Question about Exercise & Fitness
I have a Sportscraft TX5.ORC Treadmill. When you turn power on and press the + button the machine will beep but the belt will not move. After about 3 or 4 seconds It displays an error code 3. Have checked the speed sensor. What else can I do?
3 Suggested Answers
  • 103 Answers
SOURCE: NordicTrack Z7xi treadmill console buttons not working
Hello there. It sounds as if you may have a button stuck on your console. Thus not allowing any other buttons to be pushed. (i.e. the 4 beeps). This is usually caused by the i-fit buttons (silver buttons on the front). If the machine is only 4 months old you should still be under warranty (1 year) I believe. This problem in most instances requires the console be replaced. You can contact nordictrack through iconservice.com or by using the number on the fron of your users manual.
Good Luck! Tim
Posted on Dec 16, 2009
maxtreadmill
  • 832 Answers
SOURCE: sportart 6310 treadmill - check speed sensor
Unplug unit and check the motor brushes they maybe worn and need to be replaced call Sports Art Fitness customer service @ 1-866-709-1750 they will sell you the brushes
Posted on Mar 13, 2010
My BT3152 treadmill has stopped working, the belt no longer moves
Is anything jamming the belt or motor drive pulley? Look carefully for anything that could be jamming it. If you suspect the motor could be bad, take it electrically out of the circuit and connect it directly to the your power supply, if it spins up you know its working, however, it could still be tripping off when under load.
Nov 09, 2014 | Body Sculpture Bt3152 Motorised Treadmill
The number seven appears on upper left side of tx5.orc treadmill
1) try to run the software calibration for diagnostic, troubleshooting and fix it.
2) adjust the REED switch see the diagram, clean it, and tight the plug+connector very well.
3) adjust the speed sensor , see the diagram, clean it, and tight the plug+connector.
God bless you
Sep 20, 2012 | Exercise & Fitness
I have a tx5 orc treadmill and it will not work when plugged in
1) you must use the VOM, for test the outlet wall, and measure if the voltage is o.k reset the c.breaker from your house.
2) reset the c.breaker from your treadmill
3) replace the fuse with the same capacity(ampers) +voltage and the same type ceramic or glass.
4) after you did the replace, test for main switch, and adjust the REED switch according see the instruc. manual.
5)if the problem persist a) LUBE the deck belt b) Lube the rollers bearing c) lubricate the bearing motor.Otherwise the main motor board is faulty.
Aug 05, 2012 | Exercise & Fitness
I have an E-4 sign coming up on the treadmill. I still dont have a clue how to calibrate it or anything. i bought it over the internet and there was no instruction manual that came with it. i really need...
Dear Sir:
This is guide for software calibration in Horizon. Please see under your Hood for motor the instruction for step in calibration.
Turn the treadmill power to "On." Place the safety key in its place on the treadmill console.
  • 2 Simultaneously press and hold the incline "+" and speed "-" buttons for approximately five seconds: The console will beep and display the software version in either the "Time" window or the "Calories/Elevation" window.
  • 3 Press "Start" and allow the running belt to begin moving. The belt should start at 0.5 mph. If this speed is not the speed your treadmill starts at, adjust the speed cube screw located under the control board. Turn the screw to slowly to the right to increase the speed or slowly to the left to decrease the speed.
  • 4 Verify this speed is correct by counting the running belt revolutions per minute. At 0.5 mph, the running belt should make four revolutions in a minute for the Alpine and Advance 500 models and four-and-a-half revolutions for all other models.
  • 5 Press and hold the "Stop" button for three seconds to exit the engineering menu.
  • sincerely. God bless you.
    ernesto cuadra
    managua, nicaragua. c.a
    Feb 11, 2012 | Exercise & Fitness
    I currently replaced the walking belt on my C954i/C956i treadmill. When I plugged it back in and turned on the power, the treadmill has no power. What could have happened?
    Dear Sir:
    I can read you trouble, and follow the next steps:
    ALIGNING AND ADJUSTING THE RUNNING BELT
    The correct alignment of the running belt is critical to the smooth operation of the treadmill. The belt is properly aligned at the factory. However, during shipping and handling or by use on an uneven surface, the belt may move off center and require a few simple adjustments. Before aligning the running belt, check its operation by following the procedure in Checking the Alignment of the Running Belt. If you determine that the belt needs alignment, follow the instructions here. CAUTION: Special care must be taken when aligning the running belt. Turn OFF the treadmill while adjusting or working near the rear roller. Remove any loose clothing and tie back your hair. Be very careful to keep your finger or any other object clear of the belt and rollers, especially in front of the roller and behind the deck. The treadmill will not stop immediately if an object becomes caught in the belt or rollers. Realigning the belt takes a few simple adjustments. If you are unsure about this procedure, call Precor Customer Support (see Obtaining Service.) Take the following steps to align the running belt on the treadmill. To ensure your safety, make all adjustments while the treadmill is OFF. 1. Make sure the treadmill is OFF and the running belt has completely stopped. 2. Locate the right belt adjustment bolt in the rear end cap of the treadmill. (To determine left and right, stand at the rear of the treadmill and face the display.) See Diagram 24. The direction you turn the bolt depends on how the belt is tracking. Make all belt adjustments on the right rear corner bolt using the hex key provided. • If the belt is off center to the RIGHT, turn the adjusting bolt ¼ turn clockwise, which moves the running belt to the left. • If the belt tracks off center to the LEFT, turn the bolt ¼ turn counterclockwise; this moves the belt to the right. Important: Do not turn the adjusting bolt more than ¼ turn at a time. Overtightening the bolt can damage the treadmill. 3. Turn the unit ON. 4. Stand beside the treadmill and press QUICKSTART. 5. If you are prompted for a password, press INCLINE ??¼, SPEED ??¼, SPEED ??². The running belt starts automatically after the 3-second countdown appears on the display. 6. Press the SPEED ??² key until the display shows a speed of 3 mph (5 kph). 7. Walk around to the rear of the unit and observe the running belt for a few minutes. The belt should run centered along the running bed. If the belt drifts off center, you will need to make adjustments. CAUTION: If you hear any chafing or the running belt appears to be getting damaged, stop the running belt immediately by pressing the red STOP button. Contact Precor Customer Support. 8. If the belt needs additional alignment, repeat steps 1 through 7 until the belt is properly aligned. 9. After aligning the belt, press the STOP button and RESET. Turn OFF the treadmill. Tighten any loose fasteners or other components on the equipment. If you hear unusual noises or you feel that the treadmill is in need of repair or service, contact Precor Customer Support. Refer to Obtaining Service.
    Finally, check if the power cord is loose, connect it again. a) See if the breaker of Home is tripped? b) See if the breaker of the Treadmill is tripped. If do the Belt is very Tighted! loose a little. Try again.
    Thank you in advance, if you need assistance, you can contact me, Blessing. sincerely.
    E. CUADRA Managua, Nicaragua. C.A.
    Sep 26, 2011 | Precor C954i Commercial Treadmill
    The treadmill will sometimes start and most times will not, even though there is still power. Then I will be on and the belt will stop turning. I can move the incline level but that is all.
    With the motor cover off and the power on, make sure there is a red light/led lit on the controler, if yes then press the start button then press #3 on the speed side. If not lit, you dont have power to the controller. If you had a red light, and pressed the speed button, the light should start flashing just before the walk belt starts to move. If the speed button is pushed and the light on the controller does not flash, you have a problem in the console. This is only fixed by replaceing the controler.
    Sorry.
    Hope this was at least helpfull, Matt
    Dec 30, 2010 | Reebok Acd1 Treadmill Motor Control Board ...
    Horizon treadmill won't start running
    The manual said that after lubricating the deck, press Stop and Speed buttons together for 5 minutes and this will reset the lubrication message and the treadmill should work.
    Jan 25, 2010 | Horizon Exercise & Fitness
    I need to know how to tighten the belt
    describe how to tighten the belt on a tx 400 sportscraft treadmill.
    Dec 16, 2009 | RTO Exercise & Fitness
    Exercise & Fitness Logo
    66 people viewed this question
    Top Exercise & Fitness Experts
    Electro Med Services...
    Howard
    Howard
    Tom Chichester
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
