Question about Zanussi ZMB30CST Convection Microwave Oven
Wont work Although the microwave itself recieves power when plugged in, it just doesnt work. The start button gives no response. Please advise. Thanx.
    Problem Solver:
  • 4 Answers
<PLEASE READ THE MICROWAVE SAFETY ADVICE BEFORE OPENING YOUR MICROWAVE - IT CAN KILL YOU!>
My symptoms were not exactly the same as yours. Mine worked intermittently (it would stop and start when heating and a tap on the control panel would occasionally help get it started again).
Here's some information which may be of use. If you read elsewhere on here you'll find that slamming the door can cause problems with the door lock switches moving slightly. So you can have a look to see whether these are being moved correctly when the door is opened and closed.
You'll also hear that if the control board is bad then you'll need to scrap the microwave. Actually this isn't always the case. On this model there are three relays on the printed cicruit board. I'm no electronics buff and not really up to diagnosing such things, but I can tell the difference between a nice shiny looking relay and one that has charring all over the contacts and a slightly melted looking casing. The relays are easy to spot as they have clear cases and you can see the copper coils inside.
I managed to look up the relay from the code on it's side and order a new one (about £3 or $5). With the PCB removed, I was able to swap the relay pretty quickly. I also found that a big grey box on the PCB (lablled Myrra and what I believe to be either a transformer or an inductor) had two dry solder joints and it was physically loose on the board. I suspect a result of some shoddy manufacture and the door slamming again. Ran a bit of solder on to those joints also.
It lives!
Posted on Sep 17, 2011
    Novelist:
  • 101 Answers
Your control board is bad and needs to be replaced. A control board for a microwave costs more money then a new microwave though. If there is no response to you pressing any buttons on the display then the problem is the control board. Let me know if you have any other questions and let me know if this was helpful. Good luck and I am glad that I could help.
Posted on Jan 22, 2009
Will not turn on . Appears as though there's no power.
I'd try to unplug for a while. Could be a bad power cord for the microwave itself. I recently had a toaster problem. Bad wire right at the departure from the plug.
May 12, 2015 | Sharp R-930AK Convection/Microwave Oven
I have a built-in AEG Microwave code MC166(0E?) My son unfortunately used the microwave as a timer so it was on for 30mins without anything in it. It now won't turn "on"; no light/clock...
What fuse did you change? The fuse on the wiring that leads to the microwave needs to be intact, then the fuse in the Microwave itself needs to be checked. Usually there is a plug where the microwave is plugged in, in the cabinet above the microwave, you can take another small appliance or a power tester to make sure power is available in the outlet where the microwave is plugged in. If the power is on at the outlet then you'll know that it is the microwave itself that has turned itself off for some reason. You can get manuals for these ovens at this website
May 11, 2011 | Microwave Ovens
We had a power outage and the display is blinking and there is no response to pressing any button
First, try unplugging the microwave for 2 to 5 minutes and then plugging it back in. Sometimes, a very brief power outage will be sensed by the control as an internal error and the control will lock itself out.
If it continues to blink and does not respond to key presses after this "hard reset", it is likely a portion of the control board could have been damaged from the power outage.
FYI ... the touch panel for this model is no longer available. I mention that because no response from any key press can also denote a shorted key pad.
Apr 15, 2011 | Frigidaire FMT116E1W Microwave Oven
My GE microwave JVM1740DM1WW no longer is responsive to the keypad. Lights, fan, power etc. don't turn on. Just beeps and gives a "disply shortage" error message along with a "might need...
there is no easy fix to this units current problem it will need to be looked at by a service tech as the fault is an internal circuit shortout and needs to have the faulty circuit found and then replaced using expensive testing units
sorry
merry christmas
Dec 21, 2010 | GE Profile Spacemaker Over-the-Range...
We have a over-the-range LG Microwave Model #LMVM2055ST purchased in 2006. It was working fine until today when I tried to heat something, it wouldn't start. The light works inside when you open the...
Most likely the touch panel is bad. You can try ordering a new one from repairclinic.com by searching with your model number. If you find that replacing it doesn't help, return the panel within 30 days and you are only out the shipping costs. With what you describe, it should be the panel itself. Let me know what you find out.
Benjamin
Nov 04, 2010 | LG Over-the-Range Microwave
Whirlpool Microwave Hood Combination MH3184XPS-0 (October 2004), for no reason at all, this morning keeps beeping and running the power setting down from 10 to 1, and just keeps doing it in rapid sequence....
Ours just started doing this exact same thing this past Friday - 12/11/09. What's going on? The cook power just starts beeping all by itself and going from 10 down to 1 over and over again. It may stop momentarily, but then starts again within a minute or so - it's constant until we unplug it. We plug it back in and within a few minutes it starts doing it again. What gives?
Dec 08, 2009 | Whirlpool MH3184XP Microwave Oven
Microwave will not cook..all the buttons work except for the 0 and the start button
hi..the reason to this problem may be due to one of these
reasons.check it out from the following link.
http://applianceparts.wordpress.com/2008/10/29/microwave-doesnt-heatcook-food-what-is-wrong/
try this out..
thank you..
kindly rate my response..
Jul 19, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Westinghouse WST3501 Microwave
Contact Westinghouse Small Kitchen Appliances at 800-245-0600 or 800-947-3745 or visit here.
Is it possible that some spray cleaner accidentally got into the controls?
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
I always recommend that users spray the cleaner on a soft cloth (not on the keypad itself) then wipe the control panel off.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Aug 30, 2008 | Westinghouse WST3501 Microwave Oven
Zanussi ZMB30CST Convection Microwave Oven Logo
153 people viewed this question
Top Zanussi Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Zanussi Microwave Oven Expert? Answer questions, earn points and help others
