Question about Coleman Sport & Outdoor - Others
Air bed leak
Coleman raised quickbed combo leaks. used 3 times since new. used indoors only. cannot find leak. says on box guaranteed not to leak where do i send to for replacement or fix?
  • 8,197 Answers
Http://www.colemancanada.ca/Warranty/Default.en.aspx
Good Luck and please rate fixya!
Posted on Jan 22, 2009
I got a Swiss gear queen size bed ans it's got a hole right on t he top of the bed on a seam, the patch that came with it is not working in sealing the hole, what else can I use?
You could try some seam weald glue.
But when these leak from a join, it can be very very hard to reseal them.
You could try a hot soldering iron, carefully try to reseal.
But to be honest it may be easier to purchase new.
May 12, 2014 | Swiss Gear SwissGear Queen Raised Double...
Is my old Coleman QuickPump 5999-200C compatable with new Quickbeds?
If the new bed has a built in pump, you won't need the old pump. If not then you can use your pump on the new bed. It all depends on the model you choose to replace your old one.
Aug 05, 2012 | Coleman Quickpump
I have a coleman outdoor split system the indoor unit has two cooper pipes at the bottom the larger one keeps forming ice around it.
Hello my name is Heath it will be my pleasure to assist you. First thing to do is turn the unit off and check the filter then if the filter is okay check to see if the blower comes on when you put the fan switch on the thermostat from auto to on. If the blower isn't coming on then there could be a problem with the blower motor. If the motor is running then turn the system to cool and turn the setting down to where the air should be on. Then check the outside unit and be sure the outside unit is running if the outside unit is not running go to the house panel box and check the breaker to see if any of them are tripped or off. If there off turn them on and check the outside unit again. If all is running and you get no air flow through the vents then the coil could be frozen. If the unit is frozen turn the thermostat to off and leave the indoor blower on by leaving the fan switch in the on position for a couple hours till it thaws. If the unit froze up then there could be a problem with the a/c system most likely low on refrigerant as a result of a leak. I would have it leak tested and repaired if this is the case.
Aug 27, 2011 | Coleman Heating & Cooling
I have a coleman powermate 7.5 hp.pressure switch set at 125 but will only pump up around 100 psi.It keeps running.IF I set switch 100 it will pump up and shut off but it takes a long time.If my H.P....
One can determine the condition of the pump components by the length of time to fill to 125. For example, when new your unit would most likely take about 3~5 minutes to fill to 125, as it wears would take 5~8 minutes. Now it will not reach 125 so most likely problem is leak at one of the connections or cylinder /piston leaking compression. Easy to check for leaks. Spray soapy water on all connections while running and repair as needed. If no leaks, examine condition of the cylinder close to the top of stroke. Unplug machine, let out all the air, remove cover so that you can see bottom of cylinder. Turn motor my hand to move piston to top and look for scratches. If scratched /worn looking, replace cylinder /piston and bearing. After new parts are installed, time unit to fill to 125 and keep track as you use the unit to tell condition of parts/leaks. Good luck No spell check today so forgive.
Jul 08, 2011 | Coleman Air Tools & Compressors
Do I ever need to recharge my coleman mach 3
Hi, and the answer is no. This system is a sealed hermetic a/c unit, and does not require you to charge the unit, only if it develops a leak in a coil, copper line, or a line has rubbed through causing it to leak. If it is cooling good, your freon level should be fine. It doesn't hurt to go on top in the summer or before it gets hot, remove the cover and take your garden hose and kill power. Now, wash the coil out real good. They get very dirty and cause the pressures in the system to get real high and the unit will not cool like it should. This is about all you can do, but its very important. Keeping the indoor filter foam clean is also good, but no you don't need to charge it on a regular basis, only if you have a leak in the unit. Please don't forget to rate me as I know you will be kind. Please let me know if you have any problems with your unit, and I will be happy to help you out.
Sincerely,
Shastalaker7
A/C, Heating,
Sep 07, 2010 | Coleman Mach III Air Conditioner
Appears to be condensation leaking from the Carrier roof A/C in 2009 Pleasure Way Plateau RV. Leaks on back bed and floor. Thanks, Richard
there should be a pan under the evaporator coil in the roof mounted unit, the pan should have a hose on it to remove the water to a non objectionable place, you need to locate the drain and pressure it up to clear it, I would also remove the top covaer and check the cleanliness of the coil drain pan itself
Jul 18, 2009 | Coleman Mach 15 Air Conditioner
Need a replacement coil for a Coleman Evcon air handler Model # AH12L10NA. I am losing freon at a rapid pace. Leak detector indicated leaks in the indoor coil in the air handler. PLEASE HELP! Thanks in...
This may be a bigger issue than you want to tackle alone, generally speaking the coil will have to be ordered from a dealer, as most wholesalers will not sell to the general public. Further, this will require brazing the new coil in, evacuating the system, installing a dryer and recharging.
Jul 12, 2009 | Coleman Heating & Cooling
Leaking water
water leakage from indoor unit
1.clean cooling coil
2. wash air filter
3. check drain tray.if it block then clean it
4. check drain pipe U band.
5.check indoor unit water tray.if damage change by new one or repair it
Sep 04, 2007 | Friedrich QuietMaster RS10J10 Air...
Sport & Outdoor - Others Logo
113 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
David Payne
David Payne
Vernon Taylor
Thomas Perkins
Thomas Perkins
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
