Question about Canon PIXMA MP150 All-In-One InkJet Printer
Cannot connect power cord
When we moved, the power cord was removed from the Pixma MP150 and we have tried to reconnect it. It appears to be like putting a square peg in a round hole. Is there a trick to it?
  • 432 Answers
No, no trick. Are you sure you have the right power cord? Make sure your looking in the right place on the printer.
Posted on Jul 06, 2007
SOURCE:
Pixma mp 130 - the waste ink absorber is almost full
Try this
1. Disconnect printer from AC power (take out AC cord or power off your power strip). Disconnect USB PC cable from printer.
2. Press and HOLD the POWER button (untill step 7).
3. Reconnect power cord (turn on power) to the printer.
4. The indicator should be green.
5. Press and release the RESUME button , the indicator should be orange.
6. Press and release the RESUME button again, the indicator should be green.
7. NOW Release POWER buttons.
8. NOW Connect the printer to PC (USB cable).
9. NOW...Open "Printers" and make sure that a "copy" of the printer (MP150) had been made. Make that COPY your default printer and all should work.
Let me know if this works for you. Thanks.
Sep 29, 2010 | Canon PIXMA MP130 All-In-One InkJet...
I have problem in my canon MP150 printer that the display is blinking digit 5 and E so wat the problem tell me
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly.
Here is the first fix for this error:
  1. Disconnect the printer's power cord.
  2. Press and hold the power button while reconnecting the power cord.
  3. While still holding down the power button, press the reset button twice (red circle with a triangle).
  4. Release the power button. The printer takes about 10 seconds to show the number 0.
  5. Press + to change the value from 0 to 1.
  6. When this value is 1, press color button; this will light up two leds. One is for plain paper and the other for photo paper. At this point, feed the printer with paper.
  7. Press the power button twice and the printer will print a test page (if this page doesn't print by itself, press the "color" button once and the test page will print).
  8. When you print this sheet the value in the display returns to zero.
  9. Open the printer cover and remove the cartridges. With the printer still open, disconnect the power outlet.
  10. Close the lid and turn on the printer.
  11. Now put your cartridges back in the printer, and wait for 2 minutes. The amber light beside the black ink and color ink should have disappeared.
If you continue to get the error message, try this:
  1. Disconnect power cord.
  2. Press and hold the power button whilst plugging the cord back in.
  3. While still holding the power button, press the reset button twice. The printer's display will read "Factory 1".
  4. Allow the printer to finish warming up (takes around 25 seconds).
  5. The word "idle" appears on the screen.
  6. Disconnect the power cord.
  7. Reconnect the power cord.
  8. Turn the printer back on.
Here is the manual for the Canon MP150.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 05, 2010 | Canon PIXMA MP150 All-In-One InkJet...
What is code 5? I have a Canon Pixma MP150 which no longer prints. Cartridges have been replaced with refilled ones which the printer does not recognize. What to do please? Caryl
  6. When this value is 1, press color button; this will light up two LEDs. One is for plain paper and the other for photo paper. At this point, feed the printer with paper.
Jul 24, 2010 | Canon PIXMA MP150 All-In-One InkJet...
PIXMA MP150 All-In-One InkJet Printer: I am getting a E5 message on my Canon Pixma MP150 ...
You should check the ink level.
Open the [Printer Properties] dialog box. Click the [Maintenance] tab and click [View Printer Status].
If the "?" mark appears then you have to disable the low ink warning. If something else appears please let me know.
The reset procedure is this:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
note: press 3 times for EEPROM reset
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off)
then turn it on again.
May 06, 2010 | Canon PIXMA MP150 All-In-One InkJet...
The waste ink absorber is full
To reset your Canon IP1000 just simply pull out power cord then press-hold power button, while holding power button insert back power cord. You will notice that the power button indicator lights up upon inserting power cord. then you may release power button and start printer. That will solve your "The waste ink absorber is full" message.
Downside is: you may have to do this frequently if your printer looses power. You will understand what i mean.
Jan 04, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Will Not print from my MacBook Pro in spite of trying both wireless and corded connections. Copies perfectly.
Deleted the original CD download. Then, reconnected the corded connection, as there is no wireless capacity. With both computer and printer reconnected, repeated the entire download process, and deleted all prior printers used by computer. System works fine if connected now.
Oct 18, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Paper jammed error notice appears but there is no paper jammed
let print head cool first now disconnect and reconnect the device>>>press on /off remove the paper slowly and softly and reset the cartridge these are best probable step to fix such problem
May 12, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon Pixma MP150
Hi Try
This error means waste ink counter is full.
Solution:
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Press resume
Apr 01, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
Clive
Clive
old marine
old marine
Ekse
