Question about Ricoh Aficio 220 Laser Printer
I have Aficio220 prblam is that Internal tray 1 is full remove the copies
4 Suggested Answers
  • 4 Answers
SOURCE: ricoh 2022sp internal tray 1
Where the paper comes out there is a little black thing that is supposed to stick out. Somebody has pushed it in.
Posted on Sep 01, 2008
  • 86 Answers
SOURCE: I have a ricoh Aficio
Please you must remove the copies from the output tray.
If you don't have copies in the output tray, check for a black lever at the middle of the exit rollers. It can be either stucked or broken.
If you want this lever can be folded inwards.
Good luck and please rate me, thanks.
Posted on Jan 15, 2009
  • 903 Answers
SOURCE: I have a ricoh aficio 220 and it says internal
There is a sensor above the tray where the paper comes out, and that sensor has a long black actuator. Sometimes that actuator gets turned to the side, and this will cause that message to appear.
Reach above the rollers where the paper exits the copier, find the black actuator, and turn it so that it is hanging down over the tray. Once the sensor is reset that message should disappear.
Posted on May 29, 2010
What does it mean when my dell copier says output tray full
It means that where the copies come out it is too full. This is to help you avoid jams. Remove the copies from the tray. In some printers you may have to push a button in order for it to reset itself to print. Most manuals for printers can be found on line. Just google manual for your model number.
Oct 01, 2014 | Dell Office Equipment & Supplies
Copystar cs1510 showing error e70 please help
The E70 its a troubleshooting original placement and memory errors:
1. Remove originals and replace them in the original table when the "E70" or "E71" errors display.
2. Remove originals placed on the original tray and allow the copy job from the plate to complete when the "E72" error displays.
3. Remove originals remaining in the original table when the "E90" error displays, indicating that the memory is full. Press the button with a "%" sign on it, labeled recall, to print the copies of the originals that have already been scanned. When printing completes, place the remaining originals back into the original tray and press "Start" to continue copying.
Hope helps.
Apr 18, 2011 | Copystar CS-1510 Copier
My aficio 2035e shows sc 329 and sc 322. what does this mean?
  1. Remove paper from all output trays. Depending upon the options fitted to your device, the output trays are:
  2. Locate the gray cables that are connected between finisher and main unit. Check that they are secure, and that the cables are in good condition.
  3. Switch off the device at the red power switch.
Dec 16, 2010 | Office Equipment & Supplies
I have a ricoh aficio 220 and it says internal tray 1 is full remove the copy on the display
May 04, 2010 | Ricoh Aficio 220 Laser Printer
The display says following output tray is full.
Look at the area where the paper just exits from the machine. You should see a small black plastic arm. Make sure it has not become stuck in the up position or knocked out of place. This arm is what tells the machine that the area is full of paper. Also your machine is the same as Ricoh 1022, Savin 2522 in case you need to do more research.
Oct 19, 2009 | Gestetner 2212 Digital Imaging System...
We need a manual for the NRG D422/2822/3222 PCL printer. Do you know where I can get this? thank you
Here's a link to the Ricoh version (aficio 220). It's the same machine. Only the Copy" manual is available, not the fax: http://www.ricoh-usa.com/downloads/manuals/bw/aficio220.pdf
Jun 04, 2009 | Office Equipment & Supplies
Cant copy any pictures from computer
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw )
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
Feb 03, 2009 | Kodak EasyShare SV811 (8858946) Digital...
I have a ricoh Aficio 220 and it says internal tray 1 is full remove the copy on the display
Dec 29, 2008 | Ricoh Aficio 220 Laser Printer
Konica 7155 Main Error Code : 74 ,printer stops for no reason
There are a few code 74's, and Konica has a bulletins on them.
DESCRIPTION: Code 74-0 from the E-mail alert system. SOLUTION ID: 154045
SOLUTION: CAUSE: Paper remains at finisher main tray paper exit opening.
DESCRIPTION: Code 74-1 from the E-mail alert system. SOLUTION ID: 154055
SOLUTION: CAUSE: Booklet tray is full.
SOLUTION: Remove the paper from bottom exit of the finisher.
DESCRIPTION: Code 74-4 from the E-mail alert system. SOLUTION ID: 154058
SOLUTION: CAUSE: Paper remains inside finisher.
SOLUTION: Please remove copies from the finisher.
DESCRIPTION: Code 74-5 from the E-mail alert system. SOLUTION ID: 154059
SOLUTION: CAUSE: Punch trash box is full.
SOLUTION: Trash basket of punching unit is full. Please empty trash basket.
DESCRIPTION: Code 74-6 from the E-mail alert system. SOLUTION ID: 154066
SOLUTION: CAUSE: Sub-tray (first tray) is full.
SOLUTION: Sub tray is full. Please remove paper.
I'm guessing it just means the finisher thinks it's full, and wants you to take the copies / prints out.
Apr 23, 2008 | Office Equipment & Supplies
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
