Question about Acoustic Solutions Audio Players & Recorders
Surround sound not responding
Hi, i have a problem with my acoustic solution DS 833 surround sound. I cannot change it from optical to auxilary in the sound input, and now the optical will not work either. as there are no manual controls i only have my remote to work from and i have checked battery. i can see the volume working, however, pressing anyother button does nothing
    President:
  • 2,559 Answers
Hi,It sounds like you have a burned out amp,or Ir board,Which could be repaired at a local Tv or radio repair shop.
But since the Acoustic solution website has been shut down since 2006,I don't know of any way to contact them or get a manual or any other info.
Sorry I couldn't be more helpful.
Please rate this fixya solution
Posted on Jan 23, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, since there are no other forms of control for the DS833, possibilities then are limited to:
  • unplug the unit for an extended period of time. Normally, this would revert the unit back to factory defaults;
  • replace the remote's batteries. It may be necessary to clean/scrape the battery contacts to ensure a more pressure to the battery terminals;
  • at times, the remotes keys/buttons tend to be fault. Open the remote and clean the pads underneath the keypad. Cottonbuds and alcohol would be sufficient to;
  • internal fault on the logic/switching circuitry of the DS8333. Familiarity with electronic circuitry & components is required to effect repairs/diagnosis. Perhaps your best bet would be to seek the services of q a qualified professional.
Pls post back updates. Good luck and thank you for using FixYa.
    Brigadier General:
  • 5,158 Answers
When you check the batteries that was without a load on the batteries. replace it with a fresh battery and try it again.
Hi all, I'm using a Sony BDVE 280 surround sound
no u will not be able to because you would have two seperate sources like to listen to ur iphone ud have to put ur surround sound on auxilary while for xbox ud have to have it on something else which ever port ur xbox is pluged into ur surround sound at or whereever ur tv is pluged on ur surround sound
Apr 17, 2013 | Audio Players & Recorders
Hoooking up surround sounds with optical cable surround system is RT2280 AHHH please help my husband is driving me crazy to get it fixed and he cannot figure it out. Superbowl must be in surround sou
Make sure the digital setting (optical/coaxialor analog)is correct.
If youre connection is differet from default setting
1.select the source
2.press function
3.rotate multi jog to toggle among optical/coaxil/analog to match
yuor connection.
your selection will be stored automatically.
every time you press the source button the input setting(dvd/opti)
will be show on display.
heres a link to the manual go tto page 21 advanced settings.
http://www.google.co.uk/url?sa=t&rct=j&q=surround+sound+RT2280+AHHH&source=web&cd=4&cad=rja&ved=0CEMQFjAD&url=http%3A%2F%2Fsupport.radioshack.com%2Fsupport_audio%2Fdoc66%2F66651.pdf&ei=G2QMUbKqMOOY0QWJlYBw&usg=AFQjCNG2gc-bExNRynH2JEV22sR-L_ggDg&bvm=bv.41867550,d.d2k
Feb 02, 2013 | RCA RT2280 System
I have audio cables going from HD 61g887 jvc tv, to my phillips surround sound system under aux but it is not giving me sound?
hi
you didn't mentioned the model number of your surround sound system, for a better solution its important. any why try the following.
if you are connected the analog audio output of your tv to the system using RCA cable, then go to the setup of the surround sound system and change the input assignment setting from digital to analog.
If your connected the digital output of your tv to the digital input of your surround system using optical cable then, goto the setup of your surround system and change the input assignment to digital (optical) input.
if u need any further assistance fell free to contact through fixya
Jan 20, 2011 | JVC HD-61G787 61" Television
E320VP LED HDTV just purchased. How to I hook up to a home theater system if it has no optical input jack? Thanks.
You should be looking for an optical output on the TV and an input on the home theater. if you mean the home theater has no optical input then you will have to resort to using RCA cables, they wont provide surround sound but most TV channels wont use surround anyway. They are the red and white sockets on the TV. If you need further help please respond with the brand and model of home theater system
Jan 11, 2011 | Vizio Televison & Video
My surround sound will not work through the TV, only the DVD
If your tv and surround has an optical input/output.Then you can connect with an optical lead.This will then play the sound from whatever you are watching.You normaly select dig1 or input1 on the surround system.
Nov 12, 2009 | Panasonic Televison & Video
Need installation manual for acoustic research headphones
I have lost the manual of my RCAmodelnumverWHP150 how can I find another one?
Feb 23, 2009 | Acoustic Research Audio Players &...
Rear speakers no sound
you have to have it set to one of the sound settings to get surround sound , and if what you have hooked up does not have a digital connection ( optical or coax) you can not get dolby digital surround either
if it is the stereo your listening to then set a sound to get virtual surround sound ( unless you have a digital tuner that supports digital signal input
Oct 26, 2008 | Audio Players & Recorders
I cant rig up my surround sound to my tv
Run a phono cable from the tv output to a input on your system,select this input and you should have sound,if not go to tv menu for sound set up as some tv,s need the output turned up or even to be switched on.
hope this helps.
CABLE GUY.
Jun 30, 2008 | Audio Players & Recorders
Sound problem
I have a creative SoundBlaster LIVE! 24 Bit External Sound Card and this annoyed me for weeks.
depending on your surround sound reciever depends on the solution.
i have an Acoustic Solutions surround sound system with coxial and optical inputs, aswell as stereo red & white jack inputs.
not knowing the method or connection your using makes it difficult to give you a single solution so i'll list a few.
The soundblaster software shoudl include the Creative Audio console with all sorts of effects, one is CMSS (CMSS-3D) Stereo widening which is still stereo but gives a surround sound effect.. but i'm guessing you payed for 5.1 and you want 5.1 onto the next part
5.1 surround sound can only be produced when the actuall audio your playing contains 5 channels of audio, for example you cant play a stereo song in 5.1 surround sound without some sort of hardware or software sound manipulation. Luckily my surround sound system has Pro Logic II built in and some other effects which convert a 2.1 signal to a 5.1 signal and it works brilliantly. I'm not sure of a software alternative.
setup for your soundcard will be different under XP and Vista also, but there should be a properties option for your sound device where you can select your speaker setup such as headphones, built in speakers, 2.1 speakers, 5.1 speakers, 7.1 speakers and you should be able to manage this from the creative software.
If using Coxial / Optical or SPDIF under vista you MUST set the playback device as SPDIF, at least you have to with my sound card and drivers and seems to be a limitation of the actual sound card drivers for vista.
Personally i was looking forward to hearing the windows login melody in 5.1 surround sound too, but this doesnt happen.
Infact i find that almost all programs bar a few will not play Dolby Digital or DTS 5.1 surround sound via any or my output options hence the next solution..
if you have the 5.1 sound but winamp simply just plays it in stereo try the following.
You need to use DirectSound Output:
Preferences (Ctrl-P) > Plug-ins > Output > Select "DirectSound Output"
That should work in most cases, but if not, then:
Checkmark: "Allow hardware acceleration" in DirectSound Output config,
and make sure your sound card/chip is selected as Output Device.
Note that any changes will take effect only after playback is restarted.
In some cases, a Winamp restart is required.
If that doesn't work make sure you have the latest version of DirectX
(v8.x or higher is required)
Winamp 5.25/5.3 and higher:
For actual multi-channel files (ie. aac/wav/ac3/ogg/wma files encoded in 5.1ch surround, as opposed to standard 2-channel stereo mp3's), you need to checkmark "Allow surround sound" in 'Winamp > Prefs > Playback' for the music to play in its original 5.1 channel format (Note that this setting is checkmarked by default).
Windows Vista:
In addition to the above instructions, Vista users will also need to go to:
Control Panel > Sound > Playback tab > Speakers > Configure:
Select: 5.1/7.1 Surround.
Then:
Control Panel > Sound > Playback tab > Speakers > Properties > Enhancements tab
and checkmark "Speaker Fill"
Hope this helps
Anthony Kinson
Apr 22, 2008 | Audio Players & Recorders
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
101 people viewed this question
Top Acoustic Solutions Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Acoustic Solutions Audio Player and Recorder Expert? Answer questions, earn points and help others
