Question about Kenmore 46462 Front Load Washer
Wont spin dry
Front load washer model 417
None
Posted on Jan 23, 2009
417 front load washer -
have you cleaned the filter
if its two or three years old also check the motor brushes
Dec 31, 2013 | Sears Washing Machines
Kenmore washer front load 417 wont spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped
Feb 18, 2013 | Kenmore 24032\24036 Top Load Washer
My washer makes a loud noise in the spin cycle. It's a Frigidaire Gallery Washer Model 417.39012890. Any idea how expensive the repair will be?
In my experience with 417 Frigidaires is that when there is a noise in the spin cycle as you describe the drum bearing is failing. This is a very expensive repair that that when I looked up labor and parts could exceed 600 smakeroos.
Feb 14, 2010 | Frigidaire ATF6000ES Front Load Washer
Front loader won't spin replaced shocks because one was broke be still will not spin
if model # starts with 417 replace motor control located at the base of unit. if not 417 please post with model and make of washer
Sep 30, 2009 | Washing Machines
Washer wont run spin cycle model 417
The reason for your washing machine not to spin would be of a faulty motor coupling.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Thank you for contacting Fixya.com
Aug 11, 2009 | Kenmore 43042 Front Load Washer
Washer will not do a spin cycle for rinse or end of cycle
you can check two things,. One is, is the belt broken or stretched, the other is the motor, is the motor turning if the motor is turning then replace the belt. If the motor is not turning replace the motor.
Feb 08, 2009 | Kenmore 44102 Front Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Kenmore 46462 Front Load Washer Logo
167 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
