
Aug 27, 2008 | Clarion VRX745VD Car Video Player
This radio has no power.
make sure you check the fuses. on the door panel and under the hood. usually with any car their is 2 radio fuses. one under the hood and one by the driver side door. a blown fuse could be an easy/fast fix.
Jul 05, 2008 | Dual XD-7500 CD Player
Alpine CDE 9881
You must have a faceplate from that exact model, no others will work. You can try to contact Alpine for a replacement. If it is any consolation, someone has a useless faceplate, because it won't work with anything else, either. Try running an ad in your local lost & found column, you just might get lucky, especially if you offer a reward.
Jul 28, 2007 | Alpine CDE-9881 CD Player
Alpine CDE-9872 Car CD/ MP3 Player Logo
21 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
