- Pull out the battery, and then reinstall it. Power on the phone and you should be able to access your information.
The following procedure will allow you to perform a factory reset, which would require access to the Standby Screen, and Menu. If you are just trying to access your phone, reset the battery.
To reset the handset to
the factory default settings, follow the steps below:
- From the standby screen,
press Menu
- Press Settings
- Press Reset Settings
- Press on any of the following to check their boxes:
- All: Sound Profiles, Display & Light, Phone and Alarm settings will be returned to default values
- Sound Profiles:
Only
sound profile settings will be returned to default values
- Display and Light: Only
display settings will be returned to default values
- Phone: Only
phone settings will be returned to default values
- Alarms:
Only alarm settings will be returned to default values
- Press Reset
- Enter the password default password is "0000", then press OK
- If prompted, Enter the password
again to confirm then press OK
- Press Yes to Reset the handset's settings to the factory defaults
I’m happy to help further over the phone at
https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
