Question about Jenn-Air SCE30600 Slide-In Electric Kitchen Range
None of the heating elements work
I have a Jenn-Air sce30600b, I was cooking dinner last night, oven and stove were working just fine, then right in the middle of cooking, everything stopped working. The stove top elements and the oven. The clock, and the led's on the front of the stove work fine, but no heat is coming from anywhere. Is there some kind of control panel or master circuit panel that controls everything that can be replaced?? Thanks for any help
  • g8rfan23 Jan 22, 2009
    Is this the board on the back of the stove? I replaced that a few years ago? If that's it again, it was a simple repair, I can do it again, but if it's something else, I don't want to waste the money. Do you know the part number? Thanks again...
  • Jenn-Air Master
  • 19,396 Answers
It can be the control board, the thermal fuse at the back of the unit, or a lose contact on the wiring harness.
You need to test parts before replacement.
Here you find all diagrams and parts for your appliance.
Posted on Jan 23, 2009
  • 8,197 Answers
You need to replace the ecb electric control board. It went out n you
Posted on Jan 22, 2009
  • Jyackle5
    Jyackle5 Jan 22, 2009
    You might want to have a repair person out to do this.
  • Jyackle5
    Yes that is the board. I do not have a part # though.
While cleaning oven I lifted bottom element heard a pop. Now neither the stove or oven will not come on. The indicator lights do not light up either.
The "pop" was the sound of the heating element shorting to ground so naturally nothing works now.
Jan 18, 2017 | Ovens
What's wrong and how do I fix it?
The circuit breaker outside in the power panel for the stove has a bad breaker. It will be two breakers with their handles joined together by a pin so if one tripe it takes the other so 220 V is no longer present. When one, but not the other trips you only have 110 V. That's why the lights and clock still work but no heating elements.
Nov 16, 2015 | Frigidaire Kitchen Ranges
Oven won't heat
hi, sounds like the heating element
Mar 07, 2010 | AEG U3100-4 Electric Double Oven
Jenn-air stove Model SCE30600B. Won't heat
check all the wiring at the main bus, and at the board connections could be a bad board
Oct 08, 2009 | Jenn-Air Ovens
Jenn-Air electric wall oven door opens slightly when in bake mode
you either have a bent door hinge or a broken door spring.
check the hinges by opening the door and see if it opens past 90 degrees. if it leans towards the floor then the hinges are bent.
if not then your door springs are broken off. you can check this by seeing if the door "feels" heavy when opening.
either way the door should close tight against the frame when up and the light should not come on without opening the door.
Jan 22, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
No heat
You probably still have cartridge fuses in your fusebox. This sounds like only one blew. This will let the lights and other 110 volt things work just fine. If you have circuit breakers it probably needs to be replaced. There are no internal fuses that involve the whole stove.
Jun 09, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
No heat in oven or on range
when you turn on the top burners do you hear the ignighters clicking please hold my rating for now as i need to ask a few questions
Jan 11, 2008 | Frigidaire FES367 Electric Kitchen Range
Stove top and oven will not heat
first check your voltage, and the pigtail connections at the stove, then check your elements inside the oven something has shorted
Oct 27, 2007 | Frigidaire FEF366DC Electric Kitchen Range
Jenn-Air SCE30600 Slide-In Electric Kitchen Range Logo
135 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
